Most recent scenario: Return from vacation, download 100GB of video, RAW, and JPG photos (bridge PhotoDownloader), browse a couple (presumed LARGE) folders, and the next day "DISC NOT EJECTED PROPERLY"
Too much troubleshooting to explain everything but is anyone else seeing this? Last year when this started, I ended up with 3 of 5 HDDs corrupt in like 2 weeks. Now left with 1 brand new G-Tech usb drive (2GB of6GB used) and the problem is back.
LOST: multiple SSD drive's in (USB) DOCK
LOST: LACIE 2BIG (thunderbolt) 6TB (2x 3TB seagate from HDD crisis) ie Backblaze lawsuit
LOST: SEAGATE 3TB MEDIA CENTRAL (Ethernet)
GTECH 2TB time capsule also wouldn't mount during this time but was being used for photo access in Bridge
Symptom starts will "Disk Not Ejected Properly" notification, however files appear to be fine, until one day the Disc just won't mount and everything is gone.
APPLE believes it is ADOBE issue, and wants me to "USE" my Mac without Adobe products, but the only thing I use my iMac for is photos.
I was able to manage all the recovery files and grouping (approx 1.5GB) in finder when the GTECH DRIVE was brand new with no problem, I then started moving them again in Bridge and had a couple lockups but no Disk errors.
16GB of RAM REMOVED to troubleshoot and still occurs
8GB of Apple ram currently and just occurred
Operating System wiped and reloaded clean still occurs
All software removed and reinstalled, updated still occurred
Suggestions from APPLE forums^
The thing I can't wrap my head around is whether I'm stressing the HDD by setting the bridge disk CACHE really large and/or should I be using a secondary disk for the cache? ALSO concerned about the resolution settings being to high? All variations have been attempted (while it was occurring last year) and I am now only using 1 disk to continue troubleshooting.
APPLE has been extremely helpful at the Genius Bar and through phone support and only found a burnt thunderbolt port. They weren't concerned about that, but I stopped using it anyway when I lost my RAID array to this corruption.
Last statement from level 2 at APPLE is that "ADOBE SOFTWARE REWRITES THE (KERNAL)" ?
That is why I am now here
Thoughts?
Thank You
Chris
Hi All,
We have released a new version of Adobe Bridge (CC 2019) on 15th October 2018. The new version build number is 9.0.0.204. This version is available to install via Adobe Creative Cloud application.
This Bridge update contains support for managing media cache files (https://helpx.adobe.com/bridge/using/media-cache.html).
Please check following link to know about all new features in Adobe Bridge CC 2019 - https://helpx.adobe.com/bridge/using/whats-new.html
You may need to update the Creative C
...Copy link to clipboard
i have never had a issue with high sierra and Bridge.
Your he first person I know that has this issue.
Have you tried manually copying your files to the the drive?
The GOOGLE search phrase to understand the widespread issue is “DISK NOT EJECTED PROPERLY”. Everyone is barking at Apple and most threads end unresolved. Only once did someone say that 2nd level got them a solution w a list of disconnecting from networks, changing IPs and wiping PList settings. BTW I did all that and it Still happened.
regarded the downloading of files the problem seems to only appear when bridge is involved by writting the Cache of 4 folders and 4 files for every CR2 file in a LARGE directory. Never have I seen the problem after the download, just after opening a large folder in Bridge, then the next morning after waking iMac I see “disk not ejected properly”
03/18/2018 6:00PM
This seems like it is going to continue until the drive is so corrupt it will no longer be readable.
I think this more a MAC OS issues then a Adobe Bridge issue.
APFS Bug in macOS High Sierra Can Cause Data Loss When Writing to Disk Images - Mac Rumors
The OP isn't writing to disk images.
As for the bug itself, this probably isn't Bridge. You are losing power to your drives and they are all shutting off. Get a battery backup.
iMac and every external drive have always been plugged into Battery Backup. Was concerned that the quality of the HDs may have something to do with these issues because I’ve never had a lot of confidence in external drives. I thought the thunderbolt interface would be more reliable that USB but the problem persists on all ports and many different hard drives.
For the iMac Video creators, are your HDDs lasting 2 3 4 years without these issues? Should I consider Enterprise Drives?
None of that should matter. I'm a former Mac Genius myself and have supported Macs for years. Usually when we see hard drive problems, its a power issue. If not that or bad cables, then you have a hardware problem with the computer. Even if Bridge was forcing a software eject, you wouldn't get that message. That is caused by a hardware/physical disconnect of the drive.
NEW and MOST RECENT ISSUE
BUGGING REPORT FROM BRIDGE CRASH... At least on this crash it hasn't corrupted any of my data ... YET. And following this crash the disc was not ejected. Also/again the 6TB GTECH drive is 3 months old (2TB used), new cable, plugged into a previously unused (thunderbolt USB3.0) port... with an adapter. plugged into a battery backup, set up to never sleep.
Process: Adobe Bridge CC 2018 [749]
Path: /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/MacOS/Adobe Bridge CC 2018
Identifier: com.adobe.bridge8
Version: 8.0.1.282 (8.0.1.282)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Bridge CC 2018 [749]
User ID: 501
Date/Time: 2018-03-21 16:02:03.345 -0400
OS Version: Mac OS X 10.13.3 (17D102)
Report Version: 12
Anonymous UUID: 04CD9739-08D2-A403-1C6F-38F89C5F2287
Time Awake Since Boot: 590000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000018
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Adobe Bridge CC 2018 [749]
VM Regions Near 0x18:
__TEXT 00000001001bd000-000000010122b000 [ 16.4M] r-x/rwx SM=COW /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/MacOS/Adobe Bridge CC 2018
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff7453477a __kill + 10
1 libsystem_platform.dylib 0x00007fff74666f5a _sigtramp + 26
2 ??? 000000000000000000 0 + 0
3 com.adobe.bridge8 0x00000001007874f7 0x1001bd000 + 6071543
4 com.adobe.bridge8 0x0000000100787355 0x1001bd000 + 6071125
5 com.apple.Foundation 0x00007fff4ec1b659 __NSFireTimer + 83
6 com.apple.CoreFoundation 0x00007fff4cadbdd4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
7 com.apple.CoreFoundation 0x00007fff4cadba47 __CFRunLoopDoTimer + 1095
8 com.apple.CoreFoundation 0x00007fff4cadb54a __CFRunLoopDoTimers + 346
9 com.apple.CoreFoundation 0x00007fff4cad2b4b __CFRunLoopRun + 2427
10 com.apple.CoreFoundation 0x00007fff4cad1f43 CFRunLoopRunSpecific + 483
11 com.apple.HIToolbox 0x00007fff4bde9e26 RunCurrentEventLoopInMode + 286
12 com.apple.HIToolbox 0x00007fff4bde9b96 ReceiveNextEventCommon + 613
13 com.apple.HIToolbox 0x00007fff4bde9914 _BlockUntilNextEventMatchingListInModeWithFilter + 64
14 com.apple.AppKit 0x00007fff4a0b4f5f _DPSNextEvent + 2085
15 com.apple.AppKit 0x00007fff4a84ab4c -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044
16 com.apple.AppKit 0x00007fff4a0a9d6d -[NSApplication run] + 764
17 com.adobe.bridge8 0x0000000100784b76 0x1001bd000 + 6060918
18 com.adobe.bridge8 0x000000010077dbb9 0x1001bd000 + 6032313
19 com.adobe.bridge8 0x000000010077dc8d 0x1001bd000 + 6032525
20 com.adobe.bridge8 0x00000001008612de 0x1001bd000 + 6963934
21 com.adobe.bridge8 0x00000001008619a5 0x1001bd000 + 6965669
22 libdyld.dylib 0x00007fff743e5115 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff7453505a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff744b075c nanosleep + 199
2 com.adobe.bridge8 0x0000000100c41408 0x1001bd000 + 11027464
3 com.adobe.bridge8 0x0000000100c2693c 0x1001bd000 + 10918204
4 com.adobe.bridge8 0x0000000100c41051 0x1001bd000 + 11026513
5 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
