7 Replies Latest reply on Jun 23, 2008 10:31 AM by Newsgroup_User
    Unable to Unlock Layers
    Gary_Whitling
      Hello,
      I have downloaded a template from Yootheme which is for Joomla, I am trying to unlock some layers but it is impossible?
      Is there any setting/protection that could stop me from doing this? I have paid for this template but as I say can not edit the layers which I should be able to do.
      I am using Fireworks CS3
      Gary
        • 1. Re: Unable to Unlock Layers
          Level 7
          Without actually seeing the problem It's hard to comment, but you should
          just be able to click on the padlock Icon in the layers panel.
          Peter
          ____________________
          "Gary Whitling" <webforumsuser@macromedia.com> wrote in message
          news:g3nvcq$c27$1@forums.macromedia.com...
          | Hello,
          trying to
          be
          | able to do.
          | Gary
          • 2. Re: Unable to Unlock Layers
            Gary_Whitling Level 1
            Hi Peter,
            Yea, I tried that as normal but the padlocks will not unlock?
            Very Strange and very frustrating too.
            Any Suggestions
            • 3. Re: Unable to Unlock Layers
              Level 7
              Have you checked to see if they are 'Read only' files? Right click on the
              file in question and select 'Properties and uncheck 'Read only' if checked.
              All I can think of.
              Peter
              news:g3o187$dso$1@forums.macromedia.com...
              | Hi Peter,
              | Any Suggestions
              • 4. Re: Unable to Unlock Layers
                Hi Peter,
                Thanks for the suggestion, Checked that and it is not read only.
                Can I send you the file so you can check with your program?
                • 5. Re: Unable to Unlock Layers
                  Level 7
                  Sure thing Gary
                  Peter at fasterthanu.com
                  Peter
                  news:g3odbp$qne$1@forums.macromedia.com...
                  | Hi Peter,
                  • 6. Re: Unable to Unlock Layers
                    Hi Peter,
                    I have found out how to unlock the images.
                    1. Open up the image source file in Fireworks CS3
                    2. Then look to the top right of the screen/workarea,
                    3. Click on "Pages" then on layout[Master Page],
                    4. Then select "layers" proceed to unlock the sections you need to work with.
                    Cheers for your suggestions and help
                    Regards
                    Gary
                    • 7. Re: Unable to Unlock Layers
                      Level 7
                      Well done!
                      I wasn't having any luck. Glad you got it sorted.
                      Peter
                      _______________________
                      news:g3old5$6bb$1@forums.macromedia.com...
                      | Hi Peter,
                      with.
                      | Regards
                      | Gary
