• Global community
    • Language:
      • Deutsch
      • English
      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Exit
0
Portrait and Landscape to pdf
New Here ,
Mar 07, 2018 Mar 07, 2018
Hello,
My framemaker 12 document has mostly portrait pages with a few landscape pages  to accommodate large tables. When I save to PDF, the landscape pages get cut off at the same width as the portrait pages so the columns get cut off. How can I get each page to print to pdf in the correct way?
Thanks for any help you can give!
Abby
TOPICS
PDF output
Views
3.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Keep the pages portrait but rotate the content.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 08, 2018 Mar 08, 2018
There are 10 columns in the table, so the information will get too crunched if I try to make it portrait. Thank you for your response!
Votes
Translate
Translate
Report
Report
Community Expert ,
HI Abby:
I have not had that experience:
Fm 2017
Acrobat Pro DC
How did you rotate the pages, and how are you creating the PDF?
~Barb
Votes
Translate
Translate
Report
Report
New Here ,
Hi Barb,
The document was created by someone else with much more FM experience than me so I'm not sure how she rotated them. There are 10 columns so I'd like to keep it as landscape, otherwise the information will get quite crunched.
To create the PDF, I go to File - Save as PDF - select the place to save it - when the PDF Setup window appears, I select View Generated PDF in Acrobat, then click Set.
Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Abby:
Do you have rotated master pages in the file?
~Barb
Votes
Translate
Translate
Report
Report
New Here ,
Hi Barb,
Yes I do.
Abby
Votes
Translate
Translate
Report
Report
Community Expert ,
Ok, Abby, so it must be something in the PDF export. I have used rotated pages in Fm (and output to PDF) for years without issue, so I'm not sure where this is going awry. I just reviewed my Adobe PDF Settings, and it is all set to portrait.
Do you have Acrobat installed, or are you using the PDF conversion utility that comes with FrameMaker?
Are you able to output just the landscape pages correctly?
~Barb
Votes
Translate
Translate
Report
Report
New Here ,
Acrobat is installed on the computer, and I'm able to output just the landscape pages correctly. I've manually added them into the document in the past, but then the hyperlinks to them throughout the document break.
Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
Well, Abby, I'm out of ideas, but the beauty of this forum is that lots of us read these questions and someone may well come along shortly with exactly what you need.
In the meantime, if this were my file, I think I might uninstall/reinstall Adobe Acrobat DC. I've always used the defaults, and it just works. Ohā€”are you using a custom job options file?
As a heads up, you can replace pages in a PDF without breaking the links to those pages. This would be good only until you get this figured out but might be helpful if your deadline is looming.
~Barb
Votes
Translate
Translate
Report
Report
New Here ,
Thank  you very much for your help, Barb!
Now I'm curious - how can I replace the pages without breaking the links?
Votes
Translate
Translate
Report
Report
Community Expert ,
Use Replace Pages instead of deleting the current ones and adding new ones:
  • Convert the landscape pages as their own PDF
  • Open the file with the truncated landscape pages in Adobe Acrobat
  • View > Show/Hide > Navigation Panes > Page Thumbnails
  • Select the page thumbnail(s) of the page(s) you want to replace.
  • Right click over the selected page(s) and choose Replace pages
The links are on a top layer, and this replaces the content layer underneath.
~Barb
Votes
Translate
Translate
Report
Report
Community Expert ,
This sounds like a problem that is specific to your machine. (a setting, or a scrambled connection 'tween Fm and the PDF generation process)
If it's an option to send me the file, I'm happy to process it in Fm12 to see if I get the same result.
-Matt
Votes
Translate
Translate
Report
Report
New Here ,
Hi Matt,
Thanks for your offer of help; unfortunately I can't send you the doc.
Abby
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
No worries,
My plan was to check through the settings in both the Save as PDF workflow, and the Print workflow.
Check out my post at FrameMaker PDF Tips and Tricks - Tech Comm Tools for a comprehensive look at how I produce PDF from Fm.
-Matt
Votes
Translate
Translate
Report
Report
