Hi all,https://indesignsecrets.com/batch-change-hyperlinks-across-a-whole-indesign-document.php
I have been trying to change all the hyperlinks in an InDesign document (there are a lot!! need to change "http://" to "https://")
I found this tutorial
the problem is that Indesign CC 2018 will not open the IDML file (whether I have modified the file externally or not) and the IDML was created in the same program. InDesign crashes when I try to open the IDML file.
any help or advice would be greatly appreciated
either help with opening the file OR help with change 100's of hyperlinks in the InDesign file
If you have the original .indd file then you don't need an IDML to open an InDesign file using CC 2018. Since CC 2018 is the most recent version of the program it should be able to open any document created by an earlier version of the program. See if opening the original file works for you.
thank you for your response
in the tutorial it says to export as "IDML" then open the file as a zip file......inside the zip file is the XML files which can be edited using any text editor..... but you can also "find/replace" across the entire file. which I did.
but after I recompress the files into an "IDML" file it will not open in InDesign cc 2018
so....
I attempted to export an IDML file then just open it in InDesign (no external editing)... but the file still fails to open in Indesign.
so I assume that editing the file with the text editor is not the problem, but that InDesign will not open IDML files.
Are you doing this on a Mac or Windows?
I'm on a mac, running macOS 10.11.6
Gandhi4 wrote
... but after I recompress the files into an "IDML" file it will not open in InDesign cc 2018
That article does not mention "recompressing" at all. David uses a text editor that can extract one single file out of a ZIP file and also can put it back in the same place, without rebuilding the entire ZIP file – which is a crucial point of the structure of an IDML file.
Googling for your question resulted in this page (funny enough also from InDesignSecrets): https://indesignsecrets.com/topic/how-do-i-re-zipcompress-an-expanded-idml-file
hi there,
that what I meant by recompressing.... put the file back in the IDML file... doesn't work either way.
I have just tried again.... to open the IDML that I create in Indesign CC 2018 in Indesign CC 2018 (no external editing, just export as IDML then open again in InDesign CC 2018)
it crashes InDesign.
Hi Gandhi4 ,
how exactly was your workflow with the IDML file?
Did you inspect the IDML file with a tool like Springy where you could look into the package and designate an editor like TextWrangler for editing the XML files and also writing back the results directly to the package?
Regards,
Uwe
Hi all,
I used Better zip to look into the IDML/ZIP file and then used text wrangler to edit the XML file.
the thing is.... even if I don't edit the XML files or open the IDML as a zip file..... the IDML file will not open in InDesign CC 2018... it just crashes.
Gandhi4 wrote
… the thing is.... even if I don't edit the XML files or open the IDML as a zip file..... the IDML file will not open in InDesign CC 2018... it just crashes.
Ok. But that's an entirely different problem from editing an IDML file.
I would send Himanshu the file for inspection. Also send the InDesign document where you exported the IDML from.
Regards,
Uwe
Hi Stuart,
Kindly share your file on corrupt_indesign_docs@adobe.com this email ID so that we can look into it.
Regards,
Himanshu Kapoor
I cannot really provide the original file as is HUGE (2GB+) with 1000s of links and 100s pages and images.
ultimately what I need is to find and replace unique Hyperlinks (thats why i was looking into the XML file)
e.g
http://www.minispares.com/21A1879.aspx
http://www.minispares.com/MSRJM.aspx
http://www.minispares.com/FAM7306.aspx
to
https://catalogue.minispares.com/21A1879.aspx
https://catalogue.minispares.com/MSRJM.aspx
https://catalogue.minispares.com/FAM7306.aspx
I'm not well versed in javascript
can someone help me with some script?
thank you all for your help so far
Gandhi4 wrote
I cannot really provide the original file as is HUGE (2GB+) with 1000s of links and 100s pages and images.…
That may be the real problem here.
Do you mean the InDesign document is 2 GB+ or is it the IDML file? Or both?
Working with file sizes like that seems to be the culprit here. Can you do something to reduce overall file size? Are there any images embedded instead of linked?
First action I would try is a Save As with the document.
Then see into the Links panel if there are any images embedded. Unembed them.
The next step would to test if there is any pixel data that has no link at all and is pasted to the layout.
That would require a script to be effective. We recently had that topic, I think:
Re: Clipboard images and report it
If you are on OS X read on what solution Rob Day provided for that.
If on Windows look after Peter Kahrel's script that is linked to there.
Regards,
Uwe
Gandhi4 wrote
e.ghttp://www.minispares.com/21A1879.aspx
to
What's not clear for me:
Should only URLs change where www.minispares.com is involved?
Or do you really want to change ALL
URLs to
Or there are more cases to differentiate?
Regards,
Uwe
Sorry. But the forum editor is a mess on formatting code where URLs or parts of URLs are involved…
I meant:
to
Regards,
Uwe
hello again,
INDD file is 316.5mb
IDML file is 22.3mb
packaged up 2gb (INDD + IDML + linked images)
if I knew how to create javascript I would create a script to find and replace the hyperlinks I wish to change, but I don't so this I why I was trying to use the IDML method and edit the XML file.
cheers
I've never seen an IDML file that large. Are you embedding images?
Hi Bob,
22.3 MB is not that large for an InDesign document IDML file with hundreds of pages.
Especially if there are tables involved.
Regards,
Uwe
EDIT: Meant IDML not InDesign document.
Missed the decimal. Need more coffee.
Hi again
the file has just over 100 pages.
every single page has a table on it and a lot of anchored objects (like every object!). (I'm not the original creator!!)
there are no embed images.
thanks
so ive just check with the client
to
so
yes
http://www. to https://catalogue.
but
.aspx needs to be removed as well
thank you again
to
Did you test both versions of the URL?
The first one is working, the second one is giving my browser headache:
Wrong config of website and no security ( or no certificate ).
Regards,
Uwe
the new website is not live yet, we are prepping for the changeover
Ok. Stephen_A_Marsh provided a scripting tool for a possible solution here:
Regards,
Uwe
Thanks Uwe, I have tested various regular expressions in the hyperlink script in the other topic thread with success.
______________
P.S. The topic of editing IDML files is also mentioned here:
Re: automatically relinking Shutterstock fpos to hires images
