2 Replies Latest reply on Mar 2, 2018 3:00 AM by daniel-r7
    Can open produced DNG in Photoshop but not in LibRaw
    daniel-r7 Level 1
      I have a few questions regarding the Adobe DNG SDK and if i am using it correctly.
      So the flow of my program works as follows: i read a custom binary file containing the raw data.
      This will be the buffer of my output DNG. I can open the produced DNG in the windows preview correctly and
      also in Adobe Photoshop, but if I want to open it in some other programs like LibRaw or RawTherapee, the image
      is just completely black.
      I will post my programm and the log of DNGValidate.exe , perhaps you have an idea what went wrong.
      Here is a link of my DNG.
      See my program below
      #include "DNGWriter.h"
      namespace Unpacker {
      dng_error_code CDNGWriter::writeDNG(byte *pFrame, const std::string &fileName) {
      try {
      m_pDngImage.Reset(m_dngHost.Make_dng_image(m_imageRect, 1, m_depth == 8 ? ttByte : ttShort));
      m_dngBuffer.fArea = m_imageRect;
      m_dngBuffer.fPlane = 0;
      m_dngBuffer.fPlanes = 1;
      m_dngBuffer.fRowStep = m_dngBuffer.fPlanes * m_imageRect.W();
      m_dngBuffer.fColStep = m_dngBuffer.fPlanes;
      m_dngBuffer.fPlaneStep = 1;
      m_dngBuffer.fPixelType = m_depth == 8 ? ttByte : ttShort;
      m_dngBuffer.fPixelSize = TagTypeSize(m_depth == 8 ? ttByte : ttShort);
      m_dngBuffer.fData = pFrame;
      m_pDngImage->Put(m_dngBuffer);
      // Write DNG file
      // Assign Raw image data.
      m_pDngNegative->SetStage1Image(m_pDngImage);
      // Compute linearized and range mapped image
      m_pDngNegative->BuildStage2Image(m_dngHost);
      // Compute demosaiced image (used by preview and thumbnail)
      m_pDngNegative->BuildStage3Image(m_dngHost);
      // Update XMP / EXIF
      m_pDngNegative->SynchronizeMetadata();
      // Update IPTC
      m_pDngNegative->RebuildIPTC(true);
      // Create stream writer for output file
      dng_file_stream fstream(fileName.c_str(), true);
      // Create thumbnail
      dng_image_preview thumbnail;
      dng_render render(m_dngHost, *m_pDngNegative);
      render.SetFinalSpace(dng_space_sRGB::Get());
      render.SetFinalPixelType(m_depth == 8 ? ttByte : ttSShort);
      render.SetMaximumSize(1 << m_depth);
      thumbnail.fImage.Reset(render.Render());
      AutoPtr<dng_image_writer> oWriter(new dng_image_writer());
      oWriter->WriteDNG(m_dngHost, fstream, *m_pDngNegative.Get(), NULL, dngVersion_1_3_0_0, ccUncompressed);
      } catch (const dng_exception &ex) {
           return ex.ErrorCode();
      } catch (...) {
           return dng_error_none;
      dng_error_code CDNGWriter::setup(int rows, int cols, int depth) {
      try {
      m_depth = depth;
      m_imageRect = dng_rect(cols, rows);
      // Set DNG version
      // Remarks: Tag [DNGVersion] / [50706]
      // dngVersion default is the most recent one with 1.4.0.0
      m_dngHost.SetSaveDNGVersion(dngVersion_SaveDefault);
      // Set DNG type to RAW DNG
      // Remarks: Store Bayer CFA data and not already processed data
      m_dngHost.SetSaveLinearDNG(false);
      // DNG Negative Settings
      m_pDngNegative.Reset(m_dngHost.Make_dng_negative());
      // Set camera model
      // Remarks: Tag [UniqueCameraModel] / [50708]
      m_pDngNegative->SetModelName("MyModel");
      // Set localized camera model
      // Remarks: Tag [UniqueCameraModel] / [50709]
      m_pDngNegative->SetLocalName("Grass hopper");
      // Set colorkey information
      // Remarks: Tag
      m_pDngNegative->SetColorKeys(colorKeyRed, colorKeyGreen, colorKeyBlue);
      // Set bayer pattern information
      // Remarks: Tag [CFAPlaneColor] / [50710] and [CFALayout] / [50711]
      // bayer pattern depends on the colorkey set by
      // dngNegative->SetColorKeys(colorKeyRed, colorKeyGreen, colorKeyBlue);
      // In this case: 3 means GBGR bayer pattern
      m_pDngNegative->SetBayerMosaic(3);
      // Set colorchannel information
      m_pDngNegative->SetColorChannels(3);
      // Set linearization table
      // Remarks: Tag [LinearizationTable] / [50712]
      // Calculate bit limit
      const uint8 m_unBitLimit = 0x01 << m_depth;
      AutoPtr<dng_memory_block> oCurve(m_dngHost.Allocate(sizeof(uint8)*m_unBitLimit));
      for (int32 i = 0; i < m_unBitLimit; i++) {
      uint8 *pulItem = oCurve->Buffer_uint8() + i;
