• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Words starting with Swedish letters not generated in right order in index
Community Beginner ,
Mar 13, 2018 Mar 13, 2018
Hi!
I am working with Indesign 2018 and I have a problem with the index of a book written in Swedish. Swedish has three extra letters Å, Ä and Ö and words beginning with these letters should go at the end of the alphabet / index. However, after generating the index indesign places words that start with Å and Ä immediately after the words starting with A.  And the words that start with Ö are placed immediately after the words starting with O. See below.
orsaken och verkan. Se handlingar och effekter; karma
otaliga levande varelser  97, 155
ödmjukhet  134–138
önskande kärlek  80, 183–194
önskeuppfyllande juvel  98, 113, 124, 201, 212
övertygelse  197, 199
P
Palden, Geshe  195
pansarliknande ansträngning  159
potential  5, 52, 99–100, 121, 131, 169–170, 197
för att gynna levande varelser  189, 194, 197
för att återfödas i ett rent land  200
primärt sinne  228. O .
The only way I can fix this at the moment is to manually move the Å, Ä and Ö words to the end after generating the index. But if I need to make change to the index and generate it again then I need to manually move these words again.
I have already set the language to Swedish in the character panel, so I don't know what else to do.
Does anyone have any tips?
Many thanks!
Views
459
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Mar 13, 2018 Mar 13, 2018
You can use the index panel to change the sorting order for those words.
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Hi!
Many thanks for your swift reply. I have applied the changes you suggest and the index now looks like this:
Y
yogan i att jämställa samsara och nirvana  252
yogi/yogini  26, 122, 190. O .
yttra sanningen  195
yttre objekt  10
yttre omständigheter  12, 69, 278
  beror på sinnet  145, 179
  och lycka  7, 18, 176, 280
Z
åldrandet  32, 60–63, 79
åtaganden  76. O .
  för att träna sinnet  150–151
återfödelse  21–27, 46–49, 79
  förorenad  47, 53, 56, 71
  i ett rent land  200
  okontrollerad  34, 66, 147
  utan början  56, 207
återfödelse som djur  26, 48–49, 52–53, 76–77
  begränsningar  4
återfödelse som människa  47, 52, 55, 119, 175
  lidandet  55–69
ägodelar  64, 68, 97, 135, 277–278
ödmjukhet  134–138
So this is much better, since it all the entries are in the right order now. However, there are a couple more changes I would like to make. We don't have any words in the index that begin with Z, so I don't want the Z index section header to be generated.
Also, we are missing the index section headers for Å, Ä and Ö. Any idea how to generate them automatically from the index?
Thanks again!
Votes
Translate
Translate
Report
Report
Mar 14, 2018 Mar 14, 2018
I will mark this question as answered and start a new thread for my follow up question.
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 15, 2018 Mar 15, 2018
Based on the answer you received for your followup, my answer was not really correct, and was just an unnecessary (for your situation) workaround. (It's a useful tool for me when an entry starts with a number, so I can sort 5th Wheel under Fifth Wheel, for instance.)
Votes
Translate
Translate
Report
Report
LATEST
True, the second answer I got solved the problem. But thanks anyway for giving it a shot.
Very cool that people want to help out in these forums.
Votes
Translate
Translate
Report
Report
