18 Replies Latest reply on Aug 10, 2018 7:59 AM by kanikaa32870678
    AEM 6.3: Getting 403 error on dispatcher and blank page
    AEM newbie Level 1
      I have configured Apache web server and dispatcher. Here are the rewrite rules:
      RewriteRule ^/$ /content/aemsite/en.html [PT,L]
        RewriteCond %{REQUEST_URI} ^/content
        RewriteCond %{REQUEST_URI} !^/content/campaigns
        RewriteCond %{REQUEST_URI} !^/content/dam
        RewriteRule !^/content/aemsite/en - [R=404,L,NC]
        RewriteCond %{REQUEST_URI} !^/apps
        RewriteCond %{REQUEST_URI} !^/etc
        RewriteCond %{REQUEST_URI} !^/home
        RewriteCond %{REQUEST_URI} !^/libs
        RewriteCond %{REQUEST_URI} !^/tmp
        RewriteCond %{REQUEST_URI} !^/var
        RewriteRule ^/(.*)$ /content/aemsite/en/$1 [PT,L]
      I have also configured sling mappings:
        "jcr:primaryType": "sling:Mapping",
        "www_aemsite_com": {
        "sling:internalRedirect": [
        "/content/aemsite/en.html"
        "sling:match": "www.aemsite.com/$"
        "www.aemsite.com": {
        "/content/aemsite/en",
      and I have also configured "Day CQ Link Checker Transformer" to strip HTML extension:
      <?xml version="1.0" encoding="UTF-8"?>
      <jcr:root xmlns:sling="http://sling.apache.org/jcr/sling/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0"
        jcr:primaryType="sling:OsgiConfig"
        linkcheckertransformer.strictExtensionCheck="{Boolean}false"
        linkcheckertransformer.rewriteElements="[a:href,area:href,form:action]"
        linkcheckertransformer.disableRewriting="{Boolean}false"
        linkcheckertransformer.disableChecking="{Boolean}false"
        linkcheckertransformer.stripHtmltExtension="{Boolean}true"
        linkcheckertransformer.mapCacheSize="{Long}5000"/>
      A trailing slash gets appended to the URL. For example, a link that points to http://www.aemsite.com/articles has the "/" appended and  I see a blank page. In the logs I see a 403 on web server level while trying to access the pages under http://www.aemsite.com/ as shown below.
      127.0.0.1 - - [09/Mar/2018:22:26:44 -0500] "GET /articles HTTP/1.1" 302
      127.0.0.1 - - [09/Mar/2018:22:26:44 -0500] "GET /articles/ HTTP/1.1" 403 1
      How can I make sure that http://www.aemsite.com/articles gets redirected to http://www.aemsite.com/articles.html internally?
      Thanks in advance
        • 2. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
          Jörg Hoh Adobe Employee
          for me it looks like that the problem in this case is in the webserver/dispatcher config. Is this request sent to AEM at all? If you enable debug logging on the dispatcher you can see if this request is handled by the dispatcher at all or maybe only by the webserver. And if it's handled by the dispatcher it can show you if the request is sent to AEM.
          Jörg
          • 3. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
            AEM newbie Level 1
            Hi Jörg Hoh thank you for your response. The logs
            are from dispatcher.log and yes the request is not reaching to the publish environment. I have checked the rules under /filter but can't locate if it is due to any rules. Here is the whole dispatcher file:
            # Each farm configures a set of load balanced renders (i.e. remote servers)
            /farms
              # First farm entry
              /wwwaemsitecom
                # Request headers that should be forwarded to the remote server.
                /clientheaders
                  # Forward all request headers that are end-to-end. If you want
                  # to forward a specific set of headers, you'll have to list
                  # them here.
                # Hostname globbing for farm selection (virtual domain addressing)
                /virtualhosts
                  # Entries will be compared against the "Host" request header
                  # and an optional request URL prefix.
                  # Examples:
                  #   "www.aemsite.com"
                  #   intranet.*
                  #   myhost:8888/mysite
                # The load will be balanced among these render instances
                /renders
                  /rend01
                    # Hostname or IP of the render
                    /hostname "127.0.0.1"
                    # Port of the render
                    /port "4503"
