I've been signing my documents without any problem, then yesterday I started getting "Forbidden. The operation could not be completed. Please try again." error when I try to sign on my desktop. I tried closing Adobe and restarting computer, no luck.
Thanks so much for responding.
You’re online help assisted me. I apparently had two id’s which they fixed so I no longer have the issue.
Thank you
Siobhan
[ad removed by moderator ]
Did you manage to find a solution to this problem? I cant seem to get it working again.
This same message is popping up for me when attempting to send PDF Doc for signature. It goes to 60% then the message comes up. Thanks
I have the same issues
Did you get a resolution?
Hi All,
Sorry for the delay in response.
Could you please confirm the Adobe application you are using to send the document for signature?
Did you check if the issue occurs with some particular document or with all?
Please share the exact steps you do to send the document for signature and the screenshot of the error message you get.
To share the screenshot, use the steps provided below:
- Click on the insert icon provided in the reply window as shown below:
- An Insert Image window will appear.
- Then click on Insert Image and browse the location where you have saved the screenshot file.
- Select the file and click on Open > Insert Image.
Please share the details asked above
We will be waiting for your response.
Regards,
Meenakshi
Thank you
Siobhan
This was resolved last night – thank you
Michelle Riggs
Branch Processor
NMLS# 450701
562 Lynnhaven Parkway, Suite 100
Virginia Beach, VA 23452
Direct: 757-729-8346
<tel:757-729-8346>eFax: 1-866-304-9256
<tel:1-866-304-9256>
michelle.riggs@fairwaymc.com<mailto:michelle.riggs@fairwaymc.com>
Confidentiality Notice: The information contained in and transmitted with this communication is strictly confidential, is intended only for the use of the intended recipient, and is the property of Fairway Independent Mortgage Corporation NMLS #2289 or its affiliates and subsidiaries. If you are not the intended recipient, you are hereby notified that any use of the information contained in or transmitted with the communication or dissemination, distribution, or copying of this communication is strictly prohibited by law. If you have received this communication in error, please immediately return this communication to the sender and delete the original message and any copy of it in your possession.
FL License Number LO53822. NC License Number I-180709. Fairway Independent Mortgage Corporation NMLS Entity ID #2289 (http://nmlsconsumeraccess.org/EntityDetails.aspx/company/2289). & VA License Number MLO-32756VA.