6 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
7 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 2:: cr_scratch
0 libsystem_kernel.dylib 0x00007fff74534cee __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff74671662 _pthread_cond_wait + 732
2 libc++.1.dylib 0x00007fff7241acb0 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
3 com.adobe.CameraRaw 0x00000001113d4423 0x110a1c000 + 10191907
4 com.adobe.CameraRaw 0x0000000111158251 0x110a1c000 + 7586385
Thread 3:: Mondo Worker
2 com.adobe.bridge8 0x00000001009d8c16 0x1001bd000 + 8502294
3 com.adobe.bridge8 0x00000001009dc045 0x1001bd000 + 8515653
4 com.adobe.bridge8 0x00000001009dbefb 0x1001bd000 + 8515323
5 com.adobe.bridge8 0x000000010086f522 0x1001bd000 + 7021858
6 com.apple.CoreServices.CarbonCore 0x00007fff4dc9e13a PrivateMPEntryPoint + 39
7 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
8 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
9 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 4:: Mondo Worker
Thread 5:: Mondo Worker
3 com.adobe.bridge8 0x0000000100a1c9f2 0x1001bd000 + 8780274
4 com.adobe.bridge8 0x000000010086f522 0x1001bd000 + 7021858
5 com.apple.CoreServices.CarbonCore 0x00007fff4dc9e13a PrivateMPEntryPoint + 39
6 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
7 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
8 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 6:
2 com.adobe.bridge8 0x000000010060d0fb 0x1001bd000 + 4522235
3 com.adobe.bridge8 0x000000010060c0be 0x1001bd000 + 4518078
4 com.adobe.bridge8 0x000000010060f3ab 0x1001bd000 + 4531115
5 com.adobe.bridge8 0x0000000100763815 0x1001bd000 + 5924885
Thread 7:
Thread 8:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fff74534f0a __recvfrom + 10
1 VulcanMessage5.dylib 0x00000001019de9a8 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2 VulcanMessage5.dylib 0x00000001019ddd6c vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3 VulcanMessage5.dylib 0x00000001019dd064 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4 VulcanMessage5.dylib 0x00000001019dcf28 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5 VulcanMessage5.dylib 0x00000001019d7b67 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6 VulcanMessage5.dylib 0x00000001019d85f6 vcfoundation::io::Serializer::InternalDeserialize() + 30
7 VulcanMessage5.dylib 0x00000001019d7f8f vcfoundation::io::Serializer::Deserialize() + 9
8 VulcanMessage5.dylib 0x00000001019dc014 vcfoundation::ncomm::Connection::ReadIn() + 22
9 VulcanMessage5.dylib 0x00000001019dba6d vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10 VulcanMessage5.dylib 0x00000001019db75a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11 VulcanMessage5.dylib 0x00000001019db6ad vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12 VulcanMessage5.dylib 0x00000001019cdb5a adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13 VulcanMessage5.dylib 0x00000001019ccf01 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 523
14 VulcanMessage5.dylib 0x00000001019dc8ac vcfoundation::thread::AbstractThread::Run() + 72
15 VulcanMessage5.dylib 0x00000001019de7a9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
17 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
18 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 9:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff7452b7c2 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff7452acdc mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff4cad3575 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff4cad28c7 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff4cad1f43 CFRunLoopRunSpecific + 483
5 com.apple.CFNetwork 0x00007fff4bc4af84 -[__CoreSchedulingSetRunnable runForever] + 722
6 com.apple.Foundation 0x00007fff4ebb1ee8 __NSThread__start__ + 1197
Thread 10:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff74534fca __select + 10
1 com.apple.CoreFoundation 0x00007fff4cb0d59b __CFSocketManager + 635
2 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
3 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
4 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 11:: Mondo Worker
3 com.adobe.bridge8 0x00000001009d0e93 0x1001bd000 + 8470163
4 com.adobe.bridge8 0x00000001009d0e30 0x1001bd000 + 8470064
Thread 12:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff4a1f23c8 _NSEventThread + 184
Thread 13:: MPSupport Worker
2 MultiProcessor Support 0x000000010ebfa0fb boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 59
3 MultiProcessor Support 0x000000010ebfa01b ThreadFunctor::operator()() + 203
4 MultiProcessor Support 0x000000010ec1bf45 boost::(anonymous namespace)::thread_proxy(void*) + 184
Thread 14:: MPSupport Worker
Thread 15:: MPSupport Worker
Thread 16:
2 com.adobe.headlights.LogSessionFramework 0x000000011f5509dc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3 com.adobe.headlights.LogSessionFramework 0x000000011f54f2ff boost::this_thread::hiden::sleep_for(timespec const&) + 191
4 com.adobe.headlights.LogSessionFramework 0x000000011f4fcd89 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5 com.adobe.headlights.LogSessionFramework 0x000000011f4cbaad RealTimeProcessor::WorkerThread(int, int) + 3633
6 com.adobe.headlights.LogSessionFramework 0x000000011f54e679 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 17:
2 com.adobe.headlights.LogSessionFramework 0x000000011f4fde82 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3 com.adobe.headlights.LogSessionFramework 0x000000011f4fce0b void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4 com.adobe.headlights.LogSessionFramework 0x000000011f4fc8de IdleTimeLogger::IdleTimeWorkerThread() + 2804
5 com.adobe.headlights.LogSessionFramework 0x000000011f54e679 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 18:
0 libsystem_kernel.dylib 0x00007fff7452b7fe semaphore_wait_trap + 10
1 com.adobe.bridge8 0x00000001002af827 0x1001bd000 + 993319
2 com.adobe.bridge8 0x000000010075d26f 0x1001bd000 + 5898863
3 com.adobe.bridge8 0x000000010075d04e 0x1001bd000 + 5898318
4 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
5 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
6 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 19:
Thread 20:
Thread 21:
Thread 22:
2 com.apple.CoreServices.CarbonCore 0x00007fff4dcc2734 TSWaitOnCondition + 108
3 com.apple.CoreServices.CarbonCore 0x00007fff4dcc2933 TSWaitOnConditionTimedRelative + 171
4 com.apple.CoreServices.CarbonCore 0x00007fff4dc9dd1f MPWaitOnQueue + 192
5 com.adobe.dvacore.framework 0x000000010a4109e8 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::AllocatedFunctionT<boost::function<void ()> > >&, int) + 152
6 com.adobe.dvacore.framework 0x000000010a40e838 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 168
7 com.adobe.dvacore.framework 0x000000010a40b1c6 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 358
8 com.adobe.boost_threads.framework 0x000000010a107794 boost::(anonymous namespace)::thread_proxy(void*) + 164
9 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
10 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
11 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 23:
0 libsystem_kernel.dylib 0x00007fff74535ec2 kevent + 10
1 com.adobe.dvatransport.framework 0x000000010ac71f15 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 261
2 com.adobe.dvatransport.framework 0x000000010ac71b5c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 364
3 com.adobe.dvatransport.framework 0x000000010ac717b8 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 184
4 com.adobe.dvatransport.framework 0x000000010ac669f2 SkyConnectionEnv::MainLoop() + 162
5 com.adobe.dvatransport.framework 0x000000010ac66449 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 com.adobe.boost_threads.framework 0x000000010a107794 boost::(anonymous namespace)::thread_proxy(void*) + 164
Thread 24:
2 com.adobe.dvatransport.framework 0x000000010ac71ae6 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 246