                    # Connect timeout in milliseconds, 0 to wait indefinitely
                    # /timeout "0"
                # The filter section defines the requests that should be handled by the dispatcher.
                # Entries can be either specified using globs, or elements of the request line:
                # (1) globs will be compared against the entire request line, e.g.:
                #       /0001 { /type "deny" /glob "* /index.html *" }
                #     denies request "GET /index.html HTTP/1.1" but not "GET /index.html?a=b HTTP/1.1".
                # (2) method/url/query/protocol/path/selectors/extension/suffix will be compared
                #     against the respective elements of  the request line, e.g.:
                #       /0001 { /type "deny" /method "GET" /url "/index.html" }
                #     denies both "GET /index.html" and "GET /index.html?a=b HTTP/1.1".
                # (3) all elements of the request line can also be specified as regular expressions,
                #     which are identified by using single quotes, e.g.
                #       /0001 { /type "allow" /method '(GET|HEAD)' }
                #     allows GET or HEAD requests, or:
                #       /0002 { /type "deny" /extension '()' }
                #     denies requests having no extension.
                # Note: specifying elements of the request line is the preferred method.
                /filter
                  # Deny everything first and then allow specific entries
                  /0001 { /type "deny" /glob "*" }
                  # Open consoles
            #     /0011 { /type "allow" /url "/admin/*"  }  # allow servlet engine admin
            #     /0012 { /type "allow" /url "/crx/*"    }  # allow content repository
            #     /0013 { /type "allow" /url "/system/*" }  # allow OSGi console
              /0014 { /type "allow" /glob "* /*" }  # allowing /
                  # Allow non-public content directories
            #     /0021 { /type "allow" /url "/apps/*"   }  # allow apps access
            #     /0022 { /type "allow" /url "/bin/*"    }
            #     /0023 { /type "allow" /url "/content*" }  # disable this rule to allow mapped content only
            #     /0024 { /type "allow" /url "/libs/*"   }
            #     /0025 { /type "deny"  /url "/libs/shindig/proxy*" } # if you enable /libs close access to proxy
            #     /0026 { /type "allow" /url "/home/*"   }
            #     /0027 { /type "allow" /url "/tmp/*"    }
            #     /0028 { /type "allow" /url "/var/*"    }
              /0029 { /type "deny" /url "/etc/"    }
              /0030 { /type "allow" /url "/etc.clientlibs/*"    }
              /0031 { /type "allow" /url "/content/*" }
              /0032 { /type "allow" /url "/etc/designs/*" }
              /0033 { /type "allow" /url "/etc/clientlibs/*" }
              /0034 { /type "allow" /path "/libs/granite/csrf/token"  /extension '(json)' }
                  # Enable extensions in non-public content directories, using a regular expression
                  /0041
                    /type "allow"
                    /extension '(css|gif|ico|js|png|swf|jpe?g)'
                  # Enable features
                  /0062 { /type "allow" /url "/libs/cq/personalization/*"  }  # enable personalization
                  # Deny content grabbing, on all accessible pages, using regular expressions
                  /0081
                    /type "deny"
                    /selectors '((sys|doc)view|query|[0-9-]+)'
                    /extension '(json|xml)'
                  # Deny content grabbing for /content
                  /0082
                    /type "deny"
                    /path "/content"
                    /selectors '(feed|rss|pages|languages|blueprint|infinity|tidy)'
                    /extension '(json|xml|html)'
            /0083 { /type "deny"  /glob "GET *.sysview.xml*"   }
                  /0084 { /type "deny"  /glob "GET *.docview.json*"  }
                  /0085 { /type "deny"  /glob "GET *.docview.xml*"  }
                  /0086 { /type "deny"  /glob "GET *.*[0-9].json*" }
            #     /0087 { /type "allow" /method "GET" /extension 'json' "*.1.json" }  # allow one-level json requests
                # The cache section regulates what responses will be cached and where.
                /cache
                  # The docroot must be equal to the document root of the webserver. The
                  # dispatcher will store files relative to this directory and subsequent
                  # requests may be "declined" by the dispatcher, allowing the webserver
                  # to deliver them just like static files.
                  /docroot "C:/Apache2.2/htdocs"
                  # Sets the level upto which files named ".stat" will be created in the
                  # document root of the webserver. When an activation request for some
                  # page is received, only files within the same subtree are affected
                  # by the invalidation.
                  /statfileslevel "2"
                  # Flag indicating whether to cache responses to requests that contain
                  # authorization information.
                  /allowAuthorized "0"
