12 Replies Latest reply on May 23, 2018 9:36 AM by waynet7410269
    Defining a policy for parsys with dynamic node name
    mkinbaum27
      Hello,
      I am working on creating editable templates in AEM 6.2. I have an accordion-like component that leverages a multi-field to create tabs with parsys containers. In order to preserve the content that gets dragged into each of these parsys nodes, and to preserve the re-orderability that the multi-field provides, I've assigned each of the parsys nodes that get generated a unique ID that gets saved with the component.
      I would like to make this available to the template editor, however the trouble I am facing is that I need to keep redefining a policy every time I add a tab. The problem with this is that I have to have a fixed number of tabs in my structure which is not acceptable.
      This works fine however in the static templates. To get that working I added a list of allowed components to the design of the parent node that contains all of the dynamic parsys nodes. Each of the parsys nodes that get generated respect the list of allowed components defined on their parent.
      I tried this approach using policies, but it does not work for me.
      Can anyone offer any suggestions on how I can replicate what I've done with the static templates?
      Thanks, Matt
        • 1. Re: Defining a policy for parsys with dynamic node name
          smacdonald2008 Adobe Employee
          I am still not 100% what you are asking. Can you show a screenshot of your component. I am not sure what you mean by dynamic node name.
          • 2. Re: Defining a policy for parsys with dynamic node name
            mkinbaum27 Level 1
            Hi Scott, I'll share with you the static template version that leverages /etc/designs/
            Here is my component:
            This component has a multi-field which creates "x" number of parsys nodes and dynamically adds a unique node name to them.
            <div class="omc-Drawer-parsys" data-sly-resource="${['drawer-content', item.id] @ join='-', resourceType='foundation/components/parsys'}"></div>
            Under /etc/designs, rather that trying to add a series of nodes below the omc-Drawer component and set the components[] for each, I am simply able to specify this property at the component level, like so:
            I do it this way, otherwise I'd have to dynamically add the names of each generated parsys below omc-Drawer, ie:
            - maincontent
                 - omc-Drawer
                      - drawer-content-6377
                      - drawer-content-4452
                      - etc...
            This works well for static templates. I tried a similar approach with template editor and policies. But I am unable to replicate this behavior. I hope this cleared up any confusion.
            Thanks, Matt
            • 3. Re: Defining a policy for parsys with dynamic node name
              That is why i am confused. You component (looks like HTL) is only logic/code.
              When you add that to a page based on a static template or an editable template - the code should still be invoked and work the same way.
              What happens when you allow your component to be added to a editable template and then drop that component into an editbale template.
              • 4. Re: Defining a policy for parsys with dynamic node name
                mkinbaum27 Level 1
                When I drop it onto an editable template, I configure it with "x" number of drawers.
                When the component renders, I have to manually define the policy for each parsys that gets created.
                In the policy selection dialog, I am able to select the policy that I defined on the parent component (omc-Drawer).
                Having to do this leads to a fixed number of tabs in my structure, or I have initial content with no available components to select from.
                Here are some screenshots of the policies I've defined.
                These mimic the /etc/designs/ approach:
                • 5. Re: Defining a policy for parsys with dynamic node name
                  mkinbaum27 Level 1
                  I can upload my package if that is helpful. I've tested this in fresh instances of 6.2, 6.3, and 6.4
                  This did not work in any environment.
                  • 6. Re: Defining a policy for parsys with dynamic node name
                    mkinbaum27 Level 1
                    After some playing around with this issue, I found a hack / workaround by doing the following:
                    1. I cannot click "Drag components here" on my drawer's child parsys
                    2. However, I can add a component as a sibling to my drawer component (i.e. a text component)
                    3. I am able to drag this component into my drawer's child parsys node (even though I haven't defined a policy at this level - the policy is defined on the drawer itself).
                    4. I refresh the page
                    5. I remove the text component from the drawer child parsys
                    6. Now I am able to add my whitelisted components to the drawer's child parsys nodes
                    Doing it this way creates a drawer-content-* node under my omc_drawer node.
                    That 26770 number is dynamically created to provide uniqueness to that drawer so that we can reorder our drawers using our multi-field.
                    So this will not work if we wanted to unlock the component and provide our users the with the ability to add / remove drawers as the ID would be unknown.
                    In the static templates, we set the design on omc_drawer itself. This "whitelist" of components then flows downward to any parsys nodes that are created below omc_drawer. In template editor, the behavior of policies is not identical to aforementioned, as you can see that the node name drawer-content-26770 has to be present for the parent policy to take effect.
                    • 8. Re: Defining a policy for parsys with dynamic node name
                      mkinbaum27 Level 1
                      Sure. Unfortunately this is still unanswered. I believe this is a bug with the policies code.
                      • 9. Re: Defining a policy for parsys with dynamic node name
                        waynet7410269
                        Is there by any chance a resolution to this? I have the same issue and have 404s thrown when one of the dynamic parsys components are hovered.
                        • 11. Re: Defining a policy for parsys with dynamic node name
                          Alex Lidov
                          Hi mkinbaum27 and waynet7410269
                          Don't know if the issue is still actual for you, but I faced exactly the same problem and found the way to resolve it without dirty hacks.
                          Problem:
                          I need to define a policy for the component which is container for other components. Purpose - to allow only particular components to be added inside this container component.
                          I added pretty similar policy as in post 4 https://forums.adobe.com/message/10240555#10240555
                          Result: policy worked fine for the first component added to a page, but did not work if to add second, third, etc components to the same page. The reason for that - first component has name MyComponent, when all added later components will be MyComponent-1111111, MyComponent-2222222 etc, and policy will be applied only for the first component with the name without any suffix - MyComponent.
                          Solution:
                          the matter is, that the nodes structure in your template-type and template itself must fully correspond to the structure of the defined policy. Let's take mkinbaum's example.
                          Current template structure:
                          templates
                          --matt-test
                          ----policies
                          ------jcr:content
                          --------root
                          ----------omc_drawer
                          Must be:
                          templates
                          --matt-test
                          ----policies
                          ------jcr:content
                          --------root
                          ----------foundation
                          ------------components
                          --------------parsys
                          Hope that will help.
