31 Replies Latest reply on Apr 16, 2018 3:16 AM by Ritz.Meritz
    phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
    pixellet5 Level 1
      Just three days back...all of a sudden all my directory structure has changed inside the phonegap project...the build folder disappeared (appeared automatically today) ...all build commands don't show any errors (except --verbose) ....verbose shows a lot of errors which are totally a rocket science to understand atm as no resources available online on the internet.... is this due to the latest phonegap update?? I am stuck....please help....many thanks in advance
        • 1. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
          jcesarmobile_ Adobe Community Professional
          cordova-android 7.x.x uses a different folder structure, so if you have updated the Phonegap CLI to 8.0.0 you will get that cordova-android version.
          The build folder also changed the location, so your app is probably on the new folder, just search for the .apk inside your project, it should be there.
          • 2. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
            pixellet5 Level 1
            many thanks for your reply sire...
            Surprisingly...just after getting your reply ...i can see the build being generated....but it is no longer working in my phone lol....perhaps some other issue....
            many thanks once again for taking time....and the apk got generated in the same folder as previously...not any different folder...
            • 3. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
              pixellet5 Level 1
              btw....other projects/apps are still showing me errors as under
              BUILD FAILED in 1s
              23 actionable tasks: 1 executed, 22 up-to-date
              Command finished with error code 1: cmd /s /c "E:\phonegap\amyindiafinal\platfor
              ms\android\gradlew.bat cdvBuildDebug -b E:\phonegap\amyindiafinal\platforms\andr
              oid\build.gradle -Dorg.gradle.daemon=true -Dorg.gradle.jvmargs=-Xmx2048m -Pandro
              id.useDeprecatedNdk=true"
              (node:8100) UnhandledPromiseRejectionWarning: Error: cmd: Command failed with ex
              it code 1 Error output:
              E:\phonegap\amyindiafinal\platforms\android\app\src\main\AndroidManifest.xml:25:
              5-74 Error:
                      uses-sdk:minSdkVersion 14 cannot be smaller than version 16 declared in
              library [:CordovaLib] E:\phonegap\amyindiafinal\platforms\android\CordovaLib\bui
              ld\intermediates\manifests\full\debug\AndroidManifest.xml as the library might b
              e using APIs not available in 14
                      Suggestion: use a compatible library with a minSdk of at most 14,
                              or increase this project's minSdk version to at least 16,
                              or use tools:overrideLibrary="org.apache.cordova" to force usage
              (may lead to runtime failures)
              FAILURE: Build failed with an exception.
              * What went wrong:
              Execution failed for task ':app:processDebugManifest'.
              > Manifest merger failed : uses-sdk:minSdkVersion 14 cannot be smaller than vers
              ion 16 declared in library [:CordovaLib] E:\phonegap\amyindiafinal\platforms\and
              roid\CordovaLib\build\intermediates\manifests\full\debug\AndroidManifest.xml as
              the library might be using APIs not available in 14
              * Try:
              Run with --stacktrace option to get the stack trace. Run with --info or --debug
              option to get more log output.
              * Get more help at https://help.gradle.org
              BUILD FAILED in 1s
                  at ChildProcess.whenDone (E:\phonegap\amyindiafinal\platforms\android\cordov
              a\node_modules\cordova-common\src\superspawn.js:169:23)
                  at ChildProcess.emit (events.js:180:13)
                  at maybeClose (internal/child_process.js:936:16)
                  at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
              (node:8100) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This
              error originated either by throwing inside of an async function without a catch
              block, or by rejecting a promise which was not handled with .catch(). (rejection
              (node:8100) [DEP0018] DeprecationWarning: Unhandled promise rejections are depre
              cated. In the future, promise rejections that are not handled will terminate the
              Node.js process with a non-zero exit code.
              [phonegap] completed 'cordova build android --verbose --no-telemetry'
              E:\phonegap\amyindiafinal>phonegap build android --verbose
              [phonegap] executing 'cordova build android --verbose' ...
              No scripts found for hook "before_build".
              No scripts found for hook "before_prepare".
              Checking config.xml and package.json for saved platforms that haven't been added
              to the project
              Config.xml and package.json platforms are the same. No pkg.json modification.
              Package.json and config.xml platforms are different. Updating config.xml with mo
              st current list of platforms.
              PlatformApi successfully found for platform android
              Android Studio project detected
              Checking config.xml for saved plugins that haven't been added to the project
              Checking for any plugins added to the project that have not been installed in an
              droid platform
              No differences found between plugins added to project and installed in android p
              latform. Continuing...