                  # Flag indicating whether the dispatcher should serve stale content if
                  # no remote server is available.
                  /serveStaleOnError "1"
                  # The rules section defines what responses should be cached based on
                  # the requested URL. Please note that only the following requests can
                  # lead to cacheable responses:
                  # - HTTP method is GET
                  # - URL has an extension
                  # - Request has no query string
                  # - Request has no "Authorization" header (unless allowAuthorized is 1)
                  /rules
                    /0000
                      # the globbing pattern to be compared against the url
                      # example: *             -> everything
                      #        : /foo/bar.*    -> only the /foo/bar documents
                      #        : /foo/bar/*    -> all pages below /foo/bar
                      #        : /foo/bar[./]* -> all pages below and /foo/bar itself
                      #        : *.html        -> all .html files
                      /glob "*"
                      /type "allow"
                  # The invalidate section defines the pages that are "invalidated" after
                  # any activation. Please note that the activated page itself and all
                  # related documents are flushed on an modification. For example: if the
                  # page /foo/bar is activated, all /foo/bar.* files are removed from the
                  # cache.
                  /invalidate
                    /0000
                      /glob "*"
                      /type "deny"
                    /0001
                      # Consider all HTML files stale after an activation.
                      /glob "*.html"
                      /type "allow"
                    /0002
                      /glob "/etc/segmentation.segment.js"
                      /type "allow"
                    /0003
                      /glob "*/analytics.sitecatalyst.js"
                      /type "allow"
                  # The allowedClients section restricts the client IP addresses that are
                  # allowed to issue activation requests.
                  /allowedClients
                    # Uncomment the following to restrict activation requests to originate
                    # from "localhost" only.
                    #/0000
                    #  /glob "*"
                    #  /type "deny"
                    #/0001
                    #  /glob "127.0.0.1"
                    #  /type "allow"
                  # The ignoreUrlParams section contains query string parameter names that
                  # should be ignored when determining whether some request's output can be
                  # cached or delivered from cache.
                  # In this example configuration, the "q" parameter will be ignored.
                  #/ignoreUrlParams
                  #  /0001 { /glob "*" /type "deny" }
                  #  /0002 { /glob "q" /type "allow" }
                  # Cache response headers next to a cached file. On the first request to
                  # an uncached resource, all headers matching one of the values found here
                  # are stored in a separate file, next to the cache file. On subsequent
                  # requests to the cached resource, the stored headers are added to the
                  # response.
                  # Note, that file globbing characters are not allowed here.
                  #/headers
                  #  "Cache-Control"
                  #  "Content-Disposition"
                  #  "Content-Type"
                  #  "Expires"
                  #  "Last-Modified"
                  #  "X-Content-Type-Options"
                  # A grace period defines the number of seconds a stale, auto-invalidated
                  # resource may still be served from the cache after the last activation
                  # occurring. Auto-invalidated resources are invalidated by any activation,
                  # when their path matches the /invalidate section above. This setting
                  # can be used in a setup, where a batch of activations would otherwise
                  # repeatedly invalidate the entire cache.
                  #/gracePeriod "2"
                  # Enable TTL evaluates the response headers from the backend, and if they
                  # contain a Cache-Control max-age or Expires date, an auxiliary, empty file
                  # next to the cache file is created, with modification time equal to the
                  # expiry date. When the cache file is requested past the modification time
                  # it is automatically re-requested from the backend.
                  # /enableTTL "1"
                # The statistics sections dictates how the load should be balanced among the
                # renders according to the media-type.
                /statistics
                  /categories
                    /html
                      /glob "*.html"
                    /others
                      /glob "*"
                # Authorization checker: before a page in the cache is delivered, a HEAD
                # request is sent to the URL specified in /url with the query string
                # '?uri='. If the response status is 200 (OK), the page is returned
                # from the cache. Otherwise, the request is forwarded to the render and
                # its response returned.
                # Only pages matching the /filter section below are checked, all other pages
                # get delivered unchecked.
                # All header lines returned from the auth_checker's HEAD request that match
                # the /headers section will be returned as well.
                #/auth_checker
                #  /url "/bin/permissioncheck.html"
                #  /filter
                #    /0000
                #      /glob "*"
                #      /type "deny"
                #    /0001
                #      /glob "*.html"
                #      /type "allow"
                #  /headers
                #    /0000
                #      /glob "*"
                #      /type "deny"
                #    /0001
                #      /glob "Set-Cookie:*"
                #      /type "allow"
            In httpd.conf I am also using DirectorySlash Off under virtual hosts configuration but the / is still getting appended to all the URL under http://www.aemsite.com. I don't know what configuration under dispatcher or httpd.conf is responsible for the behavior.
