• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
ipad pro 12.9 ios simulator resolution
Contributor ,
Mar 15, 2018 Mar 15, 2018
Hello,
I'm seeing the resolution reported as 2048x1536 when testing in the iOS simulator, when it shold be 2732x2048.
I thought this was a launch image issue after research. I'm not sure if the launch image is working due to the lag of the simulator. Is there a way to peek into the ipa file to see the included launch images to ensure they are packaging correctly via xcode or another way?
I've included Default-Landscape-1024w-1366h@2x~ipad.png and Default-Portrait-1024w-1366h@2x~ipad.png, but it's still reporting the smaller rez.
I've tried both including an entire folder of launch images via the command: "adt -package ... project.swf icons defaultimgs\." Is this syntax correct for including the contents of an entire folder to the root package (folder\.)?
I've also tried simply listing the full two filenames at the end of the adt command but still the rez is reporting smaller.
Is the device operating at the smaller rez? Or is air just reporting this erroneously?
Thanks for reading,
-cybo
TOPICS
Development
Views
716
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor , Mar 15, 2018 Mar 15, 2018
Thanks for your reply el111.
I did have the launch images made but my syntax for ADT was incorrect.
The syntax to include a folder in the root is follows: "adt -package ... project.swf icons -C defaultimgs ."
This will properly include the contents of defaultimgs in the root of the package, which is necessary for iOS to find them. It's now properly reporting the right resolution.
Also for others searching that my end up here, to peek in an IPA, just rename it to ZIP and extract. I knew this but ha
Votes
Translate
Translate
Engaged ,
see Launch Images on iOS with Adobe AIR
This says ipad pro 12.9 images should be named
and
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
Also for others searching that my end up here, to peek in an IPA, just rename it to ZIP and extract. I knew this but had forgotten.
Thanks again for your reply and link.
-cybo
Votes
Translate
Translate
Report
Report
