5 Replies Latest reply on Mar 9, 2018 10:34 PM by dclaarit
    Disable alerts in batch script?
    dclaarit
      How can I stop alerts from stopping my batch script?
      I've found and adapted a script to do batch photomerges on a group photos that might be related. There's only one issue: Some of them aren't, and the photomerge script throws an alert ("Some images could not be aligned") and stops dead until I dismiss the dialog. That's...not automation. I tried to tell it to not display dialogs:
      displayDialogs = DialogModes.NO;
      alert('displayDialogs='+displayDialogs);
      But that just doesn't work. (When you think about it, the second line shouldn't throw the alert telling me the value of displayDialogs, but it does).
      I've tried various incantations:
      app.displayDialogs
      photomerge.displayDialogs
      I've even put the DialogModes.NO into the photomerge script itself, but to no avail.
      I guess I can perform surgery on the photomerge.jsx script itself, but all the documentation says that displayDialogs should work. I'm back on Photoshop CS6.
      I also tried:
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract
      but this appears to be for a different version, as it complains that UserInteractionLevels is undefined.
      I am using python to open the com object and then:
      object.DoJavaScriptFile("/N/Images/panoramas/photomerger.jsx", ["a", "b"])
      photomerger.jsx starts:
      var runphotomergeFromScript = true;
      #include "/C/Program Files/Adobe/Adobe Photoshop CS6 (64 Bit)/Presets/Scripts/Photomerge.jsx"
      photomerge.createPanorama(jpg_list, false);
      I even tried to figure out how to override alert(), but I couldn't get that to work either.
      Any ideas before I hack up the script?
      Thanks!
        • 1. Re: Disable alerts in batch script?
          Kukurykus Adobe Community Professional
          If that is what you're asking for cannot you just comment alert in your script like this (Photoshop CS6 EXTENDED / line 461):
          //alert(localize("$$$/AdobePlugin/Shared/Photomerge/alignbad=Some images could not be automatically aligned"));
          • 2. Re: Disable alerts in batch script?
            r-bin Level 4
            a()
            function a()
                function alert() {}
                /////////// your main code start
                /////////// your main code end
            • 3. Re: Disable alerts in batch script?
              dclaarit Level 1
              Thanks! Yes, my backup plan is to make a copy of the script and go in and rip out all of the alerts...or well, make the error returns that I could catch. But I would prefer to have a generic automation solution.
              • 4. Re: Disable alerts in batch script?
                dclaarit Level 1
                This only works in the outer level: It suppresses the
                alert('foo');
                but the alert in photomerge script still fires.
                So I guess I could modify the photomerge script itself with this: It would be easier than changing all of the alerts themselves!
                (I've tried for literally the last 90 minutes to set my preferences and/or see the thing that let's me paste code, but all I get is some stupid "We could not complete your request. Please check the form for details.", so...my apologies for the ugly post):
                do_merge()
                function do_merge() {
                  function alert() {}
                  alert('foo')
                • 5. Re: Disable alerts in batch script?
                  dclaarit Level 1
                  So in the end, I edited the Adobe script and changed all of the alert() calls to throw(), which I catch and then cleanup the active document. I guess that makes Kukurykus' answer the most correct...
                  Thanks for the help!