            • 4. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
              If the dispatcher denies access to that URL, you should be able to see that when you enable DEBUG logging for the dispatcher. That's the first thing you should validate. Also observe the Apache error.log
              regards,
              Jörg
              • 5. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                AEM newbie Level 1
                I have the debug enabled for dispatcher and these are the logs from dispatcher.log
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] response.headers[Date] = "Wed, 14 Mar 2018 01:57:19 GMT"
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] response.headers[X-Content-Type-Options] = "nosniff"
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] response.headers[Location] = "http://www.aemsite.com/articles/"
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] response.headers[Content-Length] = "0"
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Storing socket for later reuse: 127.0.0.1:4503
                [Tue Mar 13 21:57:19 2018] [I] [pid 7048 (tid 1184)] "GET /articles" 302 - 43ms [wwwaemsitecom/rend01]
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Found farm wwwaemsitecom for www.aemsite.com
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] checking [/articles/]
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] request URL has no extension: /articles/
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] cache-action for [/articles/]: NONE
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Reusing socket: 127.0.0.1:4503
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Connected to backend rend01 (127.0.0.1:4503)
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: Host
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: User-Agent
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: Accept
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: Accept-Language
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: Accept-Encoding
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: Referer
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: Upgrade-Insecure-Requests
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: Via
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: X-Forwarded-For
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] Adding request header: Server-Agent
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] response.status = 403
                [Tue Mar 13 21:57:19 2018] [D] [pid 7048 (tid 1184)] response.headers[Content-Type] = "text/html; charset=ISO-8859-1"
                [Tue Mar 13 21:57:19 2018] [I] [pid 7048 (tid 1184)] "GET /articles/" 403 1 78ms [wwwaemsitecom/rend01]
                • 6. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                  the dispatcher forwards the request to "/articles/" to AEM, which then responds with this 403; to investigate there further, you should have a look at the details of this request in the "Recent Requests console" (part of the OSGI webconsole) of the AEM publish instance.
                  On the other hand I don't know which causes the initial redirect from "/articles" to "/articles/". I would assume that this is some kind of apache rule, but it does not append any extension to it, which I would assume. So you should add a rewrite rule, which adds an ".html" extension if no extension is present. And only then forward the request to the dispatcher/AEM.
                  Jörg
                  • 7. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                    AEM newbie Level 1
                    I am using the LinkCheckerTransformerFactory to strip off the .html extension. I want to map the /articles to articles.html without actually changing the URL. I have checked the Recent Request Console and here are the logs:
                    0 TIMER_START{Request Processing}
                      1 COMMENT timer_end format is {<elapsed microseconds>,<timer name>} <optional message>
                      7 LOG Method=GET, PathInfo=null
                      11 TIMER_START{handleSecurity}
                      3586 TIMER_END{3573,handleSecurity} authenticator org.apache.sling.auth.core.impl.SlingAuthenticator@6f5ad765 returns true
                      3938 TIMER_START{ResourceResolution}
                      8125 TIMER_END{4184,ResourceResolution} URI=/articles/ resolves to Resource=JcrNodeResource, type=cq:Page, superType=null, path=/content/aemsite/en/articles
                      8132 LOG Resource Path Info: SlingRequestPathInfo: path='/content/aemsite/en/articles', selectorString='null', extension='null', suffix='/'
                      8132 TIMER_START{ServletResolution}
                      8136 TIMER_START{resolveServlet(/content/aemsite/en/articles)}
                      8213 TIMER_END{76,resolveServlet(/content/aemsite/en/articles)} Using servlet org.apache.sling.servlets.get.DefaultGetServlet
