Hello everyone,
I've built a Windows 10 Enterprise v1709 image for my labs and offices and have run into an issue with the Acrobat Reader extension for Google Chrome. After the extension has been installed, on the next launch of Chrome, a new tab will automatically appear and open the page at https://helpx.adobe.com/acrobat/kb/acrobat-reader-chrome-extension.html. Since this is installed as part of an image, this page is appearing for all new users who log in and launch Chrome.
This is a controlled environment and we require all web browsers to open a company webpage by default for all users. I've configured this default page on the local installs and through Group Policy using the Chrome .admx templates, but the helpx.adobe.com Tab continues to appear. I can block the URL in GPO, but the Tab will still open, it just says the page is blocked.
What I would like to do is prevent this new tab from ever opening. I've searched through the windows registry and file system to try and find where this is coming from but with no luck. I'm running out of ideas and removing the extension appears to be my only option. Does anyone know how to prevent this tab from from automatically opening in chrome?
There is no longer an Acrobat Reader extension for Chrome, so far as I can see. Google blocked it. There is an Acrobat extension for Chrome, which requires Acrobat.
So, if your users have only the free Acrobat Reader, rather than paid Acrobat, this may be of no use to them. I suggest you check if it offers functionality your users need. At one time it was essential, but times have changed.
Additionally, I had configured the Reader Extension options in Chrome to disable the option to "Allow Adobe Acrobat for Chrome to send anonymous usage information to Adobe for product improvement purposes". This is turning itself back on for all new users who log into the system. How can I permanently disable this for all users?
did you figure this out?
[Question moved to the Enterprise Deployment (Acrobat and Reader) forum]
I've found the solution to be in the chrome extension.
(I'm trying to translate from a dutch version of chrome)
1 Got to: chrome://extensions/
2 Go to "Details" of the adobe extension.
3 Here you see an setting called "Views".
4 Here you see a link called: "Background page". Click this.
5 In the new popped up screen select in the left pane: "Service workers".
6 In the main field you can see the address: "www.google.com/_/chrome" or nl or any other country you live in.
Now click "Unregister".
7 Your done. Close all fields and try to startup chrome again. and Tadaa: No more annoying adobe help tab.
One more thing for the privacy lovers.
Right click on the adobe extension sign in the upper right corner of chrome.
Now select "options".Uncheck: the allow anonymous use of tracking info.
Click: save and your done.
Hope this helps you guys and girls.
Is there a way to make this setting via gpo or register? In distributed environments this is not a valid solution unfortunately.
Hope someone could help us
Hi and thanks for your quick reply,
I'm already using Adobe acrobat extension for Chrome with free Acrobat Reader and it works fine but every time the extension is installed (we use mandatory profiles in a Citrix environment with GPO which install Adobe Acrobat extension every time they login) the chrome browser opens a new tab. This is very annoiyng for users because they have to close the tab and return to their working tab.
Is this not possible than?
This is absolutely Untrue and not the Answer for this quesion.
Adobe Acrobat and Reader both automatically install the Extension unless configured otherwise.
I have deleted the registry key that installs the Acrobat extension for all users. Now no more Error is showing on the first start of Chrome. This is not exactly the issue with a new tab opening, but extremely annoying for new users and inappropriate for a business environment. I have no experience yet if updates will reenable it or not.
On 64-bit Windows delete the registry key
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Google\Chrome\Extensions\efaidnbmnnnibpcajpcglclefindmkaj
On 32-bit Windows delete the registry key
HKEY_LOCAL_MACHINE\SOFTWARE\Google\Chrome\Extensions\efaidnbmnnnibpcajpcglclefindmkaj
Has there been an answer to this posted somewhere? We use non-persistent Citrix desktops and load extensions every time the user connects to a session. We need to suppress this page from loading with every new session. If I enable developer mode I can click on "background page" under inspect views. Here under the Application tab I choose local storage, the chrome extension and change the fte value to true the page will load every time chrome opens. If I change it to false it will not open. Is there a way via a GPO or a registry setting I can force this setting to false so the page will never load?
Is there any chance anyone will answer this question?
I manage a similiar non-persistent VMware Horizon environment, and I have the exact same request. A way to disable this pop-up for all users, every time they login. I have the same question:
By @Jasonlalanne1
