3 Replies Latest reply on May 7, 2018 3:32 PM by Günter Heißenbüttel
    State Rollower only works on Master Page
    christophm67164366
      Hey, I have created a Menu Bar with animated rollover States. In the Master Page, where it was created, it is working without problems, the red underlining is popping up as it should, if i however open the "Home" page, the rollover from the Master Page is not working anymore and I am at a loss, there are no layers on top of it whatsoever. I have uploaded a muse file with the problem to dropbox. If someone could help me, this would be great! Thanks!
      https://www.dropbox.com/s/vp39s8oncluza91/12.03.2018_Problemfile.muse?dl=0
        • 1. Re: State Rollower only works on Master Page
          Günter Heißenbüttel Adobe Community Professional
          Seems a little bit strange. Maybe(!!) your menu is somehow corrupted.
          What I tried:
          • I made your menu considerable wider, tried „uniform size“ instead of „uniform spacing“ and sometimes it worked.
          • I rebuild your menu exactly, and it worked without any hassles – on master ans layout page.
          Could you try to rebuild your menu and take care of the fonts you are using? It is only a matter of minutes.
          • 2. Re: State Rollower only works on Master Page
            christophm67164366 Level 1
            Hello,
            thanks for the answer back then. I paused the project and I am trying to continue now. But how come I have to create the whole menu from scratch? Sure, that is one way to do it but wouldnt it be more interesting to find out, what caused the menu to get corrupted in the first place? Because I dont know if simply recreating the menu will be a long time solution if this problem might reoccur again when creating new ones. It is definitely very frustrating for someone like me who is just starting out with the software. Thank you for the help though, i appreciate it.
            • 3. Re: State Rollower only works on Master Page
              You will never get an answer to this! Maybe it is a hidden bug, which occurred by performing some actions in a specific sequence and timing, maybe it is a slightly corrupted file (caused by current fluctuation), maybe a temporary problem with mass storage.)
              Don‘t be frustrated! An issue like this is quite normal, when dealing with computers and software.