4 com.adobe.dvatransport.framework 0x000000010ac7da7a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_io_service_runner>::run() + 42
5 com.adobe.dvacore.framework 0x000000010a3af863 boost_asio_detail_posix_thread_function + 19
Thread 25:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fff4c54495a HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 124
3 com.apple.audio.CoreAudio 0x00007fff4c5448cd HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 45
4 com.apple.audio.CoreAudio 0x00007fff4c541939 HALC_ProxyIOContext::IOWorkLoop() + 977
5 com.apple.audio.CoreAudio 0x00007fff4c54139c HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6 com.apple.audio.CoreAudio 0x00007fff4c5410de HALB_IOThread::Entry(void*) + 72
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
1 com.adobe.PDFL 0x00000001ec98c26f CTThreading::OSSemaphore::Wait() + 35
2 com.adobe.PDFL 0x00000001ec98d040 CTThreading::ThreadSafeQueue::Dequeue() + 42
3 com.adobe.PDFL 0x00000001ec98d0cf CTThreading::WorkerThread::Start() + 55
4 com.adobe.PDFL 0x00000001ec98cd4e CTThreading::PthreadStart(void*) + 30
Thread 33:
Thread 34:
Thread 35:
Thread 36:
0 libsystem_kernel.dylib 0x00007fff74535562 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff7467006a _pthread_wqthread + 1035
2 libsystem_pthread.dylib 0x00007fff7466fc4d start_wqthread + 13
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
0 IMSLib.dylib 0x0000000110691fa2 0x1105e6000 + 704418
1 IMSLib.dylib 0x000000011067a445 0x1105e6000 + 607301
2 IMSLib.dylib 0x0000000110673498 0x1105e6000 + 578712
3 IMSLib.dylib 0x0000000110673078 0x1105e6000 + 577656
4 IMSLib.dylib 0x00000001106484ac 0x1105e6000 + 402604
5 IMSLib.dylib 0x0000000110672b75 0x1105e6000 + 576373
6 IMSLib.dylib 0x0000000110647a3f 0x1105e6000 + 399935
7 IMSLib.dylib 0x0000000110646f4f 0x1105e6000 + 397135
8 IMSLib.dylib 0x00000001106abdce 0x1105e6000 + 810446
9 IMSLib.dylib 0x00000001106adabd 0x1105e6000 + 817853
10 IMSLib.dylib 0x0000000110635c84 0x1105e6000 + 326788
11 IMSLib.dylib 0x0000000110625276 0x1105e6000 + 258678
12 IMSLib.dylib 0x0000000110603ebd 0x1105e6000 + 122557
13 IMSLib.dylib 0x000000011062aaf2 0x1105e6000 + 281330
14 IMSLib.dylib 0x000000011060f562 0x1105e6000 + 169314
15 IMSLib.dylib 0x00000001105f6a90 0x1105e6000 + 68240
Thread 42:
0 libsystem_kernel.dylib 0x00007fff745369d2 write + 10
1 libstdc++.6.0.9.dylib 0x00007fff73fdc41d (anonymous namespace)::xwrite(int, char const*, long) + 37
2 libstdc++.6.0.9.dylib 0x00007fff73fa9cf9 std::basic_filebuf<char, std::char_traits<char> >::_M_convert_to_external(char*, long) + 317
3 libstdc++.6.0.9.dylib 0x00007fff73fa9b28 std::basic_filebuf<char, std::char_traits<char> >::overflow(int) + 102
4 libstdc++.6.0.9.dylib 0x00007fff73faa459 std::basic_filebuf<char, std::char_traits<char> >::sync() + 27
5 libstdc++.6.0.9.dylib 0x00007fff73fc1b7d std::ostream::flush() + 35
6 IMSLib.dylib 0x00000001106cab17 0x1105e6000 + 936727
7 IMSLib.dylib 0x00000001106c83df 0x1105e6000 + 926687
8 IMSLib.dylib 0x00000001106c8470 0x1105e6000 + 926832
9 IMSLib.dylib 0x00000001105e96d9 0x1105e6000 + 14041
10 IMSLib.dylib 0x00000001105e9c74 0x1105e6000 + 15476
11 IMSLib.dylib 0x000000011063454d 0x1105e6000 + 320845
12 IMSLib.dylib 0x00000001106351c9 0x1105e6000 + 324041
13 IMSLib.dylib 0x000000011062536d 0x1105e6000 + 258925
14 IMSLib.dylib 0x00000001106040a8 0x1105e6000 + 123048
15 IMSLib.dylib 0x0000000110603ddb 0x1105e6000 + 122331
16 IMSLib.dylib 0x000000011062aaf2 0x1105e6000 + 281330
17 IMSLib.dylib 0x000000011060f562 0x1105e6000 + 169314
18 IMSLib.dylib 0x00000001105f6a90 0x1105e6000 + 68240
19 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
20 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
21 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 43:
5 IMSLib.dylib 0x00000001105eb94f 0x1105e6000 + 22863
6 IMSLib.dylib 0x00000001105ec424 0x1105e6000 + 25636
7 IMSLib.dylib 0x000000011060689d 0x1105e6000 + 133277
8 IMSLib.dylib 0x000000011062a346 0x1105e6000 + 279366
9 IMSLib.dylib 0x000000011060f562 0x1105e6000 + 169314
10 IMSLib.dylib 0x00000001105f6a90 0x1105e6000 + 68240
11 libsystem_pthread.dylib 0x00007fff746706c1 _pthread_body + 340
12 libsystem_pthread.dylib 0x00007fff7467056d _pthread_start + 377
13 libsystem_pthread.dylib 0x00007fff7466fc5d thread_start + 13
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007ffeefa401c8 rcx: 0x00007ffeefa3fd28 rdx: 0x0000000000000000
rdi: 0x00000000000002ed rsi: 0x000000000000000b rbp: 0x00007ffeefa3fd30 rsp: 0x00007ffeefa3fd28
r8: 0x000000010a662cd0 r9: 0x0000000000000040 r10: 0x0000030000000000 r11: 0x0000000000000206
r12: 0x00007fff737e7e80 r13: 0x00007fff4ad431ca r14: 0x000060800356ad40 r15: 0x00007fff6b78accc
rip: 0x00007fff7453477a rfl: 0x0000000000000206 cr2: 0x000000010a639490
Logical CPU: 0
Error Code: 0x02000025
Trap Number: 133
Binary Images:
0x1001bd000 - 0x10122afff +com.adobe.bridge8 (8.0.1.282 - 8.0.1.282) <BFC69190-4563-31E2-BF40-AF5E3020A529> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/MacOS/Adobe Bridge CC 2018
0x1018d5000 - 0x10190afff +AgoraLib.dylib (1.0.0.0) <73697218-E690-371D-9728-7883DA2051A7> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AgoraLib.dylib
0x1019ad000 - 0x1019b0ff7 +com.adobe.CEP.PlugPlugExternalObject (8.0.0.35 - 8.0.0.35) <0678C4EC-1F85-345B-8545-E1B6857C16F7> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/PlugPlugExternalObject.framework/Versions/A/PlugPlugExternalObject
0x1019c0000 - 0x1019ecffb +VulcanMessage5.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <06C8FCC4-E4E4-3842-8413-7E0BB20AFB24> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/VulcanMessage5.dylib
0x101a3e000 - 0x101a59ffb +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <7E56E512-AED2-3AE2-B44B-22483C33451D> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/VulcanControl.dylib
0x101a8b000 - 0x101b73ff7 +com.adobe.dvametadata.framework (11.1.0 - 11.1.0.0) <0498E43D-12E7-3298-8102-0210C96966D5> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
0x101c65000 - 0x101c82ff7 +com.adobe.dvametadataapi.framework (11.1.0 - 11.1.0.0) <5E424910-E5EB-3D22-A0BA-3B3ACC7520C7> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvametadataapi.framework/Versions/A/dvametadataapi
0x101cb2000 - 0x101f8dfef +com.adobe.PlugPlugOwl (8.0.0.55 - 8.0.0.55) <B858CAC6-FC69-36E2-BEFB-18AE865CD8BA> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
0x1021d4000 - 0x1022affff +com.adobe.dvametadataUI.framework (11.1.0 - 11.1.0.0) <2F890D0B-116D-33BA-94E3-F670D0D9915B> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
0x1023e8000 - 0x1026b8fff +com.adobe.AGM (AdobeAGM 4.30.87.39161 - 4.30.87.39161) <5C37D655-2717-3391-9067-BC869E081583> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x102725000 - 0x102731fff +com.adobe.boost_filesystem.framework (11.1.0 - 11.1.0.0) <46853447-E0F2-3260-B40B-DAD98C98B02C> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x102745000 - 0x102aa3fff +com.adobe.MPS (AdobeMPS 5.8.1.39100 - 5.8.1.39100) <988FC209-CBE1-33C1-A566-1CD16844F747> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x102b17000 - 0x102b48ff7 +com.adobe.ARE (AdobeARE 1.5.02.39161 - 1.5.02.39161) <CD3E88B8-05B4-3E8E-A822-2EB82F2D01A2> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x102b51000 - 0x103896fff +com.adobe.ICUData (4.0 - 3.61) <8726D6A3-3921-3AB2-94D5-062E9EA297DB> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x1038b0000 - 0x10394cff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.2) <90576169-E2E3-3D56-876B-D5402241348A> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x10399d000 - 0x103a31fff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.2) <E5A7C157-24B7-393D-B5A0-1940EF81C966> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x103a7a000 - 0x103d6ffff +com.adobe.CoolType (AdobeCoolType 5.17.00.39161 - 5.17.00.39161) <3DC4F30F-B5FD-3653-9AD0-F7A8228D30AC> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x103dbe000 - 0x103e8bff7 +com.adobe.JP2K (1.2.2 - 1.2.2.39038) <ABF81325-23B4-3C51-B7E4-0F0DAD692B1E> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x103ed6000 - 0x107a56fdf +com.adobe.psl (AdobePSL 15.1.0.38776 - 15.1.0.38776) <22036635-21E0-35A5-8103-CCD034766DE3> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x107ed5000 - 0x10805dff7 +com.adobe.owl (AdobeOwl version 5.2.9 - 5.2.9) <A08490CC-75C3-35F0-A207-AE39CF56C78F> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x1080aa000 - 0x1081c4ff7 +com.adobe.ICUInternationalization (4.0 - 3.61) <36984DC1-7D78-3AB5-9891-CA6ACD116AEE> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternationalization
0x108251000 - 0x108351fff +com.adobe.ACE (AdobeACE 2.20.02.39161 - 2.20.02.39161) <B8A5A98D-253A-3F4D-AED4-E60FBDC81F1E> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x108367000 - 0x108458ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x1084a7000 - 0x1085deff7 +com.winsoft.wrservices (WRServices 11.0.0 - 11.0.0) <A1AF94EB-8B13-305C-8B8C-8E420BA0DD0A> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
0x108642000 - 0x1086e4ff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x10870f000 - 0x108715fff +com.adobe.AdobeCrashReporter (7.5 - 7.5.20170904) <305CFD68-2A99-338F-B592-ABFC59460745> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x108726000 - 0x108d65ff7 +com.adobe.dvaui.framework (11.1.0 - 11.1.0.0) <59EAFC7C-5315-3424-B3FB-1074191458A9> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x1097a2000 - 0x1098b5fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 143 - 79.161356) <75F089A9-ADBB-3F19-A06D-629C2D0E08B7> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x109a10000 - 0x109b1dfff +com.adobe.amtlib (10.0.0.221 - 10.0.0.221) <2DB81FF7-87C4-3307-A45E-96FCF6FD8AB1> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x109b33000 - 0x109c8aff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 30 - 79.161356) <2DF9CF0F-6D08-3BF6-818C-DFFB982192F8> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
0x109dbd000 - 0x109de2ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.38653 - 3.8.0.38653) <C834BECC-FCAD-34AB-860D-4FD101B4AEAA> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x109e09000 - 0x109e51ff7 +com.adobe.ahclientframework (3.0.0.6 - 3.0.0.6) <088B16D4-24A8-3F73-89D8-45CFA76C5D8D> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x109e8b000 - 0x109ea4ff7 +com.adobe.BIB (AdobeBIB 1.2.03.39161 - 1.2.03.39161) <B7C38DBC-0159-374B-8ADF-1936BA40AA63> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x109eb0000 - 0x109ed0ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.39161 - 1.1.39161) <EBB9A3A4-61EA-359B-9AE6-9A53B212ED9D> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x109ede000 - 0x109f21ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x109f44000 - 0x10a028ff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.38653 - 3.8.0.38653) <B6D2C528-A007-383C-AD25-35529BD1C350> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x10a0d5000 - 0x10a0dffff +com.adobe.boost_signals.framework (11.1.0 - 11.1.0.0) <77A5D608-19A2-3D2B-8719-BCDB9DFB63F2> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x10a0fd000 - 0x10a0feff7 +com.adobe.boost_system.framework (11.1.0 - 11.1.0.0) <FF313687-5E9A-3B63-BBFC-192D523C62AB> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x10a106000 - 0x10a113fff +com.adobe.boost_threads.framework (11.1.0 - 11.1.0.0) <A6BEA352-E06B-342C-86BC-AAF3824FC170> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x10a135000 - 0x10a1d6fff +com.adobe.dvaaudiodevice.framework (11.1.0 - 11.1.0.0) <B6ADE52F-FD48-3D9C-BFD3-FD2FAC984B41> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
0x10a2ba000 - 0x10a636ff7 +com.adobe.dvacore.framework (11.1.0 - 11.1.0.0) <A8333D70-5310-3A8B-A373-4F330D3AC291> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x10a911000 - 0x10a935fff +com.adobe.dvamarshal.framework (11.1.0 - 11.1.0.0) <E988424D-2FAF-3BF7-AEA2-41062827AEDD> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
0x10a97b000 - 0x10a9baff7 +com.adobe.dvamediatypes.framework (11.1.0 - 11.1.0.0) <787124EC-4615-36F9-A132-03B1D2AA62D9> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
0x10aa03000 - 0x10aa07ff7 +com.adobe.boost_date_time.framework (11.1.0 - 11.1.0.0) <75D9DD6F-6C2C-3701-AF1F-065866484647> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x10aa1f000 - 0x10aae3fdf +com.adobe.dvaplayer.framework (11.1.0 - 11.1.0.0) <5B12F28C-CA9F-3ACA-834F-0F9B1D7B2977> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
0x10ac4b000 - 0x10acaafff +com.adobe.dvatransport.framework (11.1.0 - 11.1.0.0) <A8CC87DC-B7B5-37FC-A871-8C619E100A04> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
0x10ad3d000 - 0x10ad56fff +com.adobe.dvaunittesting.framework (11.1.0 - 11.1.0.0) <E1CEA317-7D4A-3155-8C2A-EC3BD2C2B872> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
0x10ad8a000 - 0x10af56ff7 +com.adobe.dynamiclink.framework (11.1.0 - 11.1.0.0) <FC930E2B-FC32-39FD-B3B4-C91F12C17367> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
0x10b1e6000 - 0x10b4feff7 +com.adobe.mediacoreif.framework (11.1.0 - 11.1.0.0) <A18D9017-5A14-386B-9A63-426EF6D4801B> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/mediacoreif.framework/Versions/A/mediacoreif
0x10b851000 - 0x10b88ffff +com.adobe.dvanet.framework (8.0.0 - 8.0.0.0) <8617818A-4402-33D5-9FD3-14725A148CB2> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
0x10b8fb000 - 0x10c2e4fa7 +com.adobe.alignmentlib (Copyright © 2013 Adobe Systems Incorporated - Copyright © 2013 Adobe Systems Incorporated) <0507D481-FD8C-3856-AAB8-89679085B45A> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AlignmentLib.framework/Versions/A/AlignmentLib
0x10c561000 - 0x10c6f7ff7 +com.adobe.AIDE (1.5.0 - 1.5.0.38749) <CB102666-A75F-3BA7-8600-7F4D5CB50547> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x10c721000 - 0x10c74dff7 +libtbb.dylib (0) <64B7013E-D548-3F7B-A2FB-28B7B932275C> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/libtbb.dylib
0x10c76f000 - 0x10c78efe7 +libtbbmalloc.dylib (0) <6887ED68-67ED-3748-82DA-B39A3EB210BB> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/libtbbmalloc.dylib
0x10c8f9000 - 0x10c8fbff3 com.apple.textencoding.unicode (4.0 - 4.0) <B2304E3E-5ECA-30E0-8387-AFB1AE0B659D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x10e7a5000 - 0x10e8a0fff +com.adobe.adobe_caps (adobe_caps 10.0.0.8 - 10.0.0.8) <9066ABD7-6022-3194-90F9-5AF40275628A> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0x10e9e7000 - 0x10ea5afff +Photoshop Adapter (0) <94E808C5-EF90-3DB6-B710-B6A233DE7C43> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Required/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter
0x10ebb0000 - 0x10ec29fff +MultiProcessor Support (18.1.0 - 18.1.0) <567DA74C-9E82-3B07-A507-6E96937F8D27> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Plug-Ins/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x10ec9a000 - 0x10ed1bff7 +MMXCore (18.1.0 - 18.1.0) <A7735E65-C097-3CDD-A4BA-870FB2DB64A0> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Plug-Ins/MMXCore.plugin/Contents/MacOS/MMXCore
0x10eda4000 - 0x10eddffff +libtbb.dylib (0) <F275AA68-CB02-3242-93B3-B4D2AE7684E8> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/Frameworks/libtbb.dylib
0x10ee22000 - 0x10ee4afff +libtbbmalloc.dylib (0) <676054B1-7523-30BD-BE8C-2521A809E1B5> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/Frameworks/libtbbmalloc.dylib
0x10f4ed000 - 0x10f4efff7 com.apple.CloudDocsFileProvider (1.0 - 572.2) <B8610844-A0DF-3E72-A54D-F60FA9BBDDA1> /System/Library/PrivateFrameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x10fae9000 - 0x10fc1efff com.apple.AMDMTLBronzeDriver (1.60.26 - 1.6.0) <7C3FAF5B-05D0-3AE7-B3DB-8D50D98E3072> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x1102ac000 - 0x1102b0fff com.apple.audio.AppleHDAHALPlugIn (280.12 - 280.12) <9ACA0127-E687-3885-9475-1D5E4DD83168> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1105e6000 - 0x110731fe7 +IMSLib.dylib (10.0.0.22 - 10.0.0.22) <980F9F58-3C1B-31CC-8E92-226CACCE74C1> /Library/Application Support/Adobe/*/IMSLib.dylib
