0 Replies Latest reply on Jun 21, 2008 11:02 PM by Deep_1234
    Remote Object Error
    Deep_1234
      I am making use of Remote Object to communicate with Java. I get the following
      error:
      onGetSearchFailure [FaultEvent fault=[RPC Fault faultString="Send failed"
      faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error
      NetConnection.Call.Failed: HTTP: Status 500: url:
      'https://localhost:443/BADesktopWeb/messagebroker/amfsecure'"]
      messageId="59EDC7A9-8AC2-3E49-B5E9-AA448BA4BEAF" type="fault" bubbles=false
      cancelable=true eventPhase=2]
      What could the problem be? Please suggest a solution.
      Also, my server log says something like this :
      [6/22/08 1:33:37:456 EDT] 00000022 ServiceLogger I com.ibm.ws.ffdc.IncidentStreamImpl initialize FFDC0009I: FFDC opened incident stream file C:\Program Files\IBM\SDP70\runtimes\base_v61\profiles\AppSrv01\logs\ffdc\server1_65026502_08.06.22_0 1.33.37_0.txt
      [6/22/08 1:33:37:518 EDT] 00000022 ServiceLogger I com.ibm.ws.ffdc.IncidentStreamImpl resetIncidentStream FFDC0010I: FFDC closed incident stream file C:\Program Files\IBM\SDP70\runtimes\base_v61\profiles\AppSrv01\logs\ffdc\server1_65026502_08.06.22_0 1.33.37_0.txt
      [6/22/08 1:33:37:878 EDT] 00000022 PlatformMBean W Failed to activate MBean flex.runtime.BenefitAccess FDS WebApp:cell=NAMPCSSWVW0279Node01Cell,type=MessageBroker,node=NAMPCSSWVW0279Node01,process =server1,id=MessageBroker1[6/22/08 1:33:38:003 EDT] 00000022 ServiceLogger I com.ibm.ws.ffdc.IncidentStreamImpl open FFDC0009I: FFDC opened incident stream file C:\Program Files\IBM\SDP70\runtimes\base_v61\profiles\AppSrv01\logs\ffdc\server1_65026502_08.06.22_0 1.33.38_0.txt
      [6/22/08 1:33:38:143 EDT] 00000022 ServiceLogger I com.ibm.ws.ffdc.IncidentStreamImpl resetIncidentStream FFDC0010I: FFDC closed incident stream file C:\Program Files\IBM\SDP70\runtimes\base_v61\profiles\AppSrv01\logs\ffdc\server1_65026502_08.06.22_0 1.33.38_0.txt
      [6/22/08 1:33:38:206 EDT] 00000022 ServletWrappe E SRVE0100E: Did not realize init() exception thrown by servlet MessageBrokerServlet: flex.management.ManagementException: The MBean, 'flex.runtime.BenefitAccess FDS WebApp:type=MessageBroker,id=MessageBroker1', could not be registered because it is already registered.
      could this be a matter of concern??
      Thanks & Regards,
      Deepa