      *pulItem = (uint8)(i);
      m_pDngNegative->SetLinearization(oCurve);
      // Set scale to square pixel
      // Remarks: Tag [DefaultScale] / [50718]
      m_pDngNegative->SetDefaultScale(dng_urational(1, 1), dng_urational(1, 1));
      // Set pixel area
      // Remarks: Tag [DefaultCropOrigin] / [50719]
      m_pDngNegative->SetDefaultCropOrigin(0, 0);
      // Set pixel area
      // Remarks: Tag [DefaultCropSize] / [50720]
      m_pDngNegative->SetDefaultCropSize(m_imageRect.W(), m_imageRect.H());
      // Set active area
      m_pDngNegative->SetActiveArea(m_imageRect);
      m_pDngNegative->SetOriginalRawFileName("testdummi.bin");
      // Set white LEVEL, value where the image is supposed to be white
      m_pDngNegative->SetWhiteLevel((0x01 << m_depth) - 1); // 2^bpp -1
      // Set black LEVEL, value where the image is supposed to be black
      //m_pDngNegative->SetBlackLevel(1);
      // Set baseline exposure
      // Remarks: Tag [BaselineExposure] / [50730]
      m_pDngNegative->SetBaselineExposure(0.0);
      // Set if noise reduction is already applied on RAW data
      // Remarks: Tag [NoiseReductionApplied] / [50935]
      m_pDngNegative->SetNoiseReductionApplied(dng_urational(0, 1));
      m_pDngNegative->SetAsShotProfileName("");
      m_pDngNegative->SetBaselineNoise(1.0);
      m_pDngNegative->SetBaselineSharpness(1.0);
      m_pDngNegative->SetBaseOrientation(dng_orientation::Normal());
      m_pDngNegative->SetLinearResponseLimit(1.0);
      // Set camera neutral coordinates
      // Remarks: Tag [AsShotNeutral] / [50728]
      dng_vector pNeutral;
      pNeutral.SetIdentity(3);
      m_pDngNegative->SetCameraNeutral(pNeutral);
      // DNG EXIF Settings
      m_pDngExif = m_pDngNegative->GetExif();
      // Set Camera Make
      // Remarks: Tag [Make] / [EXIF]
      m_pDngExif->fMake.Set_ASCII("PointGrey");
      // Set Camera Model
      // Remarks: Tag [Model] / [EXIF]
      m_pDngExif->fModel.Set_ASCII("Grasshopper GS3-U3-41C6C-C");
      // Set exposure time - Shutterspeed
      // Remarks: Tag [ExposureTime] / [EXIF]
      m_pDngExif->SetExposureTime(10.0 / 1000.0); // random exposure time
      // Set ISO speed
      // Remarks: Tag [ISOSpeed] / [EXIF]
      m_pDngExif->fISOSpeedRatings[0] = 400; // ISO should be 400
      m_pDngExif->fISOSpeedRatings[1] = 0;
      m_pDngExif->fISOSpeedRatings[2] = 0;
      // Set focal length
      // Remarks: Tag [FocalLength] / [EXIF]
      m_pDngExif->fFocalLength.Set_real64(7.0, 1000);
      // Set lens info
      // Remarks: Tag [LensInfo] / [EXIF]
      m_pDngExif->fLensInfo[0].Set_real64(10.0, 10);
      m_pDngExif->fLensInfo[1].Set_real64(10.0, 10);
      m_pDngExif->fLensInfo[2].Set_real64(4.0, 10);
      m_pDngExif->fLensInfo[3].Set_real64(4.0, 10);
      m_pDngExif->fBrightnessValue = dng_srational(0, 0);
      // Set WB mode
      // Remarks: Tag [WhiteBalance] / [EXIF]
      m_pDngExif->fWhiteBalance = 0;
      // Set metering mode
      // Remarks: Tag [MeteringMode] / [EXIF]
      m_pDngExif->fMeteringMode = 2;
      // Remarks: Tag [ExposureBiasValue] / [EXIF]
      m_pDngExif->fExposureBiasValue = dng_srational(0, 0);
      // Set aperture value
      // Remarks: Tag [ApertureValue] / [EXIF]
      m_pDngExif->SetFNumber(2.4); // sunex lens apeture
      // Set Date time
      // poExif->fDateTime();
      // Set GPS value [Future]
      // DNG Profile Settings: Simple color calibration
      AutoPtr<dng_camera_profile> profile(new dng_camera_profile);
      profile->SetName("MyCompany");
      profile->SetCalibrationIlluminant1(lsD50);
      // Excerpt from the DNG specification :
      // ColorMatrix1 defines a transformation matrix that converts XYZ values to reference camera native color space values,
      // under the first calibration illuminant.The matrix values are stored in row scan order.
      dng_matrix_3by3 xyzToCam = dng_matrix_3by3(
      3.13386, -1.61687, -0.49061,
      -0.97877, 1.91614, 0.03345,
      0.07195, -0.22899, 1.40524
      profile->SetColorMatrix1(xyzToCam);
      profile->SetCopyright("MyCompany");
      profile->SetWasReadFromDNG(false);
      m_pDngNegative->AddProfile(profile);
      } catch (const dng_exception &except) {
           return except.ErrorCode();
      } catch (...) {
           return dng_error_unknown;
      And this is the log of DNGValidate
      Validating "000000.dng"...
