1 Reply Latest reply on Jun 29, 2008 11:23 AM by CatBandit
    Can no longer record audio
    ClydeMJ
      I click audio>record this slide. Info box briefly appears, but the screen to record, etc. does not appear. What has changed from yesterday?
        • 1. Re: Can no longer record audio
          CatBandit Level 3
          ClydeMJ said...
          We have no way of knowing that, Clyde. Actually that is the question we would normally ask you at this point in the discussion.
          Are you still having this problem? Have you tried shutting down Captivate and the computer, then restarting? Perhaps another application is using the microphone, and if so, that might help.
          Another thought is that you might need to go into the Control panel and make changes to the "Sounds and Audio Devices" settings.
          If none of this helps, you should probably include more detail about your setup, and the details of the problem, to help us help you. Thanks!!
          Larry
