2 Replies Latest reply on Jul 2, 2008 8:39 PM by Mail2sunil
    BlazeDS with spring
    Mail2sunil
      I am getting an error while implementing
      http://www.adobe.com/devnet/livecycle/articles/blazeds_spring_03.html
      I have followed all the steps from beginning.
      I am getting this error message - Blazeds startup failed when i try to run tomcat .
      I checked in ds-console also Blazeds -Application is not running.
      Blazeds -Application is starting properly when I remove listener node in web.xml
      <listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
      I have placed the spring.jar file under \blazeds\WEB-INF\lib and made all the changes in
      services-config.xml,
      remoting-config.xml
      and applicationContext.xml
      Can anyone help me out in this..
      Thanks & Regards
      Sunil.P
        • 1. Re: BlazeDS with spring
          SujitG Level 2
          Can you please check out if there is some other error than BlazeDS start p failed. Usually there will be other message which will give us a clue in terms of why BlazeDS start up failed. Please check in the stdout.log or if this is set to your console then check in the tomcat console.
          • 2. Re: BlazeDS with spring
            Mail2sunil Level 1
            HI Sujit,
            Thanks......
            I got it working now..... The problem is with spring.jar. I was using spring framework version 2.0.8.
            I have replaced it with Spring Framework 2.5.5. Now it is working fine.....
            I have no clue why the sample is not working with spring framework version 2.0.8.
            Regards
            Sunil.P
