3 Replies Latest reply on Mar 8, 2018 4:10 AM by astrobutch0901
    Superimpose layers
    gtsolid Level 1
      i found a framework about Turin quarters and i wish to superimpose on a real map image, maybe from google earth,
      How can i scale and allign the scheme to the map? http://www.mole24.it/wp-content/uploads/2012/07/Circoscrizioni_torino.png
      i think i will import both images as separated layers, and then play with transparency. But i don't how to do the remaining part
        • 1. Re: Superimpose layers
          astrobutch0901 Level 2
          When scaling, hold down the shift key to constrain the scale in proportion and move any corner bounding box.
          You can hold down alt+shift to constrain the scaling about the centre point.
          As far as completing the remaining part, I cannot open your link for some reason so not sure exactly what you mean.
          • 2. Re: Superimpose layers
            Ged Traynor Adobe Community Professional
            If you right click on the link and select Open link in New Tab it should work, works for me that way in Firefox
            • 3. Re: Superimpose layers
              Open both your documents in PS. The Map and the overlay.
              There are many ways you can create 2 separate layers but on the overlay you can hit cmd+a(mac) or ctrl+a(pc) and that will select the whole overlay document.
              Copy and paste onto the Map layer and you'll have the two layers, overly on top.
              I would then change the blend mode of the overlay layer to "overlay" as per image belowScreen Shot 2018-03-08 at 12.01.09.jpg
              As per my previous post, transform the overlay layer by hitting cmd+t(mac) or ctrl+t(pc) and scaling to fit the map.
              Flatten the image an save as a JPG
              Hope that helps