              Generating platform-specific config.xml from defaults for android at E:\phonegap
              \amyindiafinal\platforms\android\app\src\main\res\xml\config.xml
              Merging project's config.xml into platform-specific android config.xml
              Merging and updating files from [www, platforms\android\platform_www] to platfor
              ms\android\app\src\main\assets\www
              Wrote out android application name "amyindia" to E:\phonegap\amyindiafinal\platf
              orms\android\app\src\main\res\values\strings.xml
              android-versionCode not found in config.xml. Generating a code based on version
              in config.xml (1.0.0): 10000
              Wrote out Android package name "com.amyindia.meritz" to E:\phonegap\amyindiafina
              l\platforms\android\app\src\main\java\com\amyindia\meritz\MainActivity.java
              Updating icons at platforms\android\app\src\main\res
              Updating splash screens at platforms\android\app\src\main\res
              This app does not have additional resource files defined
              Prepared android project successfully
              Executing script found in plugin cordova-push-notifications for hook "after_prep
              are": plugins\cordova-push-notifications\hooks\after_prepare\999-admobPluginNoti
              ce.js
              No scripts found for hook "before_compile".
              ANDROID_HOME=C:\Users\Ritesh Singh\AppData\Local\Android\sdk
              JAVA_HOME=C:\Program Files\java\jdk1.8.0_162
              studio
              Subproject Path: CordovaLib
              Subproject Path: app
              Running command: cmd "/s /c "E:\phonegap\amyindiafinal\platforms\android\gradlew
              .bat cdvBuildDebug -b E:\phonegap\amyindiafinal\platforms\android\build.gradle -
              Dorg.gradle.daemon=true -Dorg.gradle.jvmargs=-Xmx2048m -Pandroid.useDeprecatedNd
              k=true""
              publishNonDefault is deprecated and has no effect anymore. All variants are now
              published.
              The Task.leftShift(Closure) method has been deprecated and is scheduled to be re
              moved in Gradle 5.0. Please use Task.doLast(Action) instead.
                      at build_15gvrh3427f3g4g9wk3g8zivt.run(E:\phonegap\amyindiafinal\platfor
              ms\android\app\build.gradle:143)
              Configuration 'compile' in project ':app' is deprecated. Use 'implementation' in
              stead.
              :CordovaLib:preBuild UP-TO-DATE
              :CordovaLib:preDebugBuild UP-TO-DATE
              :CordovaLib:compileDebugAidl
              UP-TO-DATE
              :CordovaLib:compileDebugRenderscript UP-TO-DATE
              :CordovaLib:checkDebugManifest UP-TO-DATE
              :CordovaLib:generateDebugBuildConfig UP-TO-DATE
              :CordovaLib:prepareLintJar UP-TO-DATE
              :CordovaLib:generateDebugResValues UP-TO-DATE
              :CordovaLib:generateDebugResources UP-TO-DATE
              :CordovaLib:packageDebugResources
              UP-TO-DATE
              :CordovaLib:platformAttrExtractor UP-TO-DATE
              :CordovaLib:processDebugManifest
              UP-TO-DATE
              :CordovaLib:processDebugResources
              UP-TO-DATE
              :CordovaLib:generateDebugSources UP-TO-DATE
              :CordovaLib:javaPreCompileDebug UP-TO-DATE
              :CordovaLib:compileDebugJavaWithJavac
              UP-TO-DATE
              :CordovaLib:processDebugJavaRes NO-SOURCE
              :CordovaLib:transformClassesAndResourcesWithPrepareIntermediateJarsForDebug UP-T
              O-DATE
              :app:preBuild UP-TO-DATE
              :app:preDebugBuild
              UP-TO-DATE
              :app:compileDebugAidl UP-TO-DATE
              :CordovaLib:packageDebugRenderscript NO-SOURCE
              :app:compileDebugRenderscript
              UP-TO-DATE
              :app:checkDebugManifest
              UP-TO-DATE
              :app:generateDebugBuildConfig UP-TO-DATE
              :app:prepareLintJar UP-TO-DATE
              :app:generateDebugResValues
              UP-TO-DATE
              :app:generateDebugResources UP-TO-DATE
              :app:mergeDebugResources
              UP-TO-DATE
              :app:createDebugCompatibleScreenManifests UP-TO-DATE
              5-74 Error:
              See http://g.co/androidstudio/manifest-merger for more information about the man
              ifest merger.
              :app:processDebugManifest FAILED
              * What went wrong:
              * Try:
              BUILD FAILED in 1s
              (node:7212) UnhandledPromiseRejectionWarning: Error: cmd: Command failed with ex
              5-74 Error:
              * What went wrong:
              * Try:
              BUILD FAILED in 1s
              (node:7212) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This
              (node:7212) [DEP0018] DeprecationWarning: Unhandled promise rejections are depre
              • 4. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                That error is because you are trying to use the min SDK 14, but latest cordova-android requires 16
                If you have this preference in your config.xml change the value to 16 or remove the whole preference.
                <preference name="android-minSdkVersion"      value="14" />
                • 5. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                  pixellet5 Level 1
                  oh cool...but what about the emulator? after we type the command phonegap emulate android... it doesn't emulate in the AVD?
