• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
drop down menu Partially dissapears.
Community Beginner ,
Mar 07, 2018 Mar 07, 2018
Using Windows 7, CS6
This seams/may have started after an nvidea update, but a rollback showed the problem still persisting.
If I reduce the window then up again it refeshes, problem does not always start on its own, its random. Been trying to find a fix for a month now on the web and nothing has worked. Registry refresh is on, taskmgr seams fine, did some resets in PS just in case, I dont customize PS.
Have had this problem once before long time ago, sys update got rid of it.
Thanks!
Views
634
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Mar 07, 2018 Mar 07, 2018
I notice that clipping is in the location where the document draws. This indicates a bug in your open-gl driver (the driver incorrectly place the document view over the popup window).
Try to find an update for your video card, or turn ogg GPU in Preferences>Performance.
Jesper
Votes
Translate
Translate
Adobe
Community Expert ,
Have you tried resetting Preferences?
Votes
Translate
Translate
Report
Report
From the Pref Menu yes, The Ctrl/Shift/Alt has not revealed anything.
Votes
Translate
Translate
Report
Report
Community Expert ,
To reset preferences quickly using a keyboard shortcut: Press and hold Alt+Control+Shift (Windows) as you start Photoshop. You are prompted to delete the current settings. The new preferences files are created the next time you start Photoshop.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jesper
Votes
Translate
Translate
Report
Report
I switched to Drawing Mode-Normal, was on advanced. Turned off PAC.
ogg ??
No Change.
tried 10 times Alt/Ctrl/Shift just now and no promps show up, takes 2 sec for PS to load.
Votes
Translate
Translate
Report
Report
I switched off "Use Graphics Processor" toggle, thats what you meant I believe, its working so far, see how it goes today and will report back. Nvidea drivers up to date, just have to see if theirs something specific with PS.
Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
You may need to roll back the driver a version or two.
Votes
Translate
Translate
Report
Report
Only did one update when this problem occurred, and already rolled back.
Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
If your machine is using two GPUs, see that the Nvidia control panel is switched to their one for Photoshop.
This and a few other suggestions shown here: Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
Votes
Translate
Translate
Report
Report
Thanks will look into that
Votes
Translate
Translate
Report
Report
Hmm, why im I getting messages in Asian Now?
Votes
Translate
Translate
Report
Report
Mar 08, 2018 Mar 08, 2018
So far no more problems. Thanks for the help
Votes
Translate
Translate
Report
Report
Mar 09, 2018 Mar 09, 2018
LATEST
I followed these instructions unloaded all their software/drivers and loaded the latest Nvidia drivers, reingaged PS GPU and so far all works well.
Votes
Translate
Translate
Report
Report
