Hey guys,
I'm trying to change the source location of all the psds in my project to the same files located in another directory. Unfortunately, when I try to use FootageItem.replace to do this and I have several footage items that source from the same psd (as different layers from that psd), each of those items just turn into the full psd, rather than staying as the individual layers.
basically, if I import a psd as Editable Layer Styles, it imports each layer in that psd as a separate item. so when I run a custom collect, and use FootageItem.replace to change the source to the new collection directory, it replaces each of those items with the full psd, rather than just that individual layer from that psd.
Hope that makes sense.
Any solutions?
I believe there's no workaround for this via scripting, unfortunately.
Is this a one-time-thing? Or do you need to automate a lot of projects like this?
If it's a one-time thing, what you could do, is temporarily remove or rename source folder on HDD, launch AE project and it will complain about missing items. Now, manually relink one item in the project to new location, and the rest of the mites should follow. Worth a try.
