• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Not Responding / Out of Memory PLZ HHEELLPP
Community Beginner ,
Mar 06, 2018 Mar 06, 2018
I am about to lose my mind.  I have never had trouble with this computer.  I have played all sorts of games with the settings way up.  I am new to AE and Adobe in general and am working with tutorials on Lynda.com.  I can't tell you how many time the program has crashed.  Trust me it's been dozens.
Here are some settings I changed and that did not seem to help.
I was told recently to buy a Mac and all my problems will go away.  Have you seen how expensive those are?! OUCH, not can do!
Please help me!  I would be so grateful if someone could make this system work with AE 2018.
Thank you in advance!
Views
320
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Hello,
Dolly.mov seems a long movie. Is it a sample movie for learning? If you do not need to stick to using the movie, I would recommend you use shorter movies to avoid the shortage of the memory.
Votes
Translate
Translate
Report
Report
Mar 08, 2018 Mar 08, 2018
LATEST
It is not long.  It is when I am trying to delete points for 3D tracking that I get into problems.  This is a good computer and Adobe shows that I should be able to run AE just fine.  What is going on?
Votes
Translate
Translate
Report
Report
Participant ,
Check Task Manager and see if AE is really stuck (RAM maxed out, HDD bottleneck) or just calculating (CPU at 100). If it's calculating, you'll have to wait for it to finish. If you're maxed out your RAM,  my workaround would be to render out Dolly.mov to an image sequence and re-import it to do the tracking - in pieces if needed.
Also, a games machine is not a compositing machine. And a pc and a mac with the same specs will perform the same and will require the same resource planning on your part.
Wim
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Mar 07, 2018 Mar 07, 2018
Shorten your clip. The Camera Tracker and Warp Stabilizer requires substantial amounts of RAM to be populated with its algorithm while processing - running out of memory is likely to happen with long footage. It's also slow. It's ideal to shorten the clip to just what you really need.
Read some relevant tips here -
memory and storage tips for Warp Stabilizer and 3D Camera Tracker | Creative Cloud blog by Adobe
Motion Graphics Brand Guidelines & Motion Graphics Responsive Design Toolkits
Votes
Translate
Translate
Report
Report
