2 Replies Latest reply on Mar 14, 2018 7:03 AM by mmmarc
    Android build fail
    mmmarc
      Hello,
      When I build (PGB) the zip. I get an error. Below the logs. Who could help me?
      Build Date: 2018-03-13 15:16:26 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-device" via npm
      Installing "cordova-plugin-device" at "2.0.1" for android
      Fetching plugin "cordova-plugin-inappbrowser" via npm
      Installing "cordova-plugin-inappbrowser" at "2.0.2" for android
      Fetching plugin "cordova-plugin-statusbar" via npm
      Installing "cordova-plugin-statusbar" at "2.4.1" for android
      Fetching plugin "cordova-plugin-console" via npm
      Installing "cordova-plugin-console" at "1.1.0" for android
      Fetching plugin "cordova-plugin-geolocation" via npm
      Installing "cordova-plugin-geolocation" at "4.0.1" for android
      Plugin doesn't support this project's cordova-android version. cordova-android: 6.2.3, failed version requirement: >=6.3.0
      Skipping 'cordova-plugin-geolocation' for android
      Fetching plugin "cordova-plugin-network-information" via npm
      Installing "cordova-plugin-network-information" at "2.0.1" for android
      Fetching plugin "cordova-plugin-splashscreen" via npm
      Installing "cordova-plugin-splashscreen" at "5.0.2" for android
      Fetching plugin "cordova-plugin-dialogs" via npm
      Installing "cordova-plugin-dialogs" at "2.0.1" for android
      Fetching plugin "pushwoosh-pgb-plugin" via npm
      Installing "pushwoosh-cordova-plugin" at "7.3" for android
      Subproject Path: CordovaLib
      Fetching plugin "cordova-plugin-whitelist" via npm
      Installing "cordova-plugin-whitelist" at "1.3.3" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      Fetching plugin "nl.kingsquare.cordova.background-audio" via npm
      Installing "nl.kingsquare.cordova.background-audio" at "1.0.1" for android
      Fetching plugin "cordova-plugin-socialsharing" via npm
      Installing "cordova-plugin-socialsharing" at "4.3.81" for android
      COMPILE OUTPUT
      :wrapper
      BUILD SUCCESSFUL in 2s
      1 actionable task: 1 executed
      The Task.leftShift(Closure) method has been deprecated and is scheduled to be removed in Gradle 5.0. Please use Task.doLast(Action) instead.
      at build_wx4ai6lzo5hhniiuvklm5yon.run(/project/build.gradle:137)
      The JavaCompile.setDependencyCacheDir() method has been deprecated and is scheduled to be removed in Gradle 4.0.
      Incremental java compilation is an incubating feature.
      The TaskInputs.source(Object) method has been deprecated and is scheduled to be removed in Gradle 4.0. Please use TaskInputs.file(Object).skipWhenEmpty() instead.
      File /.android/repositories.cfg could not be loaded.
      Checking the license for package Solver for ConstraintLayout 1.0.2 in /opt/android-sdk/licenses
      Warning: License for package Solver for ConstraintLayout 1.0.2 not accepted.
      Checking the license for package ConstraintLayout for Android 1.0.2 in /opt/android-sdk/licenses
      Warning: License for package ConstraintLayout for Android 1.0.2 not accepted.
      FAILURE: Build failed with an exception.
      * What went wrong:
      A problem occurred configuring root project 'project'.
      > You have not accepted the license agreements of the following SDK components:
        [ConstraintLayout for Android 1.0.2, Solver for ConstraintLayout 1.0.2].
        Before building your project, you need to accept the license agreements and complete the installation of the missing components using the Android Studio SDK Manager.
        Alternatively, to learn how to transfer the license agreements from one workstation to another, go to http://d.android.com/r/studio-ui/export-licenses.html
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 5.218 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
