• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Help: Change Feather value on Photoshop UI (menu bar)
Contributor ,
Mar 02, 2018 Mar 02, 2018
Hi all,
I'm trying to control Photoshop UI's Feather value on menu bar from script at following place.
I mean changing UI value and not doing "document.selection.feather(123)".
I followed the code from following:
Following is current code and not wokring and causing error.
function setFeather(value) {
     var ar = new ActionReference();
     ar.putProperty( charIDToTypeID( "Prpr" ), stringIDToTypeID( "tool" ) );
     ar.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
     var ret = executeActionGet(ar);
     var tmp = ret.getObjectValue(stringIDToTypeID("currentToolOptions"));
     var ad = new ActionDescriptor();
     ad.putReference( charIDToTypeID( "null" ), ar );
     if (value != undefined) tmp.putUnitDouble( charIDToTypeID( "MrqF" ), charIDToTypeID( "#Pxl" ), value );  // Double, Pixel
     ad.putObject( charIDToTypeID( "T   " ), charIDToTypeID( "Ordn" ), tmp ); // Testing: NG
     executeAction( charIDToTypeID( "setd" ), ad, DialogModes.NO );
setFeather(456);
Error from ESTK
And data structure dump around Feather part from Getter Demo script (from Xtools) is following.
Line #13 is Feather.
  <Object symname="CurrentToolOptions" sym="CrnT" objectTypeString="CurrentToolOptions" objectType="CrnT" count="5">
    <Boolean symname="Contiguous" sym="Cntg" boolean="true"/>
    <Integer symname="Selection" sym="Slct" integer="0"/>
    <Object symname="MrqI" sym="MrqI" objectTypeString="MrqC" objectType="MrqC" count="7">
      <Integer symname="MrqM" sym="MrqM" integer="1"/>
      <Integer symname="AspV" sym="AspV" integer="1000"/>
      <Integer symname="AspH" sym="AspH" integer="1000"/>
      <Double symname="FxdW" sym="FxdW" double="64"/>
      <Double symname="FxdH" sym="FxdH" double="64"/>
      <Integer symname="FxWU" sym="FxWU" integer="0"/>
      <Integer symname="FxHU" sym="FxHU" integer="0"/>
    </Object>
    <UnitDouble symname="MrqF" sym="MrqF" unitDoubleTypeString="Pixels" unitDoubleType="#Pxl" unitDoubleValue="123"/>
    <Boolean symname="MrqA" sym="MrqA" boolean="true"/>
  </Object>
Above is different from Brush structure as following for above other thread code.
https://forums.adobe.com/message/9971030
  <Object symname="CurrentToolOptions" sym="CrnT" objectTypeString="CurrentToolOptions" objectType="CrnT" count="59">
    <Integer symname="flow" sym="flow" integer="100"/>
    <Integer symname="Smooth" sym="Smoo" integer="7"/>
    <Object symname="prVr" sym="prVr" objectTypeString="brVr" objectType="brVr" count="4">
      <Integer symname="bVTy" sym="bVTy" integer="0"/>
      <Integer symname="fStp" sym="fStp" integer="25"/>
      <UnitDouble symname="jitter" sym="jitter" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="0"/>
      <UnitDouble symname="Minimum" sym="Mnm " unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="0"/>
    </Object>
    <Object symname="opVr" sym="opVr" objectTypeString="brVr" objectType="brVr" count="4">
    </Object>
    <Enumerated symname="Mode" sym="Md  " enumeratedTypeString="BlendMode" enumeratedType="BlnM" enumeratedValueString="Normal" enumeratedValue="Nrml"/>
    <Integer symname="Opacity" sym="Opct" integer="39"/>
    <Object symname="Brushes" sym="Brsh" objectTypeString="computedBrush" objectType="computedBrush" count="8">
      <UnitDouble symname="Diameter" sym="Dmtr" unitDoubleTypeString="Pixels" unitDoubleType="#Pxl" unitDoubleValue="133"/>
      <UnitDouble symname="Hardness" sym="Hrdn" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="0"/>