                      8227 TIMER_END{94,ServletResolution} URI=/articles/ handled by Servlet=org.apache.sling.servlets.get.DefaultGetServlet
                      8234 LOG Applying Requestfilters
                      8237 LOG Calling filter: com.adobe.granite.resourceresolverhelper.impl.ResourceResolverHelperImpl
                      8245 LOG Calling filter: org.apache.sling.i18n.impl.I18NFilter
                      8248 LOG Calling filter: com.adobe.granite.httpcache.impl.InnerCacheFilter
                      8255 LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter
                      8259 LOG Calling filter: com.adobe.cq.mcm.campaign.servlets.CampaignCopyTracker
                      8261 LOG Calling filter: com.day.cq.wcm.core.impl.WCMRequestFilter
                      8266 LOG Calling filter: com.adobe.fd.core.security.internal.CurrentUserServiceImpl
                      9157 LOG Calling filter: com.adobe.cq.wcm.core.components.internal.servlets.CoreFormHandlingServlet
                      9162 LOG Calling filter: com.adobe.granite.optout.impl.OptOutFilter
                      9185 LOG Calling filter: com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet
                      9188 LOG Calling filter: com.adobe.cq.social.commons.cors.CORSAuthenticationFilter
                      9195 LOG Calling filter: com.adobe.livecycle.dsc.clientsdk.internal.ResourceResolverHolderFilter
                      9206 LOG Calling filter: org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter
                      9212 LOG Calling filter: com.adobe.livecycle.content.appcontext.impl.AppContextFilter
                      9218 LOG Calling filter: org.apache.sling.dynamicinclude.CacheControlFilter
                      9225 LOG Calling filter: com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter
                      9239 LOG Calling filter: com.day.cq.wcm.core.impl.AuthoringUIModeServiceImpl
                      9243 LOG Calling filter: org.apache.sling.security.impl.ContentDispositionFilter
                      9245 LOG Calling filter: com.adobe.granite.csrf.impl.CSRFFilter
                      9248 LOG Calling filter: com.adobe.granite.rest.assets.impl.AssetContentDispositionFilter
                      9253 LOG Calling filter: com.adobe.granite.requests.logging.impl.RequestLoggerImpl
                      9257 LOG Calling filter: com.adobe.granite.rest.impl.servlet.ApiResourceFilter
                      9264 LOG Calling filter: com.day.cq.dam.core.impl.assetlinkshare.AdhocAssetShareAuthHandler
                      9266 LOG Calling filter: com.adobe.cq.social.ugcbase.security.impl.SaferSlingPostServlet
                      9268 LOG Calling filter: com.day.cq.dam.core.impl.servlet.ActivityRecordHandler
                      9281 LOG Calling filter: org.apache.sling.dynamicinclude.SyntheticResourceFilter
                      9288 LOG Applying Componentfilters
                      9289 LOG Calling filter: com.day.cq.personalization.impl.TargetComponentFilter
                      9291 LOG Calling filter: com.day.cq.wcm.core.impl.WCMComponentFilter
                      9735 LOG Calling filter: com.day.cq.wcm.core.impl.WCMDebugFilter
                      9755 TIMER_START{org.apache.sling.servlets.get.DefaultGetServlet#0}
                      9767 LOG Using org.apache.sling.servlets.get.impl.helpers.StreamRendererServlet to render for extension=null
                      10085 LOG Applying Error filters
                      10087 LOG Calling filter: org.apache.sling.i18n.impl.I18NFilter
                      10088 LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter
                      10141 TIMER_START{handleError:status=403}
                      26833 TIMER_END{16689,handleError:status=403} Using handler /apps/sling/servlet/errorhandler/default.jsp
                      54132 LOG Found processor for post processing ProcessorConfiguration: {contentTypes=[text/html], order=-1, active=true, valid=true, processErrorResponse=true, pipeline=(generator=Config(type=htmlparser, config=JcrPropertyMap [node=Node[NodeDelegate{tree=/apps/aemsite-project/config/rewriter/default/generator-html parser: { jcr:primaryType = nt:unstructured, includeTags = [A, /A, IMG, AREA, FORM, BASE, LINK, SCRIPT, BODY, /BODY]}}], values={jcr:primaryType=nt:unstructured, includeTags=[Ljava.lang.String;@4764b191}]), transformers=(Config(type=linkchecker, config={}), Config(type=mobile, config=JcrPropertyMap [node=Node[NodeDelegate{tree=/apps/aemsite-project/config/rewriter/default/transformer-mo bile: { jcr:primaryType = nt:unstructured, component-optional = true}}], values={jcr:primaryType=nt:unstructured, component-optional=true}]), Config(type=mobiledebug, config=JcrPropertyMap [node=Node[NodeDelegate{tree=/apps/aemsite-project/config/rewriter/default/transformer-mo biledebug: { jcr:primaryType = nt:unstructured, component-optional = true}}], values={jcr:primaryType=nt:unstructured, component-optional=true}]), Config(type=contentsync, config=JcrPropertyMap [node=Node[NodeDelegate{tree=/apps/aemsite-project/config/rewriter/default/transformer-co ntentsync: { jcr:primaryType = nt:unstructured, component-optional = true}}], values={jcr:primaryType=nt:unstructured, component-optional=true}]), Config(type=versioned-clientlibs, config={}), serializer=Config(type=htmlwriter, config={}))}