                  • 6. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                    No idea about that, I always use real devices to test because I have never been able to launch an emulator properly (not even from Android Studio/Eclipse), it starts bug hangs and never launch the app.
                    • 7. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                      pixellet5 Level 1
                      so true!...lol...however...just one last question
                      when i run
                      it doesn't work
                      but when i run
                      it does!
                      you have come as a blessing to our team sir! ....thanks a lot...atleast we can now send the test apk to our client
                      • 8. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                        pixellet5 Level 1
                        it has stopped working again...what min sdk version should we change it to now?
                        • 9. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                          That was for that error. What error are you getting now?
                          If you updated to cordova-android 7.1.0, then you have to change the minsdk to 19.
                          Anyway, it's better to just remove that preference if you are going to use the minsdk allowed by cordova-android
                          • 10. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                            pixellet5 Level 1
                            hi...thanks for replying....the error is as under
                            : java.lang.RuntimeException: com.android.ide.common.process.ProcessException: E
                            rror while executing java process with main class com.google.devtools.build.andr
                            oid.desugar.Desugar with arguments {--input E:\phonegap\cobraPost\platforms\andr
                            oid\app\build\intermediates\transforms\stackFramesFixer\debug\13.jar --output E:
                            \phonegap\cobraPost\platforms\android\app\build\intermediates\transforms\desugar
                            \debug\15.jar --input E:\phonegap\cobraPost\platforms\android\app\build\intermed
                            iates\transforms\stackFramesFixer\debug\11.jar --output E:\phonegap\cobraPost\pl
                            atforms\android\app\build\intermediates\transforms\desugar\debug\13.jar --input
                            E:\phonegap\cobraPost\platforms\android\app\build\intermediates\transforms\stack
                            FramesFixer\debug\6.jar --output E:\phonegap\cobraPost\platforms\android\app\bui
                            ld\intermediates\transforms\desugar\debug\8.jar --input E:\phonegap\cobraPost\pl
                            atforms\android\app\build\intermediates\transforms\stackFramesFixer\debug\27.jar
                            --output E:\phonegap\cobraPost\platforms\android\app\build\intermediates\transf
                            orms\desugar\debug\29.jar --input E:\phonegap\cobraPost\platforms\android\app\bu
                            ild\intermediates\transforms\stackFramesFixer\debug\3.jar --output E:\phonegap\c
                            obraPost\platforms\android\app\build\intermediates\transforms\desugar\debug\5.ja
                            r --input E:\phonegap\cobraPost\platforms\android\app\build\intermediates\transf
                            orms\stackFramesFixer\debug\1.jar --output E:\phonegap\cobraPost\platforms\andro
                            id\app\build\intermediates\transforms\desugar\debug\3.jar --input E:\phonegap\co
                            braPost\platforms\android\app\build\intermediates\transforms\stackFramesFixer\de
                            bug\20.jar --output E:\phonegap\cobraPost\platforms\android\app\build\intermedia
                            tes\transforms\desugar\debug\22.jar --input E:\phonegap\cobraPost\platforms\andr
                            oid\app\build\intermediates\transforms\stackFramesFixer\debug\25.jar --output E:
                            \debug\27.jar --input E:\phonegap\cobraPost\platforms\android\app\build\intermed
                            iates\transforms\stackFramesFixer\debug\21.jar --output E:\phonegap\cobraPost\pl
                            atforms\android\app\build\intermediates\transforms\desugar\debug\23.jar --input
                            FramesFixer\debug\17.jar --output E:\phonegap\cobraPost\platforms\android\app\bu
                            ild\intermediates\transforms\desugar\debug\19.jar --input E:\phonegap\cobraPost\
                            platforms\android\app\build\intermediates\transforms\stackFramesFixer\debug\32.j
                            ar --output E:\phonegap\cobraPost\platforms\android\app\build\intermediates\tran
                            sforms\desugar\debug\34.jar --input E:\phonegap\cobraPost\platforms\android\app\
                            build\intermediates\transforms\stackFramesFixer\debug\30.jar --output E:\phonega
                            p\cobraPost\platforms\android\app\build\intermediates\transforms\desugar\debug\3
                            2.jar --input E:\phonegap\cobraPost\platforms\android\app\build\intermediates\tr
                            ansforms\stackFramesFixer\debug\19.jar --output E:\phonegap\cobraPost\platforms\
                            android\app\build\intermediates\transforms\desugar\debug\21.jar --classpath_entr
                            y E:\phonegap\cobraPost\platforms\android\CordovaLib\build\intermediates\interme
                            diate-jars\debug\classes.jar --classpath_entry E:\phonegap\cobraPost\platforms\a
                            ndroid\app\build\intermediates\classes\debug --classpath_entry E:\phonegap\cobra
                            Post\platforms\android\app\build\intermediates\transforms\stackFramesFixer\debug