      <UnitDouble symname="Angle" sym="Angl" unitDoubleTypeString="Angle" unitDoubleType="#Ang" unitDoubleValue="0"/>
      <UnitDouble symname="Roundness" sym="Rndn" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="100"/>
      <UnitDouble symname="Spacing" sym="Spcn" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="25"/>
      <Boolean symname="Interpolation" sym="Intr" boolean="true"/>
      <Boolean symname="flipX" sym="flipX" boolean="false"/>
      <Boolean symname="flipY" sym="flipY" boolean="false"/>
    </Object>
    <Boolean symname="useTipDynamics" sym="useTipDynamics" boolean="true"/>
    <Boolean symname="brushProjection" sym="brushProjection" boolean="false"/>
    <UnitDouble symname="minimumDiameter" sym="minimumDiameter" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="63"/>
    <UnitDouble symname="minimumRoundness" sym="minimumRoundness" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="25"/>
    <UnitDouble symname="tiltScale" sym="tiltScale" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="200"/>
    <Object symname="szVr" sym="szVr" objectTypeString="brVr" objectType="brVr" count="4">
      <UnitDouble symname="jitter" sym="jitter" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="34"/>
    </Object>
    <Object symname="angleDynamics" sym="angleDynamics" objectTypeString="brVr" objectType="brVr" count="4">
      <UnitDouble symname="jitter" sym="jitter" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="43"/>
    </Object>
    <Object symname="roundnessDynamics" sym="roundnessDynamics" objectTypeString="brVr" objectType="brVr" count="4">
      <UnitDouble symname="jitter" sym="jitter" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="36"/>
    </Object>
    <Boolean symname="useScatter" sym="useScatter" boolean="true"/>
    <Double symname="Count" sym="Cnt " double="1"/>
    <Boolean symname="bothAxes" sym="bothAxes" boolean="false"/>
    <Object symname="countDynamics" sym="countDynamics" objectTypeString="brVr" objectType="brVr" count="4">
    </Object>
    <Object symname="scatterDynamics" sym="scatterDynamics" objectTypeString="brVr" objectType="brVr" count="4">
      <UnitDouble symname="jitter" sym="jitter" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="30"/>
    </Object>
    <Object symname="Texture" sym="Txtr" objectTypeString="Pattern" objectType="Ptrn" count="2">
      <String symname="Name" sym="Nm  " string="$$$/Presets/Patterns/Watercolor=Watercolor"/>
      <String symname="ID" sym="Idnt" string="c7b13f16-e1aa-11d5-913f-bc81e4dfd608"/>
    </Object>
    <UnitDouble symname="textureScale" sym="textureScale" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="100"/>
    <Boolean symname="InvertTexture" sym="InvT" boolean="false"/>
    <Boolean symname="protectTexture" sym="protectTexture" boolean="false"/>
    <Integer symname="textureBrightness" sym="textureBrightness" integer="0"/>
    <Integer symname="textureContrast" sym="textureContrast" integer="0"/>
    <Boolean symname="useTexture" sym="useTexture" boolean="true"/>
    <Boolean symname="TextureCoverage" sym="TxtC" boolean="true"/>
    <Boolean symname="interpretation" sym="interpretation" boolean="true"/>
    <Enumerated symname="textureBlendMode" sym="textureBlendMode" enumeratedTypeString="BlendMode" enumeratedType="BlnM" enumeratedValueString="Height" enumeratedValue="Hght"/>
    <UnitDouble symname="textureDepth" sym="textureDepth" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="100"/>
    <UnitDouble symname="minimumDepth" sym="minimumDepth" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="0"/>
