10 Replies Latest reply on Mar 8, 2018 10:16 PM by amow31609571
    My Phonegap app is redirected to annoying isp page,help
    amow31609571
      When my mobile data credit expires ,isp redirects to its page ,how can i prevent that via config file or security index meta tag,i have already done on config this
      <access origin="*://*.mysite/*" subdomains="true" />
      please help me, because its really important.
        • 1. Re: My Phonegap app is redirected to annoying isp page,help
          jcesarmobile_ Adobe Community Professional
          do you have an allow-navigation tag in your config.xml? if you have it with *, change it to only allow navigation to your site
          • 2. Re: My Phonegap app is redirected to annoying isp page,help
            amow31609571 Level 1
            thank you so much i will reply back with outcome
            • 3. Re: My Phonegap app is redirected to annoying isp page,help
              Hi again i tested the url as instructed,the ajax loads isp page instead of showing no network when data credit is off
              here is what i did .Can you direct me whats wrong with my config code
              <allow-navigation href="*://*.mysite.php/*" />
              <!-- The above is equivalent to these three declarations -->
              <allow-navigation href="http://*/*" />
              <allow-navigation href="https://*/*" />
              <allow-navigation href="data:*" />
              <access origin="*://*.googleapis.com/*" subdomains="true" />
              <access origin="*://*.gstatic.com/*" subdomains="true" />
              <access origin="*://*.google.com/*" subdomains="true" />
              <access origin="*://*.googleusercontent.com/*" subdomains="true" />
                  <allow-intent href="http://*/*" />
                  <allow-intent href="https://*/*" />
                  <allow-intent href="tel:*" />
                  <allow-intent href="sms:*" />
                  <allow-intent href="mailto:*" />
                  <allow-intent href="geo:*" />
              • 4. Re: My Phonegap app is redirected to annoying isp page,help
                Can you post your actual, real config.xml?
                This is for allowing internal navigation to your site
                For ajax the access tag is used, so you should use
                <access origin="*://*.mysite.php/*" />
                Also try adding a connect-src to your Content-Security-Policy tag (if you have one)
                connect-src *://*.mysite.php/*
                • 5. Re: My Phonegap app is redirected to annoying isp page,help
                  Thank you so much  below is my config file and how
                  ajax loads remote page to my  index file,when credit expires the isp page is loaded.
                  Index file
                              $(document).ready(function(){
                                  $('#form-id').load('http://mysite/', '', function(response, status, xhr) {
                                      if (status == 'error') {
                                          var msg = "Sorry but there was an error: ";
                                          $(".content").html(msg + xhr.status + " " + xhr.statusText);
                      </script>
                  <div id="form-id">Please  check network</div>
                  My config file
                  <?xml version='1.0' encoding='utf-8'?>
                  <widget id="com.com.com" version="4.0.0" xmlns="http://www.w3.org/ns/widgets" xmlns:gap="http://phonegap.com/ns/1.0">
                      <name>BuyOuts</name>
                      <description>
                         Deals
                      </description>
                      <author email="support@phonegap.com" href="my site">
                          Motor deals and spares
                      </author>
                      <content src="index.html" />
                  <preference name="LoadUrlTimeoutValue" value="70000"/>
                  <preference name="SplashScreenDelay" value="7000" />
                      <preference name="DisallowOverscroll" value="true" />
                      <preference name="android-minSdkVersion" value="14" />
                      <plugin name="cordova-plugin-battery-status" source="npm" spec="~1.1.1" />
                      <plugin name="cordova-plugin-camera" source="npm" spec="~2.1.1" />
                      <plugin name="cordova-plugin-media-capture" source="npm" spec="~1.2.0" />
                      <plugin name="cordova-plugin-console" source="npm" spec="~1.0.2" />
                      <plugin name="cordova-plugin-contacts" source="npm" spec="~2.0.1" />
                      <plugin name="cordova-plugin-device" source="npm" spec="~1.1.1" />
                      <plugin name="cordova-plugin-device-motion" source="npm" spec="~1.2.0" />
                      <plugin name="cordova-plugin-device-orientation" source="npm" spec="~1.0.2" />
                      <plugin name="cordova-plugin-dialogs" source="npm" spec="~1.2.0" />
                      <plugin name="cordova-plugin-file" source="npm" spec="~4.1.1" />
                      <plugin name="cordova-plugin-file-transfer" source="npm" spec="~1.5.0" />
                      <plugin name="cordova-plugin-geolocation" source="npm" spec="~2.1.0" />
                      <plugin name="cordova-plugin-globalization" source="npm" spec="~1.0.3" />
                      <plugin name="cordova-plugin-inappbrowser" source="npm" spec="~1.3.0" />