                            \0.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\app\build\inter
                            mediates\transforms\stackFramesFixer\debug\1.jar --classpath_entry E:\phonegap\c
                            obraPost\platforms\android\app\build\intermediates\transforms\stackFramesFixer\d
                            ebug\2.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\app\build\i
                            ntermediates\transforms\stackFramesFixer\debug\3.jar --classpath_entry E:\phoneg
                            ap\cobraPost\platforms\android\app\build\intermediates\transforms\stackFramesFix
                            er\debug\4.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\app\bui
                            ld\intermediates\transforms\stackFramesFixer\debug\5.jar --classpath_entry E:\ph
                            onegap\cobraPost\platforms\android\app\build\intermediates\transforms\stackFrame
                            sFixer\debug\6.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\app
                            \build\intermediates\transforms\stackFramesFixer\debug\7.jar --classpath_entry E
                            :\phonegap\cobraPost\platforms\android\app\build\intermediates\transforms\stackF
                            ramesFixer\debug\8.jar --classpath_entry E:\phonegap\cobraPost\platforms\android
                            \app\build\intermediates\transforms\stackFramesFixer\debug\9.jar --classpath_ent
                            ry E:\phonegap\cobraPost\platforms\android\app\build\intermediates\transforms\st
                            ackFramesFixer\debug\10.jar --classpath_entry E:\phonegap\cobraPost\platforms\an
                            droid\app\build\intermediates\transforms\stackFramesFixer\debug\11.jar --classpa
                            th_entry E:\phonegap\cobraPost\platforms\android\app\build\intermediates\transfo
                            rms\stackFramesFixer\debug\12.jar --classpath_entry E:\phonegap\cobraPost\platfo
                            rms\android\app\build\intermediates\transforms\stackFramesFixer\debug\13.jar --c
                            lasspath_entry E:\phonegap\cobraPost\platforms\android\app\build\intermediates\t
                            ransforms\stackFramesFixer\debug\14.jar --classpath_entry E:\phonegap\cobraPost\
                            platforms\android\app\build\intermediates\transforms\stackFramesFixer\debug\15.j
                            ar --classpath_entry E:\phonegap\cobraPost\platforms\android\app\build\intermedi
                            ates\transforms\stackFramesFixer\debug\16.jar --classpath_entry E:\phonegap\cobr
                            aPost\platforms\android\app\build\intermediates\transforms\stackFramesFixer\debu
                            g\17.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\app\build\int
                            ermediates\transforms\stackFramesFixer\debug\18.jar --classpath_entry E:\phonega
                            p\cobraPost\platforms\android\app\build\intermediates\transforms\stackFramesFixe
                            r\debug\19.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\app\bui
                            ld\intermediates\transforms\stackFramesFixer\debug\20.jar --classpath_entry E:\p
                            honegap\cobraPost\platforms\android\app\build\intermediates\transforms\stackFram
                            esFixer\debug\21.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\a
                            pp\build\intermediates\transforms\stackFramesFixer\debug\22.jar --classpath_entr
                            y E:\phonegap\cobraPost\platforms\android\app\build\intermediates\transforms\sta
                            ckFramesFixer\debug\23.jar --classpath_entry E:\phonegap\cobraPost\platforms\and
                            roid\app\build\intermediates\transforms\stackFramesFixer\debug\24.jar --classpat
                            h_entry E:\phonegap\cobraPost\platforms\android\app\build\intermediates\transfor
                            ms\stackFramesFixer\debug\25.jar --classpath_entry E:\phonegap\cobraPost\platfor
                            ms\android\app\build\intermediates\transforms\stackFramesFixer\debug\26.jar --cl
                            asspath_entry E:\phonegap\cobraPost\platforms\android\app\build\intermediates\tr
                            ansforms\stackFramesFixer\debug\27.jar --classpath_entry E:\phonegap\cobraPost\p
                            latforms\android\app\build\intermediates\transforms\stackFramesFixer\debug\28.ja
                            r --classpath_entry E:\phonegap\cobraPost\platforms\android\app\build\intermedia
                            tes\transforms\stackFramesFixer\debug\29.jar --classpath_entry E:\phonegap\cobra
                            \30.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\app\build\inte
                            rmediates\transforms\stackFramesFixer\debug\31.jar --classpath_entry E:\phonegap
                            \cobraPost\platforms\android\app\build\intermediates\transforms\stackFramesFixer
                            \debug\32.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\app\buil
                            d\intermediates\transforms\stackFramesFixer\debug\33.jar --classpath_entry E:\ph
                            sFixer\debug\34.jar --classpath_entry E:\phonegap\cobraPost\platforms\android\ap
                            p\build\intermediates\transforms\stackFramesFixer\debug\35.jar --classpath_entry
                            kFramesFixer\debug\36.jar --bootclasspath_entry C:\Users\Ritesh Singh\AppData\Lo
                            cal\Android\sdk\platforms\android-26\android.jar --bootclasspath_entry C:\Users\
                            Ritesh Singh\AppData\Local\Android\sdk\platforms\android-26\optional\org.apache.