                      54597 TIMER_END{44455,handleError:status=403} Error handler finished
                      54753 LOG Filter timing: filter=org.apache.sling.rewriter.impl.RewriterFilter, inner=45, total=45, outer=0
                      54760 TIMER_END{45004,org.apache.sling.servlets.get.DefaultGetServlet#0}
                      54768 LOG Filter timing: filter=com.day.cq.wcm.core.impl.WCMDebugFilter, inner=45, total=45, outer=0
                      54770 LOG Filter timing: filter=com.day.cq.wcm.core.impl.WCMComponentFilter, inner=45, total=45, outer=0
                      54784 TIMER_END{54783,Request Processing} Request Processing
                      55493 LOG Filter timing: filter=org.apache.sling.dynamicinclude.SyntheticResourceFilter, inner=45, total=45, outer=0
                      55496 LOG Filter timing: filter=com.day.cq.dam.core.impl.servlet.ActivityRecordHandler, inner=45, total=45, outer=0
                      55499 LOG Filter timing: filter=com.adobe.cq.dam.webdav.impl.io.DamWebdavRequestFilter, inner=45, total=45, outer=0
                      55502 LOG Filter timing: filter=com.adobe.cq.social.ugcbase.security.impl.SaferSlingPostServlet, inner=45, total=45, outer=0
                      55505 LOG Filter timing: filter=com.day.cq.dam.core.impl.assetlinkshare.AdhocAssetShareAuthHandler, inner=45, total=45, outer=0
                      55508 LOG Filter timing: filter=com.day.cq.dam.core.impl.servlet.DamContentDispositionFilter, inner=45, total=45, outer=0
                      55511 LOG Filter timing: filter=com.adobe.granite.rest.impl.servlet.ApiResourceFilter, inner=45, total=45, outer=0
                      55513 LOG Filter timing: filter=com.adobe.granite.requests.logging.impl.RequestLoggerImpl, inner=45, total=45, outer=0
                      55517 LOG Filter timing: filter=com.adobe.granite.rest.assets.impl.AssetContentDispositionFilter, inner=45, total=45, outer=0
                      55520 LOG Filter timing: filter=com.adobe.granite.csrf.impl.CSRFFilter, inner=45, total=45, outer=0
                      55523 LOG Filter timing: filter=org.apache.sling.security.impl.ContentDispositionFilter, inner=45, total=45, outer=0
                      55526 LOG Filter timing: filter=com.day.cq.wcm.core.impl.AuthoringUIModeServiceImpl, inner=45, total=45, outer=0
                      55529 LOG Filter timing: filter=com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter, inner=45, total=45, outer=0
                      55532 LOG Filter timing: filter=org.apache.sling.dynamicinclude.CacheControlFilter, inner=45, total=45, outer=0
                      55535 LOG Filter timing: filter=com.adobe.livecycle.content.appcontext.impl.AppContextFilter, inner=45, total=45, outer=0
                      55538 LOG Filter timing: filter=org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter, inner=45, total=46, outer=1
                      55540 LOG Filter timing: filter=com.adobe.livecycle.dsc.clientsdk.internal.ResourceResolverHolderFilter, inner=46, total=46, outer=0
                      55543 LOG Filter timing: filter=com.adobe.cq.social.commons.cors.CORSAuthenticationFilter, inner=46, total=46, outer=0
                      55546 LOG Filter timing: filter=com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet, inner=46, total=46, outer=0
                      55549 LOG Filter timing: filter=com.adobe.granite.optout.impl.OptOutFilter, inner=46, total=46, outer=0
                      55553 LOG Filter timing: filter=com.adobe.cq.wcm.core.components.internal.servlets.CoreFormHandlingServlet, inner=46, total=46, outer=0
                      55556 LOG Filter timing: filter=com.adobe.fd.core.security.internal.CurrentUserServiceImpl, inner=46, total=47, outer=1
                      55558 LOG Filter timing: filter=com.day.cq.wcm.core.impl.WCMRequestFilter, inner=47, total=47, outer=0
                      55562 LOG Filter timing: filter=com.adobe.cq.mcm.campaign.servlets.CampaignCopyTracker, inner=47, total=47, outer=0
                      55580 LOG Filter timing: filter=org.apache.sling.rewriter.impl.RewriterFilter, inner=47, total=47, outer=0
                      55583 LOG Filter timing: filter=com.adobe.granite.httpcache.impl.InnerCacheFilter, inner=47, total=47, outer=0
                      55586 LOG Filter timing: filter=org.apache.sling.i18n.impl.I18NFilter, inner=47, total=47, outer=0
                      55590 LOG Filter timing: filter=org.apache.sling.distribution.servlet.DistributionAgentCreationFilter, inner=47, total=47, outer=0
                    From the logs it looks like the /articles/ is being resolved to path=/content/aemsite/en/articles but still throwing a 403 error.