0x11097e000 - 0x1109c898f dyld (519.2.2) <6695F30B-4E88-3C0B-9867-7D738C44A3E6> /usr/lib/dyld
0x110a1c000 - 0x1141effe7 +com.adobe.CameraRaw (10.2 [894] - 10.2f894) <8A14462D-D322-338D-9A96-F9A9BEC68C9E> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
0x118d4d000 - 0x118e10ffb com.apple.AMDRadeonX4000GLDriver (1.60.26 - 1.6.0) <0066C672-7627-310C-8DBD-1D23BB746AE4> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x11d345000 - 0x11d349fff com.apple.carbonframeworktemplate (1.0 - 1.0) <D35D66F0-B2E8-32DB-996C-7E16E92F72E3> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/MacOS/Photo Downloader.app/Contents/Frameworks/apdhook.framework/apdhook
0x11eda0000 - 0x11edd2ff7 +com.adobe.pip (7.4.1.89.46528) <3A3C69F2-739A-3E3E-86A5-7BFA5BAB2A8D> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x11eee3000 - 0x11ef0cfff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
0x11f3f7000 - 0x11f592fff +com.adobe.headlights.LogSessionFramework (7.4.1.89.46528) <470407DF-3A7B-3FD4-9F39-69428451C33F> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/LogSession.framework/LogSession
0x123f30000 - 0x1244bcff7 +com.adobe.standard.multiplugin (18.1.1 - 18.1.1) <26EABB8C-D1C6-383B-BA74-460BC1C2C9EF> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Plug-Ins/Standard Multiplugin.plugin/Contents/MacOS/Standard Multiplugin
0x124b7b000 - 0x124b7efff com.apple.FileProviderOverride (124.1 - 124.1) <0F407C0B-B843-3D69-9133-126EFC8DB589> /System/Library/PrivateFrameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x124c21000 - 0x124c27fff com.apple.FinderSyncCollaborationFileProviderOverride (1.0 - 1054.2.4) <35F8FDBA-1363-3DE2-B28D-4A8387B14EDD> /System/Library/PrivateFrameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x1ec68a000 - 0x1ecdadfff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.39100) <0758F32C-561E-3F77-9BDA-20B9F91C154F> /Applications/Adobe Bridge CC 2018/Adobe Bridge CC 2018.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
0x7fff450ee000 - 0x7fff450efffb libCyrillicConverter.dylib (70) <4CE6D79E-2347-3340-B3CF-B310162022C5> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x7fff450f3000 - 0x7fff4510fffb libJapaneseConverter.dylib (70) <3CEF6160-E84C-3512-9252-88181B28C8C5> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x7fff45110000 - 0x7fff45131ff3 libKoreanConverter.dylib (70) <26FF584D-BDB9-3469-B078-E31D7AF334E4> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x7fff4513a000 - 0x7fff45149ffb libSimplifiedChineseConverter.dylib (70) <3A6A70F9-E7D3-30ED-A08B-E8691EB25855> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x7fff4514d000 - 0x7fff4515fff3 libTraditionalChineseConverter.dylib (70) <E965AE49-9791-3E63-A901-F676EB0DE6CD> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x7fff45175000 - 0x7fff454c3ff7 com.apple.RawCamera.bundle (8.02.0 - 1017.2.2) <C799730B-C745-3775-BCE7-C67B8BD97FDB> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff4570b000 - 0x7fff45f35ff7 ATIRadeonX4000SCLib.dylib (1.60.26) <35CB9BC0-C664-38A7-96FA-0F07243E68D6> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff48c93000 - 0x7fff48c97ffb com.apple.agl (3.3.1 - AGL-3.3.1) <5A110DE6-3EE7-343B-95FE-9642517D1B64> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff48c98000 - 0x7fff48e73fff com.apple.avfoundation (2.0 - 1530.2) <30F528A4-548F-3E18-80A8-06481788E84C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff48e74000 - 0x7fff48f2eff7 com.apple.audio.AVFAudio (1.0 - ???) <891340D8-A1F3-37B5-A183-EE5BE81F5296> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff49034000 - 0x7fff49034fff com.apple.Accelerate (1.11 - Accelerate 1.11) <5AA750F5-D633-32BA-B7F3-4F651FB1761E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff49035000 - 0x7fff4904bfe3 libCGInterfaces.dylib (417) <27E09D39-51B5-3297-BE33-0DB1736B833A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff4904c000 - 0x7fff4954afc3 com.apple.vImage (8.1 - ???) <310976EE-E12D-39D7-8F58-6EE924E08576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff4954b000 - 0x7fff496a5fcb libBLAS.dylib (1211.30.1) <0DB0D952-BCF4-3479-BA2F-785FB1A57479> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff496a6000 - 0x7fff496d4fef libBNNS.dylib (37) <49EB4DBA-877C-3D41-90A2-C3D982C72A54> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff496d5000 - 0x7fff49a95ff7 libLAPACK.dylib (1211.30.1) <2D4E4446-6B63-350C-BD68-A1B8FBE99539> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff49a96000 - 0x7fff49aabff7 libLinearAlgebra.dylib (1211.30.1) <6C68F41D-1398-3AFE-BE72-C0ECA1B24BDC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff49aac000 - 0x7fff49ab1ff3 libQuadrature.dylib (3) <3D6BF66A-55B2-3692-BAC7-DEB0C676ED29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff49ab2000 - 0x7fff49b10fff libSparse.dylib (79.1.1) <7AD0F8A8-FD36-36FE-B83D-58648EBD0027> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff49b11000 - 0x7fff49b24fff libSparseBLAS.dylib (1211.30.1) <42506F6F-0F38-322E-9903-C1DB66E4DA05> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff49b25000 - 0x7fff49cd1fc3 libvDSP.dylib (622.20.8) <6FFCA52B-7D60-326A-ADF2-601F39A8685A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff49cd2000 - 0x7fff49d82fef libvMisc.dylib (622.20.8) <54F90047-879F-3260-8604-6E453149B49E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff49d83000 - 0x7fff49d83fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <8A96A8ED-7B88-3D17-8D17-41D224E0EC90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff49d84000 - 0x7fff49ddbff7 com.apple.Accounts (113 - 113) <02AC0AF3-D620-340E-BE52-CD31119F9CD8> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff49ddc000 - 0x7fff4a072fff com.apple.AddressBook.framework (11.0 - 1808.6) <1BE4B8EF-60A4-320C-91A5-5241E2118B82> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff4a073000 - 0x7fff4aed0fff com.apple.AppKit (6.9 - 1561.20.106) <AF59A3CF-E3C3-3046-86D9-0C9145E60CE4> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff4af22000 - 0x7fff4af22fff com.apple.ApplicationServices (48 - 50) <7627DBD6-497B-3AB7-9B63-F0532EDF09B8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff4af23000 - 0x7fff4af89fff com.apple.ApplicationServices.ATS (377 - 445) <CDF5F6D7-4E7D-3D28-9FBA-1B53AD9FA8F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff4b022000 - 0x7fff4b144fff libFontParser.dylib (222.1.2) <11BD5EEF-AF18-33FB-B114-DD611932E822> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff4b145000 - 0x7fff4b18fff7 libFontRegistry.dylib (221) <A22F82C0-B4FE-3DB5-B968-79B28257DF2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff4b234000 - 0x7fff4b267ff7 libTrueTypeScaler.dylib (222.1.2) <33C245B4-E1AD-3C89-B735-5A5610E547C8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff4b2d1000 - 0x7fff4b2d5ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <42C25E85-1CF3-3DEC-A434-BE69F68F4318> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff4b2d6000 - 0x7fff4b374fff ColorSyncDeprecated.dylib (546) <DA29622B-A541-3B84-97A6-DACF95BBD3AA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x7fff4b375000 - 0x7fff4b3c7ff7 com.apple.HIServices (1.22 - 622) <2E83CD6F-ED98-3C29-BD0A-8525E38AB5DB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff4b3c8000 - 0x7fff4b3d6fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <71A9C815-AC55-3E36-A618-F6778F5119AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff4b3d7000 - 0x7fff4b423fff com.apple.print.framework.PrintCore (13 - 503) <A69E2BAD-2B66-38CC-9D3A-0A0EBC41341D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff4b424000 - 0x7fff4b45efff com.apple.QD (3.12 - 403) <38D8106A-4FFA-3FE9-9999-714CADD7EE9C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff4b45f000 - 0x7fff4b46bfff com.apple.speech.synthesis.framework (7.4.1 - 7.4.1) <9ABE85D9-6E4A-3CEF-AA09-F81E52730598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff4b46c000 - 