7 Replies Latest reply on Jun 27, 2008 5:45 PM by stickmedia
    Problems running Flex on OSX 10.5
    Coffein_42
      here is the log:
      !ENTRY org.eclipse.equinox.app 2008-06-23 10:36:07.702
      !MESSAGE Product com.adobe.flexbuilder.standalone.product could not be found.
      !ENTRY org.eclipse.osgi 4 0 2008-06-23 10:36:07.713
      !MESSAGE Application error
      !STACK 1
      java.lang.RuntimeException: No application id has been found.
      at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer. java:236)
      at org.eclipse.equinox.internal.app.EclipseAppContainer.start(EclipseAppContainer.java:98)
      at org.eclipse.equinox.internal.app.Activator.addingService(Activator.java:112)
      at org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(ServiceTracker.java:1064)
      at org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialServices(ServiceTracker.java:926 )
      at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:330)
      at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:274)
      at org.eclipse.equinox.internal.app.Activator.start(Activator.java:54)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:9 99)
      at java.security.AccessController.doPrivileged(Native Method)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:993)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:9 74)
      at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:346)
      at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:260)
      at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
      at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:111)
      at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :417)
      at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoade r.java:189)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:34 0)
      at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackag e.java:37)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java :405)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:369)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:357)
      at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.jav a:83)
      at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
      at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:374)
      at org.eclipse.core.internal.runtime.PlatformActivator.startAppContainer(PlatformActivator.j ava:47)
      at org.eclipse.core.internal.runtime.PlatformActivator.start(PlatformActivator.java:32)
      at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:350)
      at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1118)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManage r.java:634)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java :508)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelMana ger.java:282)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManage r.java:468)
      at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:195)
      at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:297)
      !ENTRY org.eclipse.osgi 2 0 2008-06-23 10:36:07.727
      !MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
      !SUBENTRY 1 org.eclipse.osgi 2 0 2008-06-23 10:36:07.728
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.template.ui_3.0.4.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.template.ui 2 0 2008-06-23 10:36:07.728
      !MESSAGE Missing required bundle org.eclipse.pde.ui_[3.2.0,4.0.0).
      !ENTRY org.eclipse.osgi 2 0 2008-06-23 10:36:07.728
      !MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.template.ui_3.0.4.200706071.jar [51] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.template.ui 2 0 2008-06-23 10:36:07.729
        • 1. Problems running Flex on OSX 10.5
          Karl_Sigiscar_1971 Level 3
          I use Flex Builder 3 Professional on MacOS X 10.5.3 without problem. Do you use the beta or the release ?
          • 2. Re: Problems running Flex on OSX 10.5
            Coffein_42 Level 1
            downloaded the trial yesterday.
            • 3. Re: Problems running Flex on OSX 10.5
              Is this the plugin version for Eclipse or the standalone version ?
              If this is the plugin version, do you use Eclipse or MyEclipse ?
              I personally use the standalone version.
              • 4. Re: Problems running Flex on OSX 10.5
                Coffein_42 Level 1
                i use the standalone version. i tried it serveral times. unistall, reinstall... no luck :(
                • 5. Re: Problems running Flex on OSX 10.5
                  Try and see if you can use other Java based applications.
                  If you cannot, you have a problem with your java install.
                  • 6. Re: Problems running Flex on OSX 10.5
                    Coffein_42 Level 1
                    other java-apps work. i'm using java SE 6(64bit) but even if i use an older version i got the same error.