                    Thank you so much for having patience to look into this issue.
                    • 8. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                      That means that it does not start the resource resolution process to find out the correct script/component to handle it.  When you request http://${hostname}/content/aemsite/en/articles.html this section will look differently.
                      The problem is in your case that the ".html" extension is missing; you need to extend the rewrites on the dispatcher to append the extension "html" as well if no other extension is available.
                        RewriteCond %{REQUEST_URI} !.html$
                        RewriteRule ^/(.*)$ /content/aemsite/en/$1.html [PT,L]
                      (I modified the last 2 lines)
                      Jörg
                      • 9. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                        AEM newbie Level 1
                        Hi Jörg,
                        I added the new rules to the httpd.conf but it somehow still adds the trailing slash.
                        • 10. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                          Then you need to enable the logging for mod_rewrite and find out which rule introduces the trailing slash.
                          Jörg
                          • 11. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                            AEM newbie Level 1
                            The logging was already enabled for mod_rewrite but it was somehow not able to log anything. I fixed that issue and put the rules you had provided in place. What happening was that /articles/  would get converted to /articles/.html due to the /articles being turned to /articles/. So, I modified the rules a bit :
                            # Define virtual host for aemsite.com
                            <VirtualHost *:80>
                              ServerAdmin webmaster@localhost
                              ServerName aemsite.com
                              DocumentRoot "C:\Apache2.2\htdocs"
                              DirectorySlash Off
                               RewriteEngine On
                               RewriteLog "C:\Apache2.2\logs\rewrite.log"
                               RewriteLogLevel 9
                               RewriteCond %{REQUEST_URI} !(.*)/$
                            </VirtualHost>
                            (The last two lines), thinking that the request /products would be rewritten to  /content/aemsite/en/$1.html
                            Here is the complete log from rewrite.log:
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (2) init rewrite engine with requested uri /products
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (3) applying pattern '^/$' to uri '/products'
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (3) applying pattern '^/(.*)$' to uri '/products'
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (4) RewriteCond: input='/products' pattern='!^/apps' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (4) RewriteCond: input='/products' pattern='!^/content' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (4) RewriteCond: input='/products' pattern='!^/etc' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (4) RewriteCond: input='/products' pattern='!^/home' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (4) RewriteCond: input='/products' pattern='!^/libs' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (4) RewriteCond: input='/products' pattern='!^/tmp' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (4) RewriteCond: input='/products' pattern='!^/var' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (4) RewriteCond: input='/products' pattern='!(.*)/$' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (2) rewrite '/products' -> '/content/aemsite/en/products.html'
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353f0f8/initial] (2) forcing '/content/aemsite/en/products.html' to get passed through to next API URI-to-filename handler
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (2) init rewrite engine with requested uri /products/
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (3) applying pattern '^/$' to uri '/products/'
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (3) applying pattern '^/(.*)$' to uri '/products/'
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (4) RewriteCond: input='/products/' pattern='!^/apps' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (4) RewriteCond: input='/products/' pattern='!^/content' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (4) RewriteCond: input='/products/' pattern='!^/etc' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (4) RewriteCond: input='/products/' pattern='!^/home' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (4) RewriteCond: input='/products/' pattern='!^/libs' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (4) RewriteCond: input='/products/' pattern='!^/tmp' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (4) RewriteCond: input='/products/' pattern='!^/var' => matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (4) RewriteCond: input='/products/' pattern='!(.*)/$' => not-matched
                            127.0.0.1 - - [16/Mar/2018:23:52:08 --0400] [aemsite.com/sid#304ab50][rid#353b0e8/initial] (1) pass through /products/
                            It looks like there are two requests /products and /products/, the rule works fine as long as it is /products but once it is /products/ it fails. I checked the network tab in the browser to check the requests and below is the screenshot:
                            I don't know what exactly is the reason behind the /products/
                            Thank you again for all the help and effort.
