2 Replies Latest reply on Apr 18, 2018 2:35 PM by srishtib8795206
    Data Merge Dropping "F"
    jessicac13234984
      We've been using data merge to create name tags for our events and recently noticed during the data merge is dropping the letter "f" from our source.  Everything else is importing correctly, it's just the "f" that is getting dropped.  Any suggestions?
        • 1. Re: Data Merge Dropping "F"
          Colin Flashman Adobe Community Professional
          It's hard to tell, are you able to supply more information, such as:
          • What version of InDesign you are on, as well as the operating system and language version;
          • When the fault started occurring (e.g. from a fixed date, after a software update, after something else was installed on the machine)
          • Does the fault happen in one document or every document;
          • Is this limited to one machine or does this happen on other machines (or there's only one copy of ID so don't know);
          • What happens when other file formats are used for the import (e.g. rather than tab delimited txt, what does CSV do?)
          • Do you have a sample of the affected data in which we may be able to try and replicate the fault? We will understand if it is sensitive and unable to be released.
          If you can supply this information, it will assist in trying to diagnose the fault.
          2 people found this helpful
          • 2. Re: Data Merge Dropping "F"
            srishtib8795206 Adobe Employee
            Hi jessicac,
            I would like to know if the issue is resolved, or it still persists.
            Have you tried resetting preferences: Set preferences in Adobe InDesign or tried with different source file.
            Kindly update the discussion if you need further assistance with it.
            Srishti