                            http.legacy.jar --bootclasspath_entry C:\Program Files\Java\jdk1.8.0_162\jre\lib
                            \resources.jar --bootclasspath_entry C:\Program Files\Java\jdk1.8.0_162\jre\lib\
                            rt.jar --bootclasspath_entry C:\Program Files\Java\jdk1.8.0_162\jre\lib\jsse.jar
                            --bootclasspath_entry C:\Program Files\Java\jdk1.8.0_162\jre\lib\jce.jar --boot
                            classpath_entry C:\Program Files\Java\jdk1.8.0_162\jre\lib\charsets.jar --bootcl
                            asspath_entry C:\Program Files\Java\jdk1.8.0_162\jre\lib\jfr.jar --min_sdk_versi
                            on 16 --desugar_try_with_resources_if_needed --desugar_try_with_resources_omit_r
                            untime_classes}
                            * Try:
                            36 actionable tasks: 3 executed, 33 up-to-date
                            or --debug option to get more log output.
                            BUILD FAILED in 5s
                            Command finished with error code 1: cmd /s /c "E:\phonegap\cobraPost\platforms\a
                            ndroid\gradlew.bat cdvBuildDebug -b E:\phonegap\cobraPost\platforms\android\buil
                            d.gradle -Dorg.gradle.daemon=true -Dorg.gradle.jvmargs=-Xmx2048m -Pandroid.useDe
                            precatedNdk=true"
                            (node:3500) UnhandledPromiseRejectionWarning: Error: cmd: Command failed with ex
                            Exception in thread "main" java.lang.IllegalArgumentException
                                    at com.google.common.base.Preconditions.checkArgument(Preconditions.java
                            :108)
                                    at com.google.devtools.build.android.desugar.DefaultMethodClassFixer$Def
                            aultMethodFinder.visit(DefaultMethodClassFixer.java:471)
                                    at org.objectweb.asm.ClassReader.accept(Unknown Source)
                                    at com.google.devtools.build.android.desugar.DefaultMethodClassFixer.def
                            aultMethodsDefined(DefaultMethodClassFixer.java:319)
                                    at com.google.devtools.build.android.desugar.DefaultMethodClassFixer.vis
                            itEnd(DefaultMethodClassFixer.java:88)
                                    at org.objectweb.asm.ClassVisitor.visitEnd(Unknown Source)
                                    at com.google.devtools.build.android.desugar.InterfaceDesugaring.visitEn
                            d(InterfaceDesugaring.java:85)
                                    at com.google.devtools.build.android.desugar.LambdaDesugaring.visitEnd(L
                            ambdaDesugaring.java:150)
                                    at com.google.devtools.build.android.desugar.Desugar.desugarClassesInInp
                            ut(Desugar.java:401)
                                    at com.google.devtools.build.android.desugar.Desugar.desugarOneInput(Des
                            ugar.java:326)
                                    at com.google.devtools.build.android.desugar.Desugar.desugar(Desugar.jav
                            a:280)
                                    at com.google.devtools.build.android.desugar.Desugar.main(Desugar.java:5
                            84)
                            * What went wrong:
                            Execution failed for task ':app:transformClassesWithDesugarForDebug'.
                            > com.android.build.api.transform.TransformException: java.lang.RuntimeException
                            untime_classes}
                            * Try:
                            BUILD FAILED in 5s
                                at ChildProcess.whenDone (E:\phonegap\cobraPost\platforms\android\cordova\no
                            (node:3500) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This
                            (node:3500) [DEP0018] DeprecationWarning: Unhandled promise rejections are depre
                            E:\phonegap\cobraPost>phonegap emulate android
                            [phonegap] executing 'cordova emulate android' ...
                            [phonegap] completed 'cordova emulate android --no-telemetry'
                            • 14. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                              Sorry, I have no idea what the problem is now.
                              Try deleting android platform and adding it again.
                              • 15. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                pixellet5 Level 1
                                Yet, I am thankful that you took time out to reply me. I have figured out the problem tho. It's because of the push plugin. By changing the minsdkversion to 16 in any new apps created I am able to compile the build file, however once I install the plugin cordova-push-notifications everything stops. It doesn't work even after removing the plugin. Please can you share any online resource or any other best plugin for push notifications? this would be my last question and I won't bother you again. I promise jcesarmobile_
                                • 16. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                  I use phonega-plugin-push and it works fine, but current version doesn't work on PGB yet as it requires cordova-android 7.1.0
                                  There is also cordova-plugin-fcm
                                  I have sample apps for both of them
                                  GitHub - jcesarmobile/phonegap-plugin-push-sample
                                  GitHub - jcesarmobile/fcm-pgb-sample
                                  • 17. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                    pixellet5 Level 1
                                    hi,
                                    when u say PGB it means Phonegap Build (build.phonegap.com) or Phonegam Command Line?
