• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFC Init problem
Explorer ,
Jun 23, 2008 Jun 23, 2008
I'm trying to create a cfc in my application scope but the variables I set in the init method don't seem to be persistent. Here is the init method:
<cfcomponent displayname="coupons" hint="Checks validity and type of coupon and applies it to order."> <cffunction name="init" access="public" output="false" returntype="coupon"> <cfargument name="ds" required="true" type="string" <cfset variables.ds=arguments.ds> <cfreturn this> </cffunction>
Here's the call in the Application.cfc
<cfset Application.coupons = createObject("component", "coupon").init(application.admin.ds)>
Here is the method that throws the "variables.ds not defined error"
<cfstoredproc procedure="pr_getCouponList" datasource="#variables.ds#" debug="Yes"> <cfprocparam type="In" cfsqltype="CF_SQL_INTEGER" dbvarname="@Active" value="#arguments.Active#" null="No"> <cfprocparam type="In" cfsqltype="CF_SQL_VARCHAR" dbvarname="@Sort" value="#arguments.gridSortColumn#" null="No"> <cfprocresult name="getCouponList" resultset="1"> </cfstoredproc>
TOPICS
Advanced techniques
Views
290
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Okay, I figured out the problem but don't know the answer. I am getting this problem when I try to bind the cfc in a grid because the grid is binding a new copy of the cfc instead of the one created in the application scope:
<cfgrid format="html" name="getCouponList" pagesize="#attributes.pageSize#" selectmode="row"
bind="cfc:cfcs.coupon.getCouponList({cfgridpage},{cfgridpagesize},{cfgridsortcolumn},{cfgridsortdirection},{active})">
It works if I call it through an invoke command.
The problem I have now is, how can I bind a cfc in a scope?
Votes
Translate
Translate
Report
Report
LEGEND ,
Jun 24, 2008 Jun 24, 2008
LATEST
> selectmode="row"
I'm not sure how to use a variable instead of a CFC in a bind statement (I
don't do much UI type development, so have never needed to know); however
your init() method in your CFC could look to see if there's an instance of
itself in the application scope and if so return that instead of a new
instance of itself. Then you chain your method call thus:
cfcs.coupon.init().getCouponList(etc...)
Adam
Votes
Translate
Translate
Report
Report
Resources
Documentation