      Uses little-endian byte order
      Magic number = 42
      IFD 0: Offset = 8, Entries = 55
      NewSubFileType: Main Image
      ImageWidth: 2048
      ImageLength: 2048
      BitsPerSample: 8 8 8
      Compression: Uncompressed
      PhotometricInterpretation: CFA
      Make: "PointGrey"
      Model: "Grasshopper GS3-U3-41C6C-C"
      StripOffsets: Offset = 6004
      Orientation: 1 - 0th row is top, 0th column is left
      SamplesPerPixel: 3
      RowsPerStrip: 2048
      StripByteCounts: Count = 12582912
      PlanarConfiguration: 1
      DateTime: 2018:03:01 17:53:32
      XMP: Count = 4618, Offset = 738
      XMP: <?xpacket begin="\357\273\277" id="W5M0MpCehiHzreSzNTczkc9d"?>
      XMP: <x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 5.6.0">
      XMP:  <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
      XMP:   <rdf:Description rdf:about=""
      XMP:     xmlns:aux="http://ns.adobe.com/exif/1.0/aux/"
      XMP:     xmlns:xmp="http://ns.adobe.com/xap/1.0/"
      XMP:    aux:LensInfo="100/10 100/10 40/10 40/10"
      XMP:    aux:Lens="10.0 mm f/4.0"
      XMP:    xmp:ModifyDate="2018-03-01T17:53:32+01:00"
      XMP:    xmp:MetadataDate="2018-03-01T17:53:32+01:00"/>
      XMP:  </rdf:RDF>
      XMP: </x:xmpmeta>
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP:
      XMP: <?xpacket end="w"?>
      CFARepeatPatternDim: Rows = 2, Cols = 2
      CFAPattern:
          Green    Blue
          Red      Green
      ExifIFD: 5780
      DNGVersion: 1.4.0.0
      DNGBackwardVersion: 1.1.0.0
      UniqueCameraModel: "Reality 7"
      LocalizedCameraModel: "Grass hopper"
      CFAPlaneColor: Red Green Blue
      CFALayout: Rectangular (or square) layout
      LinearizationTable:
      BlackLevelRepeatDim: Rows = 1, Cols = 1
      BlackLevel: 1.00 1.00 1.00
      WhiteLevel: 255 255 255
      DefaultScale: H = 1.0000 V = 1.0000
      DefaultCropOrigin: H = 0.00 V = 0.00
      DefaultCropSize: H = 2048.00 V = 2048.00
      ColorMatrix1:
            3.1339  -1.6169  -0.4906
           -0.9788   1.9161   0.0335
            0.0720  -0.2290   1.4052
      AnalogBalance: 1.0000 1.0000 1.0000
      AsShotNeutral: 1.0000 1.0000 1.0000
      BaselineExposure: +0.00
      BaselineNoise: 1.00
      BaselineSharpness: 1.00
      BayerGreenSplit: 0
      LinearResponseLimit: 1.00
      LensInfo: 10.0 mm f/4.0
      AntiAliasStrength: 1.00
      ShadowScale: 1.0000
      CalibrationIlluminant1: D50
      BestQualityScale: 1.0000
      RawDataUniqueID: <000000000000000050068b0e9fed9be2>
      OriginalRawFileName: "testdummi.bin"
      ActiveArea: T = 0 L = 0 B = 2048 R = 2048
      NoiseReductionApplied: 0/1
      ProfileName: "Reality7"
      ProfileEmbedPolicy: Allow copying
      ProfileCopyright: "Reality7"
      RawImageDigest: <da1dde5cd511616e7cec7ba6d70138b5>
      OriginalDefaultFinalSize: H = 0 V = 0
      OriginalDefaultCropSize: H = 0.00 V = 0.00
      NextIFD = 0
      Exif IFD: Offset = 5780, Entries = 11
      ExposureTime: 1/100.0 sec
      FNumber: f/2.40
      ISOSpeedRatings: 400
      ExifVersion: 2.30
      ShutterSpeedValue: 1/100.0 sec
      ApertureValue: f/2.40
      MeteringMode: CenterWeightedAverage
      FocalLength: 7.0 mm
      WhiteBalance: Auto white balance
      LensSpecificationExif: 10.0 mm f/4.0
      LensModelExif: "10.0 mm f/4.0"
      NextIFD = 0
      *** Warning: Too little padding on left edge of CFA image (possible interpolation artifacts) ***
      *** Warning: Too little padding on top edge of CFA image (possible interpolation artifacts) ***
      *** Warning: Too little padding on right edge of CFA image (possible interpolation artifacts) ***
      *** Warning: Too little padding on bottom edge of CFA image (possible interpolation artifacts) ***
      Raw image read time: 0.013 sec
      FindRawImageDigest time: 0.066 sec
      Linearization time: 0.032 sec
      Interpolate time: 0.067 sec
      Validation complete
      Thank you in advance!