                    • 7. Re: Problems running Flex on OSX 10.5
                      stickmedia
                      Same issues here running a purchased version of Flex 3 Pro:
                      Exception Type: EXC_BAD_ACCESS (SIGBUS)
                      Exception Codes: 0x000000000000000a, 0x00000000453ba000
                      Crashed Thread: 16
                      Application Specific Information:
                      Java information:
                      Version: Java HotSpot(TM) Client VM (1.5.0_13-119 mixed mode)
                      Virtual Machine version: Java HotSpot(TM) Client VM (1.5.0_13-119) for macosx-x86, built on Sep 28 2007 23:59:21 by root with gcc 4.0.1 (Apple Inc. build 5465)
                      Exception type: Bus Error (0xa) at pc=0xffff0bac
                      Current thread (0x09024f10): JavaThread "Worker-3" [_thread_in_native, id=9543680]
                      Stack: [0xb0857000,0xb08d7000)
                      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
                      J java.nio.Bits.copyToByteArray(JLjava/lang/Object;JJ)V
                      J java.nio.DirectByteBuffer.get([BII)Ljava/nio/ByteBuffer;
                      J java.util.zip.ZipFile$MappedZipFileInputStream.read([BII)I
                      J java.util.zip.ZipFile$2.fill()V
                      J java.util.zip.InflaterInputStream.read([BII)I
                      v ~RuntimeStub::alignment_frame_return Runtime1 stub
                      j sun.misc.Resource.getBytes()[B+30
                      j java.net.URLClassLoader.defineClass(Ljava/lang/String;Lsun/misc/Resource;)Ljava/lang/Clas s;+219
                      j java.net.URLClassLoader.access$100(Ljava/net/URLClassLoader;Ljava/lang/String;Lsun/misc/R esource;)Ljava/lang/Class;+3
                      j java.net.URLClassLoader$1.run()Ljava/lang/Object;+43
                      v ~StubRoutines::call_stub
                      j java.security.AccessController.doPrivileged(Ljava/security/PrivilegedExceptionAction;Ljav a/security/AccessControlContext;)Ljava/lang/Object;+0
                      j java.net.URLClassLoader.findClass(Ljava/lang/String;)Ljava/lang/Class;+13
                      j com.adobe.flexbuilder.project.sdks.FlexClassLoader.findClass(Ljava/lang/String;)Ljava/lan g/Class;+19
                      J java.lang.ClassLoader.loadClass(Ljava/lang/String;Z)Ljava/lang/Class;
                      j com.adobe.flexbuilder.project.sdks.FlexClassLoader.loadClass(Ljava/lang/String;Z)Ljava/la ng/Class;+3
                      J java.lang.ClassLoader.loadClassInternal(Ljava/lang/String;)Ljava/lang/Class;
                      j com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder.setup(Lcom/adobe/fl exbuilder/project/actionscript/IActionScriptProject;Lorg/eclipse/core/resources/IFile;Lcom /adobe/flexbuilder/project/compiler/internal/FlexIncrementalBuilder;Lcom/adobe/flexbuilder /project/compiler/LibraryCacheProxy;)V+28
                      j com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuilder.setup(Lcom/adobe/flexbuild er/project/actionscript/IActionScriptProject;Lorg/eclipse/core/resources/IFile;Lcom/adobe/ flexbuilder/project/compiler/internal/FlexIncrementalBuilder;Lcom/adobe/flexbuilder/projec t/compiler/LibraryCacheProxy;)V+19
                      j com.adobe.flexbuilder.project.compiler.BuilderFactory.createBuilder(Lcom/adobe/flexbuilde r/project/actionscript/IActionScriptProject;Lorg/eclipse/core/resources/IFile;Lcom/adobe/f lexbuilder/project/compiler/internal/FlexIncrementalBuilder;Lcom/adobe/flexbuilder/project /compiler/LibraryCacheProxy;)Lcom/adobe/flexbuilder/project/compiler/IBuilder;+102
                      j com.adobe.flexbuilder.project.compiler.BuilderManager.getBuilder(Lcom/adobe/flexbuilder/p roject/actionscript/IActionScriptProject;Lorg/eclipse/core/resources/IFile;Lcom/adobe/flex builder/project/compiler/internal/FlexIncrementalBuilder;Lcom/adobe/flexbuilder/project/co mpiler/LibraryCacheProxy;)Lcom/adobe/flexbuilder/project/compiler/IBuilder;+111
                      j com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.preBuild(Lorg/ecli pse/core/resources/IFile;Lcom/adobe/flexbuilder/project/compiler/LibraryCacheProxy;)Lcom/a dobe/flexbuilder/project/compiler/IBuilder;+10
                      j com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.buildItem(Lorg/eclipse /core/resources/IFile;ILcom/adobe/flexbuilder/project/compiler/internal/GeneratedHTMLResou rces;Lorg/eclipse/core/resources/IContainer;Lcom/adobe/flexbuilder/project/compiler/Librar yCacheProxy;Lorg/eclipse/core/runtime/IProgressMonitor;)V+279
                      j com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(I[Lorg/eclipse/c ore/resources/IFile;Lorg/eclipse/core/runtime/IProgressMonitor;)[Lorg/eclipse/core/resourc es/IProject;+589