                            • 12. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                              Strange. In your first log we see a rewrite from /products to /content/aemsite/en/products.html, but in the request view we also see a request to /products, which results in a redirect to /products/.
                              Have you made the changes on all dispatcher instances of the environment you were testing with?
                              Jörg
                              • 13. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                                AEM newbie Level 1
                                I am using only one dispatcher. Are there any other logs I need to check ?
                                • 14. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                                  This rule prevents /products/ from being rewritten:
                                  But I cannot a clean picture from it.
                                  1) Your screenshot of the browser suggests that /products is redirected to /products/
                                  2) You posted a log extract, which shows that /products is being rewritten to /content/aemsite/en/products.html
                                  3) You posted a log extract, which indicates, that /products/ cannot be handled.
                                  So 1 and 2 contradict. And 3 supports the behaviour you are analyzing.
                                  Can you validate and confirm my 3 statements here?
                                  Jörg
                                  • 15. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                                    AEM newbie Level 1
                                    The problem is even if I comment out all the rules the /products still somehow gets converted to /products/
                                    1) Your screenshot of the browser suggests that /products is redirected to /products/ That is correct
                                    I have been trying a lot of rules to make it work. The log extract must have been due to that. Sorry for the confusion, the current set of rules look like this:
                                    this is the log extract:
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (2) init rewrite engine with requested uri /products
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (3) applying pattern '^/$' to uri '/products'
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (3) applying pattern '^/(.*)$' to uri '/products'
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (4) RewriteCond: input='/products' pattern='!^/apps' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (4) RewriteCond: input='/products' pattern='!^/content' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (4) RewriteCond: input='/products' pattern='!^/etc' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (4) RewriteCond: input='/products' pattern='!^/home' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (4) RewriteCond: input='/products' pattern='!^/libs' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (4) RewriteCond: input='/products' pattern='!^/tmp' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (4) RewriteCond: input='/products' pattern='!^/var' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (2) rewrite '/products' -> '/content/aemsite/en/products'
                                    127.0.0.1 - - [19/Mar/2018:21:23:42 --0400] [aemsite.com/sid#356c590][rid#36080c8/initial] (2) forcing '/content/aemsite/en/products' to get passed through to next API URI-to-filename handler
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (2) init rewrite engine with requested uri /products/
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (3) applying pattern '^/$' to uri '/products/'
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (3) applying pattern '^/(.*)$' to uri '/products/'
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (4) RewriteCond: input='/products/' pattern='!^/apps' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (4) RewriteCond: input='/products/' pattern='!^/content' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (4) RewriteCond: input='/products/' pattern='!^/etc' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (4) RewriteCond: input='/products/' pattern='!^/home' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (4) RewriteCond: input='/products/' pattern='!^/libs' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (4) RewriteCond: input='/products/' pattern='!^/tmp' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (4) RewriteCond: input='/products/' pattern='!^/var' => matched
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (2) rewrite '/products/' -> '/content/aemsite/en/products/'
                                    127.0.0.1 - - [19/Mar/2018:21:23:43 --0400] [aemsite.com/sid#356c590][rid#3592190/initial] (2) forcing '/content/aemsite/en/products/' to get passed through to next API URI-to-filename handler
                                    I am unable to locate why /products is being rewritten to /products/
                                    I think that's the reason behind this whole issue. Please correct me if I am wrong.
                                    • 16. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                                      I see this
                                      and this
                                      But I don't know if these 2 lines belong to the same request at all... sid# and rid# are identical, but the parameters don't look the same.
                                      Sorry, I am out of ideas atm.
                                      Jörg
                                      • 17. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                                        AEM newbie Level 1
                                        The request to /product gets rewritten to /products/.
                                        I can understand, I am out of ideas too. I tried everything. debugging the virtual hots configuration to dispatcher but nothing seems to resolve this issue.
                                        Thank you for looking into this issue and apologies for it took a lot of your time.
                                        • 18. Re: AEM 6.3: Getting 403 error on dispatcher and blank page
                                          kanikaa32870678 Level 1
                                          Use DirectorSlash Off to configure mod_dir not to append /.
                                          Regards
                                          Kanika
