OCR of combined text and objects (electrocardiogram tracings) leads to recognition of portions of object as text, and distorts/fragments the image. Some tracings are faxed with moire distortion that may partly explain this. I can't find a way to selectively do OCR on the text portion.
Hi John,
As Lovekesh stated, you cannot do selective OCR on a document within Acrobat at this point in time. The only option I'm aware of is to let Acrobat OCR the entire document (or page) and selectively pull out what you need/want.
But also, I gather that the document you are working with is a fax? If so, that's a poor place to start an OCR from. That's not to say that you can't OCR a faxed document but rather you are going to have more errors in the text than if the document was a clean page.
...Copy link to clipboard
There is no way as of now to do selective OCR. We will raise your concern as a feature request and inform you if there is any update.
Thanks.
Hi John,
But also, I gather that the document you are working with is a fax? If so, that's a poor place to start an OCR from. That's not to say that you can't OCR a faxed document but rather you are going to have more errors in the text than if the document was a clean page. Consider the letter combination "rr," the less quality the original document, the more likely that will be interpreted as "n." Is there any chance you can get a cleaner, non-faxed, document?