    <Object symname="textureDepthDynamics" sym="textureDepthDynamics" objectTypeString="brVr" objectType="brVr" count="4">
    </Object>
    <Object symname="dualBrush" sym="dualBrush" objectTypeString="dualBrush" objectType="dualBrush" count="9">
      <Boolean symname="useDualBrush" sym="useDualBrush" boolean="true"/>
      <Boolean symname="Flip" sym="Flip" boolean="false"/>
        <UnitDouble symname="Diameter" sym="Dmtr" unitDoubleTypeString="Pixels" unitDoubleType="#Pxl" unitDoubleValue="5000"/>
      </Object>
      <Enumerated symname="BlendMode" sym="BlnM" enumeratedTypeString="BlendMode" enumeratedType="BlnM" enumeratedValueString="ColorBurn" enumeratedValue="CBrn"/>
      </Object>
      </Object>
    </Object>
    <Boolean symname="useColorDynamics" sym="useColorDynamics" boolean="true"/>
    <Object symname="clVr" sym="clVr" objectTypeString="brVr" objectType="brVr" count="4">
    </Object>
    <UnitDouble symname="Hue" sym="H   " unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="0"/>
    <UnitDouble symname="Start" sym="Strt" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="0"/>
    <UnitDouble symname="Brightness" sym="Brgh" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="0"/>
    <UnitDouble symname="purity" sym="purity" unitDoubleTypeString="Percent" unitDoubleType="#Prc" unitDoubleValue="0"/>
    <Boolean symname="colorDynamicsPerTip" sym="colorDynamicsPerTip" boolean="true"/>
    <Boolean symname="WetEdges" sym="Wtdg" boolean="false"/>
    <Boolean symname="Noise" sym="Nose" boolean="false"/>
    <Boolean symname="usePaintDynamics" sym="usePaintDynamics" boolean="true"/>
    <Boolean symname="useBrushPose" sym="useBrushPose" boolean="false"/>
    <Boolean symname="Repeat" sym="Rpt " boolean="true"/>
    <Boolean symname="smoothing" sym="smoothing" boolean="true"/>
    <Double symname="smoothingValue" sym="smoothingValue" double="18"/>
    <Boolean symname="smoothingRadiusMode" sym="smoothingRadiusMode" boolean="false"/>
    <Boolean symname="smoothingCatchup" sym="smoothingCatchup" boolean="true"/>
    <Boolean symname="smoothingCatchupAtEnd" sym="smoothingCatchupAtEnd" boolean="false"/>
    <Boolean symname="smoothingZoomCompensation" sym="smoothingZoomCompensation" boolean="true"/>
    <Boolean symname="pressureSmoothing" sym="pressureSmoothing" boolean="false"/>
    <Object symname="ForegroundColor" sym="FrgC" objectTypeString="RGBColor" objectType="RGBC" count="3">
      <Double symname="Red" sym="Rd  " double="0"/>
      <Double symname="Green" sym="Grn " double="0"/>
      <Double symname="Blue" sym="Bl  " double="0"/>
    </Object>
    <Boolean symname="usePressureOverridesSize" sym="usePressureOverridesSize" boolean="false"/>
    <Boolean symname="usePressureOverridesOpacity" sym="usePressureOverridesOpacity" boolean="false"/>
    <Boolean symname="useLegacy" sym="useLegacy" boolean="false"/>
  </Object>
Any suggestion, tips are appriciated.
Thank you very much,
Naoki
TOPICS
Actions and scripting
Views
1.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
People's Champ , Mar 02, 2018 Mar 02, 2018
var tool = ret.getEnumerationType(stringIDToTypeID("tool")); //!!!!!!!!!!
Votes
Translate
Translate
Adobe
People's Champ ,
ar = new ActionReference(); //!!!!!!!!!!
ar.putClass( tool );        //!!!!!!!!!!
setFeather(456);
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
r-bin​
Thank you very much again for the code.
It worked perfectly.
Just additional note for someone's help.
"MrqF" is for Marquee tools.
For Lasso tools, it needs to be replaced to "DrwR".
# I got stuck here at verification.
Thank you,
Naoki
Votes
Translate
Translate
Report
Report
