3 Replies Latest reply on Mar 4, 2018 5:45 AM by norman.sanders
    Infared/Negative Effect
    darrek57176773
      Hi everyone, I'm looking for some help in creating a certain effect. I'm not 100% sure how to describe it which is why I've probably had no success finding a tutorial.
      I've attached a sample image the effect I want. Taking a headshot and stylising it like an infared/3d image (how you see 3d it without glasses on).
        • 1. Re: Infared/Negative Effect
          norman.sanders Most Valuable Participant
          Open a file (Fig 1), duplicate the layer and Image > Adjustments > Black & White  ... (Fig 2)
          Image > Adjustments > Posterize ... 2 levels* turn off bottom layer, then
          Double click to bring up Layer Style. Blend if.. move top right slider slightly left to create transparent background Fig 3)
          Lock the transparent area (lock symbol appears in Layers panel) and Edit > Fill with Magenta. Blending mode: Multiply
          Duplicate the layer and Edit > Fill with Cyan (don't forget to lock transparency. Blending mode: Multiply
          Duplicate the layer and Edit > Fill with Yellow Cyan (don't forget to lock transparency. Blending mode: Multiply
          Use the Move tool to reposition the layers left and right
          Add a blank layer below the three color layers and Edit > Fill with white
          Choose a cream color and use the Gradient tool, dragged vertically, to produce the background vignette
          *You may find that Posterize is a tad too harsh for your design. In that case use Image > Adjustments > Levels, for this type of result:
          • 2. Re: Infared/Negative Effect
            darrek57176773 Level 1
            Thank you very much!
            When I get to the edit>fill part it's still filling the transparent parts of the face, etc even though I have locked 'transparent pixels' on the layers palette for this layer? Any idea what I'm doing wrong?01.jpeg
            • 3. Re: Infared/Negative Effect
              This may help:
              Fig 1... Your high contrast image on a white surround.
              Fig 2... Transparent layer below it.  Blend if applied to the image layer
              Fig 3... Choose Layer > Merge Down
              Good luck!
