• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Formatting Issues - RH2017 - When previewing an item
Community Beginner ,
Mar 12, 2018 Mar 12, 2018
I am having an issue with my style sheet and the bullets, 1 through 4 not showing on the preview button properly.  On my work space the bullets look fantastic and spaced properly as shown below:
However, when I preview the topic, the spacing is correct, however, the bullets are not:
Does anyone know how to correct this so when I publish my topics to our intranet, the bullets don't look like this?  I am at a loss as to why it looks like this.  Again I am using RH 2017.
Thanks!
Views
362
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Welcome to the wacky wonderful world of inconsistencies in CSS!
Basically, you need to spend time in what I call the "CSS Loop". Meaning, you tweak things and test in all the different browsers.
I've always called the RoboHelp Preview "RoboHelp's best guess" at how things will look. Because it's just one possible view of what your end user may see. You won't know for sure until you generate and test in different browsers. And each browser will likely have its own little quirks.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Thanks for the info Rick, however, can you tell me where I would need to "tweak things"?  I wouldn't go to the Formatting pod, as the bullets are spaced correctly, so where would I go to make the tweaks?  BTW, we here use IE 11 to view the topics once published to our intranet.
Thanks again!
Robert
Votes
Translate
Translate
Report
Report
Community Expert ,
Nope, you're playing with the CSS that's applied to the output files - tweak & witness the effect in your browser.
Votes
Translate
Translate
Report
Report
Thanks for info Jeff, but I have checked the CSS and it all looks correct.  It is the exact same info as shown in the formatting pod within RH 2017.  So are you saying to still start playing with the spacing of the bullets in the CSS even though they are identical to the formatting pod?
Thanks for your help!
Votes
Translate
Translate
Report
Report
Community Expert ,
I'd check one of the offending output topics and take a look at the HTML - I found a bug a few versions back that showed 2 CSS file references in the header of my topics - the second CSS was the one that was followed, even though I had it correct in the first one.
Votes
Translate
Translate
Report
Report
Community Expert ,
If two CSS files are specified, the logic is that anything in the second one adds to what is in the first one. So if <p> is defined in the first as red normal weight and in the second as bold, you will get red bold.
Anything in the first applies where not overridden in the second one.
See www.grainge.org for free RoboHelp and Authoring information.
@petergrainge
Votes
Translate
Translate
Report
Report
Community Expert ,
Hmm, according to CSS How to - "If some properties have been defined for the same selector (element) in different style sheets, the value from the last read style sheet will be used." - which is what I experienced; I imagine they would have been additive if I had different elements in each one.
Votes
Translate
Translate
Report
Report
Community Expert ,
That is what I meant by saying if
had red and normal weight defined but
the second css said just bold, red would still apply but bold would
override normal weight.
Sorry if that wasn't clear.
If the second css also had italic, you would get red bold italic.
Votes
Translate
Translate
Report
Report
Thank you gentlemen for all the information.  I have looked at everything all of you stated to look at and it all looks correct to me.  Interesting thing is that I had no issue when I was using RH10.  I will keep hunting.  We haven't officially rolled over to RH 2017 so I have some time to figure this out.
Votes
Translate
Translate
Report
Report
Community Expert ,
Can you show us screenshots of the HTML of the offending bullet line & the corresponding entry in the CSS?
Votes
Translate
Translate
Report
Report
Jeff....I would be happy to show you, however, where would you go in the CSS to see HTML code?  All I see if the actual details of the bullet....Fonts...Indent...Spacing..etc.  However, it is not in HTML code.  So is that what you want.  the HTML Code form the topic and a screenshot of the formatting of the bullet itself?  If not, let me know.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Thinking more of the HTML in the output topic for the bullet (to see the tag applied to it) and the section in the referenced CSS in Notepad where that tag is defined.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