                      <plugin name="cordova-plugin-media" source="npm" spec="~2.2.0" />
                      <plugin name="cordova-plugin-network-information" source="npm" spec="~1.2.0" />
                      <plugin name="cordova-plugin-splashscreen" source="npm" spec="~3.2.1" />
                      <plugin name="cordova-plugin-statusbar" source="npm" spec="~2.1.2" />
                      <plugin name="cordova-plugin-vibration" source="npm" spec="~2.1.0" />
                      <plugin name="cordova-plugin-whitelist" source="npm" spec="~1.2.1" />
                      <platform name="android">
                  <icon density="ldpi" src="www/res/icon/android/drawable-ldpi-icon.png" />
                          <icon density="mdpi" src="www/res/icon/android/drawable-mdpi-icon.png" />
                          <icon density="hdpi" src="www/res/icon/android/drawable-hdpi-icon.png" />
                          <icon density="xhdpi" src="www/res/icon/android/drawable-xhdpi-icon.png" />
                          <icon density="xxhdpi" src="www/res/icon/android/drawable-xxhdpi-icon.png" />
                          <icon density="xxxhdpi" src="www/res/icon/android/drawable-xxxhdpi-icon.png" />
                          <splash density="land-ldpi" src="www/res/screen/android/drawable-land-ldpi-screen.png" />
                          <splash density="land-mdpi" src="www/res/screen/android/drawable-land-mdpi-screen.png" />
                          <splash density="land-hdpi" src="www/res/screen/android/drawable-land-hdpi-screen.png" />
                          <splash density="land-xhdpi" src="www/res/screen/android/drawable-land-xhdpi-screen.png" />
                          <splash density="land-xxhdpi" src="www/res/screen/android/drawable-land-xxhdpi-screen.png" />
                          <splash density="land-xxxhdpi" src="www/res/screen/android/drawable-land-xxxhdpi-screen.png" />
                          <splash density="port-ldpi" src="www/res/screen/android/drawable-port-ldpi-screen.png" />
                          <splash density="port-mdpi" src="www/res/screen/android/drawable-port-mdpi-screen.png" />
                          <splash density="port-hdpi" src="www/res/screen/android/drawable-port-hdpi-screen.png" />
                          <splash density="port-xhdpi" src="www/res/screen/android/drawable-port-xhdpi-screen.png" />
                          <splash density="port-xxhdpi" src="www/res/screen/android/drawable-port-xxhdpi-screen.png" />
                          <splash density="port-xxxhdpi" src="www/res/screen/android/drawable-port-xxxhdpi-screen.png" />
                      </platform>
                      <platform name="ios">
                          <icon height="57" platform="ios" src="www/res/icon/ios/icon.png" width="57" />
                          <icon height="114" platform="ios" src="www/res/icon/ios/icon@2x.png" width="114" />
                          <icon height="40" platform="ios" src="www/res/icon/ios/icon-40.png" width="40" />
                          <icon height="80" platform="ios" src="www/res/icon/ios/icon-40@2x.png" width="80" />
                          <icon height="50" platform="ios" src="www/res/icon/ios/icon-50.png" width="50" />
                          <icon height="100" platform="ios" src="www/res/icon/ios/icon-50@2x.png" width="100" />
                          <icon height="60" platform="ios" src="www/res/icon/ios/icon-60.png" width="60" />
                          <icon height="120" platform="ios" src="www/res/icon/ios/icon-60@2x.png" width="120" />
                          <icon height="180" platform="ios" src="www/res/icon/ios/icon-60@3x.png" width="180" />
                          <icon height="72" platform="ios" src="www/res/icon/ios/icon-72.png" width="72" />
                          <icon height="144" platform="ios" src="www/res/icon/ios/icon-72@2x.png" width="144" />
                          <icon height="76" platform="ios" src="www/res/icon/ios/icon-76.png" width="76" />
                          <icon height="152" platform="ios" src="www/res/icon/ios/icon-76@2x.png" width="152" />
                          <icon height="29" platform="ios" src="www/res/icon/ios/icon-small.png" width="29" />
                          <icon height="58" platform="ios" src="www/res/icon/ios/icon-small@2x.png" width="58" />
                          <icon height="87" platform="ios" src="www/res/icon/ios/icon-small@3x.png" width="87" />
                          <splash height="1136" platform="ios" src="www/res/screen/ios/Default-568h@2x~iphone.png" width="640" />
                          <splash height="1334" platform="ios" src="www/res/screen/ios/Default-667h.png" width="750" />
                          <splash height="2208" platform="ios" src="www/res/screen/ios/Default-736h.png" width="1242" />
                          <splash height="1242" platform="ios" src="www/res/screen/ios/Default-Landscape-736h.png" width="2208" />
                          <splash height="1536" platform="ios" src="www/res/screen/ios/Default-Landscape@2x~ipad.png" width="2048" />
                          <splash height="768" platform="ios" src="www/res/screen/ios/Default-Landscape~ipad.png" width="1024" />
                          <splash height="2048" platform="ios" src="www/res/screen/ios/Default-Portrait@2x~ipad.png" width="1536" />
                          <splash height="1024" platform="ios" src="www/res/screen/ios/Default-Portrait~ipad.png" width="768" />
                          <splash height="960" platform="ios" src="www/res/screen/ios/Default@2x~iphone.png" width="640" />
