2 Replies Latest reply on Mar 11, 2018 5:32 PM by Rick Gerard
    24bit at 44.1khz Audio
    swietliki
      Hi there,
      I'm making a music video. The audio file ist 24bit at 44.1khz. The usual rates are, however, 16bit at 44.1khz (=lower quality because of less bit depth) and  24bit at 48khz (higher quality).
      Am I good to go with choosing 48khz in my project settings (even though the audio file is 44.1khz) in order to maintain the 24bit depth? Will this have any effect on the actual audio (which I won't import from with my compositions) during the editing  process in Premiere Pro later on?
      Wisdom :
      "If 16 bit at 44k1 (CD) is like being given 65,000 pounds/dollars a year. Then 16 bit at 88k is like being given 65,000 twice a year. However, 24 bit at 44k1 is like being given 16,000,000 a year."
      Thank you.
        • 1. Re: 24bit at 44.1khz Audio
          What does this have to do with anything? Audio in AE is a crutch, a utility, an auxiliary thing. Of course you can obsess about the minutia of audio sample rates and bith depth all day, but it won't do anything. If at all it's only relevant for the realtime playback because naturally you will want to avoid lag and buffer delays due to realtime resampling. Everything beyond that is utterly moot.
          Mylenium
          • 2. Re: 24bit at 44.1khz Audio
            video standard for production is 48 kHz 16-bit minimum. 44.1 is a consumer standard and should not be used for anything other than consumer delivery.
            Unless you have specific delivery specifications you should not see the word Custom in your composition settings or your render settings. Let AE manage the audio.
            If it were me I would either ask for a 48 kHz master that was 16bit or better and do any audio manipulation needed with that, or I would do the audio manipulation in Audition using its native 32-bit audio processing and render a 48 kHz 16 or 14 bit master to use for rendering.
            AE will handle almost any audio in the timeline but sometimes you will run into rendering or mixing problems if you use Mp3 or other highly compressed audio. OTT, as Muylenium said, you are making a big fuss about something that does not matter. What does matter is that you do not customize your comp or render settings unless you have studied enough to be confident in your decision to mess with the standards and you are willing to suffer the consequences of ren rendering a product that will not playback or perform as expected.
