Hi
I have been using Topaz or Nik Collections as smart filters in Photoshop and I have a question about non-destructive editing and whether or not there is a better workflow to the one described below
So far this is all working and I am happy with it. The question now comes when I decide to go back and amend from of my adjustments. I do the following
This works but gets a little tedious if I decide to visit my adjustments often and it gets really tedious if I make further adjustments using layers above my smart object as I end up with multiple composite layers and multiple smart objects.
Hopefully I have described my workflow adequately for you to be able to advise.
Thank you for your help.
Regards, Ian
Yes - just double click on the smart object in the layers panel to open it and a psb document will open with all your original layers intact. Adjust them and close the psb - you will be prompted to save - do so. That will update the smart object.
Dave
Why do you not convert the Layers themselves to a Smart Object and open and edit that as necessary?
Hi, sorry but I do not understand, please could you explain a little further. If it helps I've pasted the layers from my image. Thank you for your help.
Instead of creating a composite layer just select all the layers, click on first and shift click on last, then convert them to a single smart object
Dave
Is this still non-destructive? Once I've clicked on all the layers and created a single smart object can I then go back to my individual adjustments?
Regards, Ian.
Dave
Excellent, that worked a treat, thank you for your patience
Regards, Ian.
You're welcome
Dave
