• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Loading an External SWF File with Stage 3D in an AIR Application
Community Beginner ,
Mar 14, 2018 Mar 14, 2018
I have been trying to create an Adobe Air application which can download a SWF file and run it. This SWF file uses Stage 3D rendering.
I am able to load an external SWF file through an object of Loader Class, but only the Display Object elements from the SWF show up in the AIR App (Eg: Text, buttons etc) and not the 3D objects.
To check if there is an issue with the 3D Rendering, i ran scout on the app with Telemetry and Stage3D recording enabled. On Scout, the Stage 3D rendering tab does display the 3D objects. I assume this means the 3D Rendering does work but for some reason the correct stage is not being passed to the containing AIR Application.
I have tried going through posts and have defined right app flags. Eg: renderMode is set to direct, depthAndStencil is set to enabled etc. Morever i do not get any errors related to Stage3D classes.
What is it that i might be doing wrong? And is what i am trying to do even possible?
TOPICS
Development
Views
379
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Mar 15, 2018 Mar 15, 2018
I was trying somethings out with various background properties and looks like setting:
backgroundAlpha="0.0" as a WindowedApplication parameter or calling this.setStyle("backgroundAlpha","0.0") in the onApplicationStarted() method removes the white background and lets the 3D rendering to show up.
Marking the issue to answered now
Votes
Translate
Translate
Advocate ,
In your application.xml you might need to set:
<renderMode>direct</renderMode>
and, if you require the feature:
<depthAndStencil>true</depthAndStencil>
Here is the documentation:
Adobe AIR * Common settings
Votes
Translate
Translate
Report
Report
Hi!
Thanks for the response. I have already done that configuration in my application xml.
I get no errors related to Stage3D / Context3D. And on Adobe Scout, the Stage3D rendering tool does pick up the 3D rendering, but the AIR container appears blank.
Votes
Translate
Translate
Report
Report
Advocate ,
Is there a chance that your Air container application renders something on the background? Keep in mind that Stage3D content is always on the lowest level. That means you add the loaded swf as a child of the Air application, but Stage3D content of the child would still render *behind* the Air application. So if it has a background, Stage3D would not be visible. Other than that it should be straight forward. We do the same thing in our air apps as well and Stage3D content renders without problems in the loaded swfs.
Votes
Translate
Translate
Report
Report
I did try out things related to transparency and background, but it wasn't very helpful. I am pasting my code here. Please do check if i am missing out on something.
<?xml version="1.0"?>
<s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
   xmlns:mx="library://ns.adobe.com/flex/mx"
   applicationComplete="onApplicationStarted()">
  <fx:Script><![CDATA[
  import mx.controls.Label;
  protected function onApplicationStarted():void {
  var _urlLoader : URLLoader = new URLLoader;
  var _loader : Loader = new Loader;
  _urlLoader.dataFormat = URLLoaderDataFormat.BINARY;
  _urlLoader.load(new URLRequest("http://wiki.flare3d.com/demos/Test22/flare3d.swf"));
  this.stage.addChild(_loader);
  this.width = 1024;
  this.height = 600;
  _urlLoader.addEventListener(Event.COMPLETE, function(e:Event):void {
  var lc:LoaderContext = new LoaderContext(false, ApplicationDomain.currentDomain);
  lc.allowCodeImport = true;
  _loader.loadBytes(_urlLoader.data, lc);
  var loadingLabel:Label = new Label();
  loadingLabel.setStyle("fontFamily", "consolas");
  loadingLabel.text = "Loading!";
  this.addElement(loadingLabel);
  ]]></fx:Script>
</s:WindowedApplication>
I am trying to load an example Flare3D swf present here: Test22 - Drag & Drop - Flare3D Wiki
The label i added does show up, and once the external SWF gets loaded, the text from that overlaps the Loading text i add. But rest of my container remains blank (white).
I have also added the below configuration and my app.xml
Really appreciate your help on this.
Votes
Translate
Translate
Report
Report
LATEST
Votes
Translate
Translate
Report
Report
