3 Replies Latest reply on Mar 11, 2018 11:29 AM by norman.sanders
    How to darken pre existing text?
    margieannejulie Level 1
      Hi, I need to darken pale text that I did NOT  type, most reasonable way seems to darken with hue saturation, but how do I select it? it seem that I have to make a
      layer mask, how do I do that? thanks
        • 1. Re: How to darken pre existing text?
          norman.sanders Adobe Community Professional & MVP
          If you are referring to losing the Shutterstock copyright line, the Patch tool or one of the Healing brush tools could work well, but it would be prudent to consider its legality.
          • 2. Re: How to darken pre existing text?
            Hi Norman, Legality taken care of 3 years ago: SS's licencees quite often wouldn't give proper credit attribution to the photographer, sued SS,  lost regular pocket money, and my images are no longer all over the place, albeit at least no longer creditfree. As for me being me, yes it's me darkening my own name: (here with Getty) Dona Bozzi Immagini e foto | Getty Images
            Legality taken care of, - SS wouldn't sue me for darkening my own credit just for the sake of not having to deal with me anymore -
            healing tool replicates and patch, a selection tool, was probably not a good idea to select text. I was saved by the "magnifier", selected the area and curved, looks good That wouldn't be possible without the circle. It would be worth to try the spot healing brush, but "doesn't stay", I should read an article, but for now, why the effect doesn't stay?
            • 3. Re: How to darken pre existing text?
              By writing that the Spot Healing.correction "doesn't stay" I assume you mean that it doesn't display the correction.  I have never experienced that. The cause may be the Mode setting in the Options bar or something more involved.
              Luckily, with Photoshop there is usually more than one way to solve a problem. We didn't even try the Clone tool, a technique that uses the History brush set to Darken or some other strategy. You're happy with the result you achieved and that is what counts. Now you can track down the odd Spot Healing result at your leisure.