0x7fff4b6f7fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <46EDC245-5877-3438-805C-3AA0316E3F5C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff4b6f9000 - 0x7fff4b6f9fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <0FC3B4FF-FFAB-3346-9A6A-C1DE033185EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff4ba0e000 - 0x7fff4bda0fff com.apple.CFNetwork (893.13.1 - 893.13.1) <3ECC6AD0-B47D-38D2-BF26-496B34847D25> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff4bdb5000 - 0x7fff4bdb5fff com.apple.Carbon (158 - 158) <FCD7A9FF-5E53-3B0C-8A52-691C11B2A0C5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff4bdb6000 - 0x7fff4bdb9ffb com.apple.CommonPanels (1.2.6 - 98) <39C8EBA3-EEB2-335B-8A88-D6C64BAA112F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff4bdba000 - 0x7fff4c0bfff7 com.apple.HIToolbox (2.1.1 - 910.4) <D1A799BC-146A-35E8-86FF-E36273123006> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff4c0c0000 - 0x7fff4c0c3ffb com.apple.help (1.3.8 - 64) <18D02016-119A-33E8-AEB0-E9466BA4AD56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff4c0c4000 - 0x7fff4c0c9fff com.apple.ImageCapture (9.0 - 9.0) <2DE590E5-DF0E-3962-A2BE-06EBC79B3D72> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff4c0ca000 - 0x7fff4c15fffb com.apple.ink.framework (10.9 - 220) <D8AECAE3-9FD2-32E3-B659-026F33650BB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff4c160000 - 0x7fff4c17aff7 com.apple.openscripting (1.7 - 174) <66899B51-ADFD-360D-88E9-B52439F531B4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff4c19b000 - 0x7fff4c19cfff com.apple.print.framework.Print (12 - 267) <E4CBAAFC-9045-38AC-9F93-8C931DDED9D8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff4c19d000 - 0x7fff4c19fff7 com.apple.securityhi (9.0 - 55006) <E7668200-B4CB-3612-96B8-D57E94077787> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff4c1a0000 - 0x7fff4c1a6fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1F10ED1F-12C7-39AC-88A0-43A1338F9316> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff4c1a7000 - 0x7fff4c2b2ff7 com.apple.cloudkit.CloudKit (735.4 - 735.4) <89BEB558-1CA4-3782-A0F2-0057E2BDFB99> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff4c2b3000 - 0x7fff4c2b3fff com.apple.Cocoa (6.11 - 22) <1553F279-3C7B-3A48-87E6-35237F7F452E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff4c2c1000 - 0x7fff4c37aff7 com.apple.ColorSync (4.13.0 - 546) <A5E013D9-7305-3026-879E-4D1F038A430D> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff4c507000 - 0x7fff4c59aff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <F91FDE26-0702-3E44-8931-E2CAD8E36F5A> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff4c601000 - 0x7fff4c62affb com.apple.CoreBluetooth (1.0 - 1) <942F88A5-AD68-3359-90D5-6F1A3311C51A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff4c62b000 - 0x7fff4c97ffe7 com.apple.CoreData (120 - 849.2) <CE0AF596-64C0-34F3-AFE0-B94D18C09957> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff4c980000 - 0x7fff4ca4cfff com.apple.CoreDisplay (1.0 - 81.7) <D8030B81-097E-3FA2-A85C-AE1A3B8EBCFB> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff4ca4d000 - 0x7fff4ceedfe7 com.apple.CoreFoundation (6.9 - 1451) <7AFE9C8F-A562-3AFC-8402-117AA02F57E9> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff4ceef000 - 0x7fff4d4fcfef com.apple.CoreGraphics (2.0 - 1129.5) <F37BFBD2-CC21-3521-B034-9D4D36197487> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff4d4fe000 - 0x7fff4d7edfff com.apple.CoreImage (13.0.0 - 579.2.9) <8AE143AB-6284-3B00-B56D-8C0C1826EF34> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff4d7ee000 - 0x7fff4d859ff7 com.apple.corelocation (2237.0.22) <EF931B7C-7656-389B-A161-FB6605869B0B> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff4da7c000 - 0x7fff4db5dfff com.apple.CoreMedia (1.0 - 2270.12.1) <B62CF714-D69A-38C3-9929-B70FF4CBB216> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff4db5e000 - 0x7fff4dbacfff com.apple.CoreMediaIO (812.0 - 4993) <CA47AF11-0EF4-33E1-9EC3-7A56661FFEE4> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff4dbad000 - 0x7fff4dbadfff com.apple.CoreServices (822.19 - 822.19) <44456ED2-59E4-34CB-B41B-C6A82B269949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff4dbae000 - 0x7fff4dc22ffb com.apple.AE (735.1 - 735.1) <D0C73200-90A7-3FD1-A6EC-97055AA367E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff4dc23000 - 0x7fff4defaff7 com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <A1FE74F8-953B-371E-A8AC-E87B30FB79C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff4defb000 - 0x7fff4df2fff7 com.apple.DictionaryServices (1.2 - 284) <3FCEE280-8DD0-37C9-BFD4-7BA87AAFC8EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff4df30000 - 0x7fff4df38ff3 com.apple.CoreServices.FSEvents (1239 - 1239) <7BBC5CB7-DBC8-316B-99B0-781827159A2F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff4df39000 - 0x7fff4e0f1ff7 com.apple.LaunchServices (822.19 - 822.19) <2895A919-0445-3CE2-9696-40122B5A46C5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff4e0f2000 - 0x7fff4e1a1ff7 com.apple.Metadata (10.7.0 - 1191.2.6) <FB66B298-D55D-398A-BEDB-CB7B82956AE5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff4e1a2000 - 0x7fff4e1ffff7 com.apple.CoreServices.OSServices (822.19 - 822.19) <34BF1FAC-A0F7-37B4-950D-46408EBA9684> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff4e200000 - 0x7fff4e26efff com.apple.SearchKit (1.4.0 - 1.4.0) <14053F88-2C76-35CA-9FC1-2A9BC0B63F88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff4e26f000 - 0x7fff4e293ffb com.apple.coreservices.SharedFileList (71.4 - 71.4) <4AA6DCF5-BAF8-36FA-A8B0-EDF518EFEF14> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff4e52e000 - 0x7fff4e67cfff com.apple.CoreText (352.0 - 578.12.1) <55B16B2D-F083-3B89-A5C2-52FB053331F2> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff4e67d000 - 0x7fff4e6b7ff3 com.apple.CoreVideo (1.8 - 279.2) <A8FC5325-D092-3A28-A1CF-5C94B8101F71> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff4e6b8000 - 0x7fff4e742ffb com.apple.framework.CoreWLAN (13.0 - 1339) <16DDD47C-BBFE-3D49-8BDF-3652017240FD> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff4e8d0000 - 0x7fff4e8dbff7 com.apple.DirectoryService.Framework (10.13 - 207) <79F272D7-48AE-3D1E-AC5B-3CEB5F16E7D5> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff4e8dc000 - 0x7fff4e996fff com.apple.DiscRecording (9.0.3 - 9030.4.5) <2094BAC4-4F37-3741-B9BD-60158A63C503> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff4e9bd000 - 0x7fff4e9c2fff com.apple.DiskArbitration (2.7 - 2.7) <44836CE9-A9ED-3017-972A-7A0A3D6B472B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff4eb83000 - 0x7fff4ef48fff com.apple.Foundation (6.9 - 1451) <B99F94E7-117E-39CC-A65D-B7AEA8998481> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff4efb8000 - 0x7fff4efe8fff com.apple.GSS (4.0 - 2.0) <3B4B4509-B5A3-396B-9C71-80BAE84476FA> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff4f0fa000 - 0x7fff4f1fdff3 com.apple.Bluetooth (6.0.2 - 6.0.2f2) <718565B3-6DA7-3DF9-BB51-391FFCAEAFA5> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff4f25d000 - 0x7fff4f2f8fff com.apple.framework.IOKit (2.0.2 - 1445.40.1) <9CFA07B9-BA6E-31E4-AD4F-C47071A8C522> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff4f2fa000 - 0x7fff4f301ffb com.apple.IOSurface (209.2.2 - 209.2.2) <6D35A601-1C47-37BE-AD31-F8EB88F67573> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff4f302000 - 0x7fff4f357ff3 com.apple.ImageCaptureCore (7.0 - 7.0) <CBE349D4-2C8B-31F5-B5ED-B8E978DA9245> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff4f358000 - 0x7fff4f4cfff7 com.apple.ImageIO.framework (3.3.0 - 1713) <D3CE3838-72C5-3860-B3A4-6937FD916329> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff4f4d0000 - 0x7fff4f4d4ffb libGIF.dylib (1713) <C65B2846-1B94-3BB3-BBBF-5A9E5054CE1E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff4f4d5000 - 0x7fff4f5bcfff libJP2.dylib (1713) <332083DD-3D27-3DE7-9866-A36D590E511E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff4f5bd000 - 0x7fff4f5e0ff7 