                                    • 18. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                      Phonegap Build.
                                      Ah, you were using the CLI, so it shouldn't affect you, but you will have to add cordova-android 7.1.0 manually as the CLI will install 7.0.0 by default.
                                      • 20. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                        That's the CLI version, I mean the cordova-android version (the platform)
                                        Do a
                                        cordova platform rm android
                                        and then
                                        cordova platform add android@7.1.0
                                        If using Phonegap CLI, the command might need to start with phonegap (i.e. phonegap cordova rm android)
                                        • 21. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                          Ritz.Meritz
                                          Hi there! @jcesarmobile_
                                          I tried with both of your plugins and code samples...right after I have installed the plugin the app stops building.
                                          the errors .....
                                          * What went wrong:
                                          Execution failed for task ':app:processDebugGoogleServices'.
                                          > File google-services.json is missing. The Google Services Plugin cannot functi
                                          on without it.
                                             Searched Location:
                                            E:\phonegap\cobraFinal\platforms\android\app\src\debug\google-services.json
                                            E:\phonegap\cobraFinal\platforms\android\app\google-services.json
                                          * Try:
                                          BUILD FAILED in 1s
                                              at ChildProcess.whenDone (E:\phonegap\cobraFinal\platforms\android\cordova\n
                                          (node:2464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This
                                          (node:2464) [DEP0018] DeprecationWarning: Unhandled promise rejections are depre
                                          E:\phonegap\cobraFinal>phonegap build android --verbose
                                          to the project
                                          droid platform
                                          \cobraFinal\platforms\android\app\src\main\res\xml\config.xml
                                          Wrote out android application name "CobraPost" to E:\phonegap\cobraFinal\platfor
                                          Wrote out Android package name "com.izone.cobrapost" to E:\phonegap\cobraFinal\p
                                          latforms\android\app\src\main\java\com\izone\cobrapost\MainActivity.java
                                          No scripts found for hook "after_prepare".
                                          studio
                                          Running command: cmd "/s /c "E:\phonegap\cobraFinal\platforms\android\gradlew.ba
                                          t cdvBuildDebug -b E:\phonegap\cobraFinal\platforms\android\build.gradle -Dorg.g
                                          radle.daemon=true -Dorg.gradle.jvmargs=-Xmx2048m -Pandroid.useDeprecatedNdk=true
                                          published.
                                                  at build_4uwrcpdeqkfkxxykfqvbn9ysv.run(E:\phonegap\cobraFinal\platforms\
                                          android\app\build.gradle:144)
                                          stead.
                                          registerResGeneratingTask is deprecated, use registerGeneratedFolders(FileCollec
                                          tion)
                                          tion)
                                          :CordovaLib:compileDebugAidl UP-TO-DATE
                                          UP-TO-DATE
                                          :CordovaLib:packageDebugResources UP-TO-DATE
                                          :CordovaLib:processDebugManifest UP-TO-DATE
                                          :CordovaLib:processDebugResources UP-TO-DATE
                                          :CordovaLib:compileDebugJavaWithJavac UP-TO-DATE
                                          O-DATE
                                          :app:preDebugBuild
                                          UP-TO-DATE
                                          :app:compileDebugRenderscript UP-TO-DATE
                                          :app:checkDebugManifest UP-TO-DATE
                                          UP-TO-DATE
                                          :app:generateDebugResValues UP-TO-DATE
                                          Parsing json file: E:\phonegap\cobraFinal\platforms\android\app\google-services.
                                          json
                                          :app:splitsDiscoveryTaskDebug UP-TO-DATE
                                          :app:processDebugResources
                                          :app:generateDebugSources
                                          :app:javaPreCompileDebug
                                          :app:compileDebugJavaWithJavac
                                          Note: Some input files use or override a deprecated API.
                                          Note: Recompile with -Xlint:deprecation for details.
                                          Note: Some input files use unchecked or unsafe operations.
                                          Note: Recompile with -Xlint:unchecked for details.
                                          :app:compileDebugNdk
                                          NO-SOURCE
                                          :app:compileDebugSources
                                          :CordovaLib:mergeDebugShaders UP-TO-DATE
                                          :CordovaLib:compileDebugShaders UP-TO-DATE
                                          :CordovaLib:generateDebugAssets UP-TO-DATE
                                          :CordovaLib:mergeDebugAssets UP-TO-DATE
                                          :app:mergeDebugShaders UP-TO-DATE
                                          :app:compileDebugShaders UP-TO-DATE
                                          :app:generateDebugAssets UP-TO-DATE
                                          :app:mergeDebugAssets
                                          :app:extractTryWithResourcesSupportJarDebug UP-TO-DATE
                                          :app:transformClassesWithStackFramesFixerForDebug
                                          :app:transformClassesWithDexBuilderForDebug
                                          :app:transformClassesWithMultidexlistForDebug
                                          FAILED
                                          * What went wrong:
                                          Execution failed for task ':app:transformClassesWithMultidexlistForDebug'.