                          <splash height="480" platform="ios" src="www/res/screen/ios/Default~iphone.png" width="320" />
                      </platform>
                      <platform name="wp8">
                          <icon height="99" platform="wp8" src="www/res/icon/wp8/ApplicationIcon.png" width="99" />
                          <icon height="159" platform="wp8" src="www/res/icon/wp8/Background.png" width="159" />
                          <splash height="1280" platform="wp8" src="www/res/screen/wp8/screen-portrait.jpg" width="768" />
                      </platform>
                      <platform name="windows">
                          <icon height="150" platform="windows" src="www/res/icon/windows/Square150x150Logo.scale-100.png" width="150" />
                          <icon height="30" platform="windows" src="www/res/icon/windows/Square30x30Logo.scale-100.png" width="30" />
                          <icon height="50" platform="windows" src="www/res/icon/windows/StoreLogo.scale-100.png" width="50" />
                          <splash height="300" platform="windows" src="www/res/screen/windows/SplashScreen.scale-100.png" width="620" />
                          <icon height="120" platform="windows" src="www/res/icon/windows/StoreLogo.scale-240.png" width="120" />
                          <icon height="44" platform="windows" src="www/res/icon/windows/Square44x44Logo.scale-100.png" width="44" />
                          <icon height="106" platform="windows" src="www/res/icon/windows/Square44x44Logo.scale-240.png" width="106" />
                          <icon height="70" platform="windows" src="www/res/icon/windows/Square70x70Logo.scale-100.png" width="70" />
                          <icon height="71" platform="windows" src="www/res/icon/windows/Square71x71Logo.scale-100.png" width="71" />
                          <icon height="170" platform="windows" src="www/res/icon/windows/Square71x71Logo.scale-240.png" width="170" />
                          <icon height="360" platform="windows" src="www/res/icon/windows/Square150x150Logo.scale-240.png" width="360" />
                          <icon height="310" platform="windows" src="www/res/icon/windows/Square310x310Logo.scale-100.png" width="310" />
                          <icon height="150" platform="windows" src="www/res/icon/windows/Wide310x150Logo.scale-100.png" width="310" />
                          <icon height="360" platform="windows" src="www/res/icon/windows/Wide310x150Logo.scale-240.png" width="744" />
                          <splash height="1920" platform="windows" src="www/res/screen/windows/SplashScreenPhone.scale-240.png" width="1152" />
                      </platform>
                  <!-- Wildcards are allowed for the protocol, as a prefix
                       to the host, or as a suffix to the path -->
                  <allow-navigation href="*://*.mysite/*" />
                          <allow-intent href="market:*" />
                      </platform>
                          <allow-intent href="itms:*" />
                          <allow-intent href="itms-apps:*" />
                      </platform>
                  </widget>
                  • 6. Re: My Phonegap app is redirected to annoying isp page,help
                    You have multiple
                    You have to remove all those
                    • 8. Re: My Phonegap app is redirected to annoying isp page,help
                      hi i removed the intents above also i have put this as csp on my index page
                      <meta http-equiv="Content-Security-Policy"
                      content="default-src 'self' https://*.mysite;
                                    script-src 'unsafe-inline'
                                 script-src 'self' https://ajax.googleapis.com/ajax/libs/jquery/2.1.4/jquery.min.js">
                      when i open app scripts are not loading and css
                      neither remote page..i guess iam still trying to understand how works...can please help.
                      • 9. Re: My Phonegap app is redirected to annoying isp page,help
                        Sorry, wrong copy/paste
                        You have multiple
                        remove all those and only keep the <allow-navigation href="*://*.mysite/*" />
                        But allow-navigation is for page navigation, XHR calls are handled by access tags and you don't have any for allowing connections other than google sites, are you sure you provided the right config.xml and didn't forgot any access tag?
                        • 10. Re: My Phonegap app is redirected to annoying isp page,help
                          Hi thank you so much ...am really making progress especially after you mentioned csp
                          i removed tags,
                          i also played around with csp
                          <meta http-equiv="Content-Security-Policy" content="default-src 'self' http://*.mysite http://mysite.com/php  data: gap: https://ssl.gstatic.com 'unsafe-eval'; style-src 'self' 'unsafe-inline';style-src 'self'https://fonts.googleapis.com/icon?family=Material+Icons;img-src https://cdnjs.cloudflare.com/ajax/libs/font-awesome/4.7.0/css/font-awesome.min.css 'self' http://mysite.com/ data:; script-src 'self' 'unsafe-inline'; media-src *;style-src 'self' 'unsafe-inline'">
                          However
                          google map script  not working  nor when i upload a pic it doesn't show up in div