                      j com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(ILjava/util/ Map;Lorg/eclipse/core/runtime/IProgressMonitor;)[Lorg/eclipse/core/resources/IProject;+149
                      j org.eclipse.core.internal.events.BuildManager$2.run()V+33
                      j org.eclipse.core.runtime.SafeRunner.run(Lorg/eclipse/core/runtime/ISafeRunnable;)V+5
                      j org.eclipse.core.internal.events.BuildManager.basicBuild(ILorg/eclipse/core/resources/Inc rementalProjectBuilder;Ljava/util/Map;Lorg/eclipse/core/runtime/MultiStatus;Lorg/eclipse/c ore/runtime/IProgressMonitor;)V+301
                      j org.eclipse.core.internal.events.BuildManager.basicBuild(Lorg/eclipse/core/resources/IPro ject;I[Lorg/eclipse/core/resources/ICommand;Lorg/eclipse/core/runtime/MultiStatus;Lorg/ecl ipse/core/runtime/IProgressMonitor;)V+62
                      j org.eclipse.core.internal.events.BuildManager$1.run()V+24
                      j org.eclipse.core.internal.events.BuildManager.basicBuild(Lorg/eclipse/core/resources/IPro ject;ILorg/eclipse/core/runtime/MultiStatus;Lorg/eclipse/core/runtime/IProgressMonitor;)V+ 98
                      j org.eclipse.core.internal.events.BuildManager.basicBuildLoop([Lorg/eclipse/core/resources /IProject;[Lorg/eclipse/core/resources/IProject;ILorg/eclipse/core/runtime/MultiStatus;Lor g/eclipse/core/runtime/IProgressMonitor;)V+97
                      j org.eclipse.core.internal.events.BuildManager.build(ILorg/eclipse/core/runtime/IProgressM onitor;)Lorg/eclipse/core/runtime/IStatus;+148
                      j org.eclipse.core.internal.events.AutoBuildJob.doBuild(Lorg/eclipse/core/runtime/IProgress Monitor;)V+88
                      j org.eclipse.core.internal.events.AutoBuildJob.run(Lorg/eclipse/core/runtime/IProgressMoni tor;)Lorg/eclipse/core/runtime/IStatus;+48
                      j org.eclipse.core.internal.jobs.Worker.run()V+31
                      Java Threads: ( => current thread )
                      =>0x09024f10 JavaThread "Worker-3" [_thread_in_native, id=9543680]
                      0x09024950 JavaThread "Worker-2" [_thread_blocked, id=9265152]
                      0x09023f50 JavaThread "Thread-1" [_thread_blocked, id=9550848]
                      0x0901fff0 JavaThread "Worker-1" [_thread_blocked, id=9315840]
                      0x0901d1b0 JavaThread "Worker-0" [_thread_blocked, id=9261568]
                      0x09013e80 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=8860672]
                      0x09013980 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=8855040]
                      0x09012f30 JavaThread "State Data Manager" daemon [_thread_blocked, id=8585216]
                      0x09009040 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=8512512]
                      0x09008570 JavaThread "CompilerThread0" daemon [_thread_blocked, id=8508928]
                      0x09008100 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=8500736]
                      0x09007810 JavaThread "Finalizer" daemon [_thread_blocked, id=8497152]
                      0x09007410 JavaThread "Reference Handler" daemon [_thread_blocked, id=8493568]
                      0x09001560 JavaThread "main" [_thread_in_vm, id=-1608106080]
                      Other Threads:
                      0x09006b60 VMThread [id=8402944]
                      0x09009c40 WatcherThread [id=8516096]
                      VM state:not at safepoint (normal execution)
                      VM Mutex/Monitor currently owned by a thread: None
                      Heap
                      def new generation total 9088K, used 6276K [0x0d580000, 0x0df50000, 0x0fce0000)
                      eden space 8128K, 69% used [0x0d580000, 0x0db0a638, 0x0dd70000)
                      from space 960K, 62% used [0x0dd70000, 0x0de06d98, 0x0de60000)
                      to space 960K, 0% used [0x0de60000, 0x0de60000, 0x0df50000)
                      tenured generation total 121024K, used 2923K [0x0fce0000, 0x17310000, 0x2d580000)
                      the space 121024K, 2% used [0x0fce0000, 0x0ffbac18, 0x0ffbae00, 0x17310000)
                      compacting perm gen total 65536K, used 13595K [0x2d580000, 0x31580000, 0x3d580000)
                      the space 65536K, 20% used [0x2d580000, 0x2e2c7068, 0x2e2c7200, 0x31580000)
                      No shared spaces configured.
                      Virtual Machine arguments:
                      JVM args: -Xdock:icon=../Resources/flexbuilder.icns -Xdock:name=Flex Builder -XstartOnFirstThread -Xms128m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m -Dorg.eclipse.swt.internal.carbon.smallFonts -Dorg.eclipse.swt.internal.carbon.noFocusRing
                      Java command: <unknown>
                      launcher type: generic
                      What's up with Adobe products. So fragile these days...