                                          > java.io.IOException: Can't write [E:\phonegap\cobraFinal\platforms\android\app
                                          \build\intermediates\multi-dex\debug\componentClasses.jar] (Can't read [E:\phone
                                          gap\cobraFinal\platforms\android\app\build\intermediates\transforms\desugar\debu
                                          g\17.jar(;;;;;;**.class)] (Duplicate zip entry [17.jar:android/support/v4/media/
                                          RatingCompat$1.class]))
                                          39 actionable tasks: 11 executed, 28 up-to-date
                                          * Try:
                                          BUILD FAILED in 19s
                                          Command finished with error code 1: cmd /s /c "E:\phonegap\cobraFinal\platforms\
                                          android\gradlew.bat cdvBuildDebug -b E:\phonegap\cobraFinal\platforms\android\bu
                                          ild.gradle -Dorg.gradle.daemon=true -Dorg.gradle.jvmargs=-Xmx2048m -Pandroid.use
                                          DeprecatedNdk=true"
                                          (node:3560) UnhandledPromiseRejectionWarning: Error: cmd: Command failed with ex
                                          * What went wrong:
                                          * Try:
                                          BUILD FAILED in 19s
                                          (node:3560) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This
                                          (node:3560) [DEP0018] DeprecationWarning: Unhandled promise rejections are depre
                                          • 22. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                            You are building locally, right?
                                            Which CLI version are you using?
                                            looks like the resource-file tag I have in the config.xml for copying the google-services.json files is not working for you, so you might have an old CLI that doesn't support it.
                                            • 23. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                              Ritz.Meritz Level 1
                                              yup...building locally
                                              CLI version (phonegap) = 8.0
                                              Android version = 7.0
                                              • 24. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                                No idea why you don't get the files then, with that version it should work.
                                                • 25. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                                  Ritz.Meritz Level 1
                                                  a funny thing just happened...i removed phonegap and reinstalled it using the following command
                                                  npm install -g phonegap@latest
                                                  After that i created a new project. Then i deleted the following line from the config file
                                                  And i ran the build command....It did not work
                                                  Then i added the line back changed the minSdkVersion value to 16 (as it was working fine previously before uninstalling)
                                                  guess what...it did not work either
                                                  Then i Changed the value to 19 ...and it worked!
                                                  Now with the push notifications...i am trying your samples and those plugins once again....i hope it works now... Thanks for your help
                                                  • 26. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                                    Ritz.Meritz Level 1
                                                    wow...now i am getting the following errors after successfully installing the plugin cordova-plugin-fcm
                                                    For more details visit https://github.com/fechanique/cordova-plugin-fcm
                                                    Saved plugin info for "cordova-plugin-fcm" to config.xml
                                                    E:\phonegap\cobra2>phonegap build android --verbose
                                                    Checking config.xml and package.json for saved platforms that haven't been added to the project
                                                    Checking for any plugins added to the project that have not been installed in android platform
                                                    No differences found between plugins added to project and installed in android platform. Continuing...
