• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RtMouseText no longer loads after latest update
Explorer ,
Mar 16, 2018 Mar 16, 2018
The following code has worked for the past 6 months -- but the 0.1 update seems to have broken it
var fileMenu = app.menus.item("$ID/RtMouseText");
fileMenu.menuItems.add(menuAction,LocationOptions.AT_BEGINNING);
var fileMenu2 = app.menus.item("$ID/RtMouseSpellSuggestions");
  fileMenu2.menuItems.add(menuAction,LocationOptions.AT_BEGINNING);
I get an error (two actually -- one for each menu) that neither installed.
Anyone else experience this? Any suggestions what to do?
TIA
TOPICS
Scripting
Views
489
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Hi TIA,
hm…
I have no problem with "$ID/RtMouseText".
For example: A startup script written by Dirk Becker that is adding the menu action for "$ID/Apply no break" to the context menu "$ID/RtMouseText" is still working with my CC 2018.1 on Mac OS X 10.11.6 without any problems.
What is defined in your variable menuAction ?
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Explorer ,
menuAction = app.scriptMenuActions.add(menuTitle);
and menuTitle is the text for the menu.
Is the script you mentioned available? I'd like to try it and see if it works...
Votes
Translate
Translate
Report
Report
Community Expert ,
akiva_atwood  wrote
… Is the script you mentioned available? I'd like to try it and see if it works...
See the link with my answer #2.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Community Expert ,
You could try Dirk's script:
menuitemNoBreak.jsx script for Adobe InDesign
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks. I'll give it a try
Votes
Translate
Translate
Report
Report
Guide ,
Mar 18, 2018 Mar 18, 2018
Note that the script reuses an existing hard-wired action.
A scriptMenuAction requires more code where things can go wrong, including a targetengine.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Here's the entire script:
#targetengine 'SSIsession';
var fTitle = "Add Style";
var selLength;
var theSel;
var fHandlersI = {
  'beforeDisplay' : function(event)
  try{
  event.target.enabled = (app.documents.length>0);
  catch(e){notify("RT003: \n"+e,2);}
        if(event.target.enabled){
            selLength=app.selection[0].characters.length;
            theSel=app.selection[0];
  'onInvoke' : function(event)
  try{
  app.doScript(addStyle, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "SmartStyleIt");
  catch(e){notify("RT004: \n"+e,2);}
var fHandlersStyle = {
          //alert(event.target.name);
          s=event.target.name;
          if(s.indexOf("pStyle")>0){
                ss=s.replace(" pStyle","");
                //alert(ss+"\r"+theSel.contents);
              theSel.appliedParagraphStyle=ss;
        else{
            ss=s.replace(" cStyle","");
          // alert(ss+"\r"+theSel.contents);
                theSel.appliedCharacterStyle=ss;
// THE MENU INSTALLER
var fMenuInstaller = fMenuInstaller||
(function(menuTitle,menuHandlers)
var menuAction = app.scriptMenuActions.add(menuTitle);
var event;
for( event in menuHandlers )
  menuAction.eventListeners.add(event,menuHandlers[event]);
// 3. Create the menu item
try{
fileMenu.menuSeparators.add(LocationOptions.AT_BEGINNING);
  fileMenu2.menuSeparators.add(LocationOptions.AT_BEGINNING);
catch(e){
  alert("failed to install RtMouseText");
return true;
})(fTitle, fHandlersI);
function installMenuItem(menuTitle,menuHandlers)
var event;
try{
catch(e){
return true;
function doStyle(){
    alert("assigned");
function addStyle(){
    styleName="";
    sel=app.selection[0];
    if(selLength==0){
        styleName=sel.appliedParagraphStyle.name+" pStyle";
    else{
        styleName=sel.appliedCharacterStyle.name+" cStyle";
    installMenuItem(styleName,fHandlersStyle);
It's a start up script. I get the error message alert ("failed to install") whenever it starts up AND when I use the menu item -- which works despite the error message
This behaviour is new -- just since the last update. Before that it worked fine without the error messages.
Votes
Translate
Translate
Report
Report