                                                    Generating platform-specific config.xml from defaults for android at E:\phonegap\cobra2\platforms\android\app\src\main\res\xml\config.xml
                                                    Merging and updating files from [www, platforms\android\platform_www] to platforms\android\app\src\main\assets\www
                                                    Wrote out android application name "cobra2" to E:\phonegap\cobra2\platforms\android\app\src\main\res\values\strings.xml
                                                    android-versionCode not found in config.xml. Generating a code based on version in config.xml (1.0.0): 10000
                                                    Wrote out Android package name "com.izone.cobrapost" to E:\phonegap\cobra2\platforms\android\app\src\main\java\com\izone\cobrapost\MainActivity.j ava
                                                    Executing script found in plugin cordova-plugin-fcm for hook "after_prepare": pl
                                                    ugins\cordova-plugin-fcm\scripts\fcm_config_files_process.js
                                                    (node:1016) UnhandledPromiseRejectionWarning: TypeError [ERR_INVALID_ARG_TYPE]:
                                                    The "chunk" argument must be one of type string or Buffer
                                                        at validChunk (_stream_writable.js:253:10)
                                                        at Socket.Writable.write (_stream_writable.js:288:21)
                                                        at Socket.stream.write (C:\Users\Ritesh Singh\AppData\Roaming\npm\node_modules\phonegap\node_modules\ansi\lib\newlines.js:36:21)
                                                        at Object.<anonymous> (E:\phonegap\cobra2\plugins\cordova-plugin-fcm\scripts
                                                    \fcm_config_files_process.js:80:24)
                                                        at Module._compile (module.js:649:30)
                                                        at Object.Module._extensions..js (module.js:660:10)
                                                        at Module.load (module.js:561:32)
                                                        at tryModuleLoad (module.js:501:12)
                                                        at Function.Module._load (module.js:493:3)
                                                        at Module.require (module.js:593:17)
                                                    (node:1016) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This
                                                    (node:1016) [DEP0018] DeprecationWarning: Unhandled promise rejections are depre
                                                    • 27. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                                      Ritz.Meritz Level 1
                                                      hi,
                                                      thanks for helping me so far... I am using your sample code and the plugin phonegap-plugin-push and it seems to be working
                                                      -I am able to build the apk
                                                      -I am also able to get the token which is (from one of the devices)
                                                      fScLbvQvneU:APA91bGTzHMBOtO8DtDRH3We38etNSaz5rPvX4B2-IdjtxcvIJSr1zeGRtCPDlmaV1sWkG-twYqj8u Yfs6y7T_i7lcf9Us7SCFrtQxrGt7QfbYAIyZSMEx8uX6ZstWN9u-RJw8PydVF5
                                                      but I am not able to send the notification to this token it shows me the below error
                                                      The request's Authentication (Server-) Key contained an invalid or malformed FCM-Token (a.k.a. IID-Token).
                                                      Error 401
                                                      also, below is my code
                                                      receivedEvent: function(id) {
                                                              console.log('Received Event: ' + id);
                                                              var push = PushNotification.init({
        android: {
        ios: {
        alert: "true",
        badge: true,
        sound: 'false'
                                                              push.on('registration', function (data) {
                                                      alert(data.registrationId);
        $("#registration").val(data.registrationId);
        console.log(data.registrationType);
        var regId = document.getElementById("registration").appendChild(document.createTextNode(data.registra tionId));
                                                      //navigator.notification.alert(regId);
                                                      //regFcmId(regId);
                                                      regFcmId(regId);
                                                      function regFcmId(reg){
                                                      var unid = device.uuid;
                                                      var regId = $("#registration").val();
                                                      //alert(regId);
                                                      $.ajax({
                                                         type: "POST",
                                                         url: "http://cobrapost1.adhocteam.com/app_data/regFcm.php",
                                                         dataType:'json',
                                                         data:{unid:unid,fcm:regId}, // serializes the form's elements.
                                                         success: function(response)
                                                              push.on('notification', function (data) {
        var ul = document.getElementById("pushList");
        var li = document.createElement("li");
        li.appendChild(document.createTextNode(data.message));
        ul.appendChild(li);
        console.log(data.message);
        console.log(data.title);
        console.log(data.count);
        console.log(data.sound);
        console.log(data.image);
        console.log(data.additionalData);
                                                      app.initialize();
                                                      what am i doing wrong?
                                                      • 28. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                                        Try removing the fScLbvQvneU: part
                                                        Also, make sure you are using your own google-services.json and GoogleService-Info.plist instead of mine
                                                        • 29. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                                          Ritz.Meritz Level 1
                                                          Hi...thanks for replying
                                                          Yes I did that..I have been trying all sort of ways... I am using my own google-services.json file and my project does not have GoogleService-Info.plist file ...I tried the token with and without fScLbvQvneU: yet it shows me the same error...
                                                          I am glad tho as now atleast the plugin is getting installed and even the build is compiling... I think the server API key that I am using isn't correct or from the same project so today I will be trying that once I reach my desk. Will update you once I am through
                                                          • 30. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                                            Try sending the push message from firebase console, so you make sure the API key isn't the problem.
                                                            I got a different error when I removed that part (but it's because I used your token, not one of mine, and the error is related to not registered token)
                                                            • 31. Re: phonegap build android --debug shows no errors but generates no build...all of a sudden three days agi
                                                              Ritz.Meritz Level 1
                                                              it's working fine now!!
                                                              the token was fine...fKQEy7rWKhA:APA91bEWRP9H9EDoKrS-tqcMj0fNdEchrrkeX3R05kdxzciSQ3w0Dx_pdvjb9ugOP9l7WF Lwcs4AFE80lBHRJ7iR8mAowWqqrfgTPWkrzsh-4UcWjrrM8DKTlNqIARDmxao-eUy2QvTj
                                                              the problem was with the api key i replaced it with Legacy Server Key (earlier it was server key) from my firebase console...
                                                              now the only problem is how do i wrap the text in the notification body text...as beyond certain characters of the notification body it hides...i cant type 100 characters as notification body? do you have any link whether how do I open a specific html page inside my app once the notification is clicked?
                                                              Thanks a lot!