libJPEG.dylib (1713) <2D846A18-D8AF-3573-803B-BEABCBAC38D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff4f8bc000 - 0x7fff4f8e2feb libPng.dylib (1713) <546F41CE-185C-31A0-B61C-1012AA932624> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff4f8e3000 - 0x7fff4f8e5ffb libRadiance.dylib (1713) <31787C46-4A2B-3CDF-95E9-EC1BD4794917> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff4f8e6000 - 0x7fff4f933feb libTIFF.dylib (1713) <5319B2E1-83D2-30C7-A7BC-A0CE0B07885D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff4faef000 - 0x7fff506aafff com.apple.JavaScriptCore (13604 - 13604.5.6) <5541E211-3248-3B89-9AE9-D5FE413F12D1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff506c2000 - 0x7fff506dbff7 com.apple.Kerberos (3.0 - 1) <CAF075C0-4C24-3ACE-9AE6-77BEFDEA3622> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff506dc000 - 0x7fff50711fff com.apple.LDAPFramework (2.4.28 - 194.5) <8419BDB5-12DF-3BC9-871D-7A270E080249> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff50993000 - 0x7fff5099afff com.apple.MediaAccessibility (1.0 - 114) <D72C593A-AC32-3419-AB86-6B07217EBFD5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff50a3d000 - 0x7fff51058fff com.apple.MediaToolbox (1.0 - 2270.12.1) <40802884-1347-3CDC-AAD3-D046463A528E> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff5105a000 - 0x7fff510d9fff com.apple.Metal (124.7 - 124.7) <F161C177-80B4-3674-8147-04343702CF08> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff510f6000 - 0x7fff5110bfff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <D4BCBA84-AD1B-33DC-99F3-16F9E5E50906> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff5110c000 - 0x7fff51177fef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <E504EC97-FAD7-36DC-B151-6F89AB911E3A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff51178000 - 0x7fff5119bfff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <A5B6F6FC-A19A-32C0-A999-98B6688760C7> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff5119c000 - 0x7fff5121cff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <D0D8F13F-ACD4-3B61-BE54-121CCB05ECF4> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff5121d000 - 0x7fff5121dff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <2E8723FC-AA53-3596-B6A4-220A378B7A5A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff52226000 - 0x7fff52232ffb com.apple.NetFS (6.0 - 4.0) <81B22AE7-7094-30F2-BF41-84CA05EDB95B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff5501a000 - 0x7fff55022fef libcldcpuengine.dylib (2.8.7) <DD781325-D94E-3AD7-8D6C-817FB3068917> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff55023000 - 0x7fff55070ffb com.apple.opencl (2.8.12 - 2.8.12) <7F9BF7F0-AFB2-349A-BF9B-2DE5288380C4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff55071000 - 0x7fff5508dffb com.apple.CFOpenDirectory (10.13 - 207) <A229B355-337B-33F4-AAA8-C751BEF0B718> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff5508e000 - 0x7fff55099fff com.apple.OpenDirectory (10.13 - 207) <D8AA4C58-149E-3504-88CD-F5B59F882C25> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff56218000 - 0x7fff5621afff libCVMSPluginSupport.dylib (16.4.2) <A967BC8B-ABB3-393F-BF34-BD32B45831F7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff5621b000 - 0x7fff5621fff7 libCoreFSCache.dylib (162.4) <B325B709-0C81-357A-B9F1-6E0027B64F9B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff56220000 - 0x7fff56224fff libCoreVMClient.dylib (162.4) <B129DB84-39BA-34E4-9FB7-20A020A1BB86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff56225000 - 0x7fff5622dfff libGFXShared.dylib (16.4.2) <07F1D947-F79B-3608-9080-E4DBFE13AF1D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff5622e000 - 0x7fff56239fff libGL.dylib (16.4.2) <97D6871A-BAF1-33DD-9ED7-BE7BB437F378> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff5623a000 - 0x7fff56275fe7 libGLImage.dylib (16.4.2) <3E2802DF-4998-31DB-B3A2-65720DE919A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff56276000 - 0x7fff563e2fff libGLProgrammability.dylib (16.4.2) <3505EF20-FA3D-321B-8C11-D9CA74656F30> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff563e3000 - 0x7fff56421ffb libGLU.dylib (16.4.2) <ECABCFAB-E400-3667-8EE1-586C07E0E214> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff56d99000 - 0x7fff56da7ffb com.apple.opengl (16.4.2 - 16.4.2) <C8C31EF5-8DB4-336F-A87C-5D520C7EFDC5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff56da8000 - 0x7fff56f3fffb GLEngine (16.4.2) <8F35484D-9C09-3D79-9825-7E73661326D4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff56f40000 - 0x7fff56f68ffb GLRendererFloat (16.4.2) <463BD481-6E1A-3EFC-A93B-C7E9292F76ED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff5711f000 - 0x7fff5726bfff com.apple.QTKit (7.7.3 - 3014) <CF2818E6-E215-3C24-A2AC-1B5F8AD7E398> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff5726c000 - 0x7fff574d1ff7 com.apple.imageKit (3.0 - 1040) <5A1261EA-76C5-386C-9F46-06EE804E2234> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff574d2000 - 0x7fff575beff3 com.apple.PDFKit (1.0 - 677.4) <265C1FB2-4E62-3498-A86B-02C0F790F1ED> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff575bf000 - 0x7fff57ad1ff7 com.apple.QuartzComposer (5.1 - 364) <D99600D5-C066-3D49-8641-369A69300D16> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff57ad2000 - 0x7fff57af5fff com.apple.quartzfilters (1.10.0 - 1.10.0) <8CBE10F3-828F-373C-B92A-A5289CBCF77A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff57af6000 - 0x7fff57bedff7 com.apple.QuickLookUIFramework (5.0 - 743.7) <B0352E2A-C582-3C86-A2ED-A30D4A3B785D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff57bee000 - 0x7fff57beefff com.apple.quartzframework (1.5 - 21) <3F3BE91F-A032-3E92-ACEA-E2DFEC999E93> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff57bef000 - 0x7fff57e37fff com.apple.QuartzCore (1.11 - 584.8.102) <4479AF33-E6EA-3037-A2C1-3C6F12B1260A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff57e38000 - 0x7fff57e8fff7 com.apple.QuickLookFramework (5.0 - 743.7) <0CB6717C-CCE2-3591-A31E-A8EF01DD4FC8> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff58054000 - 0x7fff5806afff com.apple.SafariServices.framework (13604 - 13604.5.6) <D71DE52A-9B30-381B-82CA-57473E7A0E7E> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff58670000 - 0x7fff58987ff7 com.apple.security (7.0 - 58286.41.2) <EB297497-884A-362F-B566-73A14A2F25FE> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff58988000 - 0x7fff58a12ff7 com.apple.securityfoundation (6.0 - 55185.30.4) <65144003-B9E2-3DE3-8923-F2BAA68BBF4E> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff58a13000 - 0x7fff58a43ff3 com.apple.securityinterface (10.0 - 55109.30.2) <8BFD22AB-32C9-3AD1-9CB4-39EA2D18E865> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff58a44000 - 0x7fff58a47ffb com.apple.xpc.ServiceManagement (1.0 - 1) <B11C3C64-6FE7-3A78-B583-D790B7CCE95A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff58dec000 - 0x7fff58e5cff3 com.apple.SystemConfiguration (1.17 - 1.17) <3C6B2BB9-43AB-39AD-8027-38E30A8A4186> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff58e5d000 - 0x7fff58e62fff org.twain.dsm (1.9.5 - 1.9.5) <C53A4DA0-7BD1-34DD-A2FA-BC0E38E536EB> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x7fff59011000 - 0x7fff5938aff7 com.apple.VideoToolbox (1.0 - 2270.12.1) <77848D39-10DA-3AA3-88F4-2898F42FCA5A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff59632000 - 0x7fff59b4afe7 libwebrtc.dylib (7604.5.6) <7C956A2C-8F14-310F-AE27-CCDA9F64AAE5> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff59b4b000 - 0x7fff5b032ff7 com.apple.WebCore (13604 - 13604.5.6) <558072BF-6134-3C19-B32E-4889C5C06C5C> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff5b033000 - 0x7fff5b226ff3 com.apple.WebKitLegacy (13604 - 13604.5.6) <E0177202-32F5-3D0F-9F80-85F41AFF049E> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff5b227000 - 0x7fff5b61fff7 com.apple.WebKit (13604 - 13604.5.6) <5AB44A86-7C8C-3F24-A76B-80618F164763> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff5ba8f000 - 0x7fff5bb1bff7 com.apple.APFS (1.0 - 1) <9D67579C-7FB4-3AD9-AB4F-9174A552EB37> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff5c72e000 - 0x7fff5c756fff com.apple.framework.Apple80211 (13.0 - 1345) <D1B8340A-41FB-35C3-88F0-3DDD9A2A1999> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff5c758000 - 0x7fff5c767ff7 com.apple.AppleFSCompression (96.30.2 - 1.0) <CFA90544-68EB-3CCE-A8F7-1B03974F3B85> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff5c8a3000 - 0x7fff5c8ebff3 com.apple.AppleJPEG (1.0 - 1) <8BBD5180-5BF9-33DB-8B91-974B1D0AECFB> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff5c8fe000 - 0x7fff5c91cff3 com.apple.aps.framework (4.0 - 4.0) <932274E4-DCD5-30D5-9AC7-58CEF4571EB3> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff5c91d000 - 0x7fff5c925ff3 com.apple.AppleSRP (5.0 - 1) <4CEC34CF-63E3-3023-B61B-F8D133698534> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff5c926000 - 0x7fff5c94efff com.apple.applesauce (1.0 - ???) <32FF4851-2F68-35BA-835F-91856A20C323> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff5ca17000 - 0x7fff5ca1aff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <A6795AC1-D528-3A2F-9C43-14EBFC57B7D6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff5ca1b000 - 0x7fff5ca6bff7 com.apple.AppleVAFramework (5.0.39 - 5.0.39) <4B830521-2A54-3116-8103-127E631FEDC8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff5d13a000 - 0x7fff5d141ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <47B6301F-D908-3811-BB9E-DA16D9B29A34> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff5d142000 - 0x7fff5d1c9ff7 com.apple.backup.framework (1.9.2 - 1.9.2) <40C6CFA8-4013-3AFB-97CE-8A09388FA343> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff5d23f000 - 0x7fff5d27bfff com.apple.bom (14.0 - 194.2) <ED2FFB9D-4DA4-322B-89C0-102D790649CD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff5d899000 - 0x7fff5d8c6fff com.apple.CalendarAgentLink (8.0 - 250) <55B60B04-2EAA-3F22-88EF-1602129D5294> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fff5df8d000 - 0x7fff5dfdcff3 com.apple.ChunkingLibrary (188 - 188) <84E024A0-5F95-3A30-A60B-102343AE46B7> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff5dfe3000 - 0x7fff5e073ff7 com.apple.CloudDocs (1.0 - 572.2) <7549FED5-7C41-3E3E-ABB4-34DCB312F8A2> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff5eb59000 - 0x7fff5eb62ff3 com.apple.CommonAuth (4.0 - 2.0) <11B2D184-36B8-3624-B1AD-7B6037D76160> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff5eb77000 - 0x7fff5eb8cff7 com.apple.commonutilities (8.0 - 900) <518FBC2C-0AF3-39DF-B454-526311796A49> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff5ed10000 - 0x7fff5ed70fff com.apple.AddressBook.ContactsFoundation (8.0 - ???) <9B39DF3E-5B7F-3467-AC17-23258F76A376> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff5ed71000 - 0x7fff5ed93fff com.apple.contacts.ContactsPersistence (1.0 - 2330.3) <EE8079D4-E1E2-3EFF-A7E1-E97BD81F6C6F> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff5edf3000 - 0x7fff5f1d3fff com.apple.CoreAUC (249.0.0 - 249.0.0) <7F406271-A215-3C75-BDAA-B9611BA2822E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff5f1d4000 - 0x7fff5f204ff7 com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <D0879D8F-488A-3D46-BC50-AD7B0642C0E8> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff5f3ff000 - 0x7fff5f408ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <0A87A91C-A2CF-3BB1-9038-7F610111BC30> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff5f56f000 - 0x7fff5f57fff7 com.apple.CoreEmoji (1.0 - 69.3) <A4357F5C-0C38-3A61-B456-D7321EB2CEE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff5fe3a000 - 0x7fff5fe50ff7 com.apple.CoreMediaAuthoring (2.2 - 956) <A5003E93-68B3-3A0E-8252-454CC4CFEC4D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff5ff92000 - 0x7fff5ffefff7 com.apple.CoreNLP (1.0 - 130.4.1) <1F329E38-E7D0-3455-981B-48F434C9E8CC> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff60178000 - 0x7fff6017dff7 com.apple.CoreOptimization (1.0 - 1) <785B622B-8F7D-3B4D-83AF-EB98CB79FFF6> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff6017e000 - 0x7fff60223ff7 com.apple.CorePDF (4.0 - 414) <2F0447DB-826B-3CEC-A98C-B8A8DDEA1B26> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff602c3000 - 0x7fff602cbff7 com.apple.CorePhoneNumbers (1.0 - 1) <B782FEA6-ACAD-34C6-811F-635F319C3B71> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff602cc000 - 0x7fff60328fff com.apple.CorePrediction (1.0 - 1) <B1E687BA-4E62-321B-8C87-D37C540A5A68> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff60455000 - 0x7fff60486ff3 com.apple.CoreServicesInternal (309.1 - 309.1) <EB09CAFC-AE9B-3257-BE45-5471D9F64AAD> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff607d5000 - 0x7fff60866fff com.apple.CoreSymbolication (63075) <2458D96C-1C31-34F8-93F0-73DB0042CB30> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff608e9000 - 0x7fff60a1dfff com.apple.coreui (2.1 - 492.2) <FE0B32BC-958D-3445-866E-A3905626396D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff60a1e000 - 0x7fff60b29fff com.apple.CoreUtils (5.3 - 530.60) <D74B16CC-E2C5-3D8A-B9F4-6D1DB23092B1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff60b7e000 - 0x7fff60be2fff com.apple.framework.CoreWiFi (13.0 - 1339) <7EBA8BA5-C650-3067-A805-8DD08FC816FD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff60be3000 - 0x7fff60bf2ff7 com.apple.CrashReporterSupport (10.13 - 1) <6B5B2B78-15D2-363F-BE34-8F9226E79E24> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff60c6f000 - 0x7fff60c7eff7 com.apple.framework.DFRFoundation (1.0 - 191.1) <87B83349-C317-3E07-894C-5BC5C20AE08B> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff60c81000 - 0x7fff60c85ffb com.apple.DSExternalDisplay (3.1 - 380) <BEC07C7C-F3AC-3CF3-B13E-3EBFD6224C0D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff60cca000 - 0x7fff60d0affb com.apple.datadetectors (5.0 - 376) <612C677D-BB71-35D2-BBF3-EA9EC51ADF12> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fff60d0b000 - 0x7fff60d81fff com.apple.datadetectorscore (7.0 - 590.3) <792593BC-21C7-3E0C-929E-067CD725FCBD> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff60dcf000 - 0x7fff60e0fff7 com.apple.DebugSymbols (141 - 141) <99562E28-0E56-3F6F-93A1-EF997A5E1F87> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff60e10000 - 0x7fff60f3ffff com.apple.desktopservices (1.12.2 - 1.12.2) <8E068AF7-FB72-38E2-948E-6C13F359C69D> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff60f9f000 - 0x7fff60fa0ff7 com.apple.diagnosticlogcollection (10.0 - 1000) <DFD57FDB-CB78-3FB0-B49B-4586F9E0DFC1> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x7fff61032000 - 0x7fff61104ff7 com.apple.DiskImagesFramework (480.30.2 - 480.30.2) <4A7D01B5-0A30-3425-AC35-D349EC10454F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff61105000 - 0x7fff6117cff7 com.apple.DiskManagement (11.2 - 1339) <0B17E79A-0BF6-3FD8-8AD0-A8498545030F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff6117d000 - 0x7fff61188ff7 com.apple.DisplayServicesFW (3.1 - 380) <FB1FBB24-7FD5-3B57-8D3C-39F953F8A9BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff61210000 - 0x7fff61212ff7 com.apple.EFILogin (2.0 - 2) <5B6E5A73-C2B2-3188-ADE9-C29CE29BB225> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff6195e000 - 0x7fff61976fff com.apple.Engram (1.0 - 1) <93DC8AE3-B3F7-326E-93DB-C85A2BFD3C3F> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
0x7fff61cb4000 - 0x7fff620e2fff com.apple.vision.FaceCore (3.3.2 - 3.3.2) <80C97AD7-D5C2-311A-B268-4AA60CAD6CED> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff62115000 - 0x7fff6219eff7 com.apple.FileProvider (124.1 - 124.1) <5BF434E7-7675-3877-B761-0281418BC633> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff621b5000 - 0x7fff625a4fff com.apple.FinderKit (1.6.2 - 1.6.2) <4DCCE9B6-2CE6-358F-BE78-C47A87BBD7D5> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x7fff63d4a000 - 0x7fff63d4afff libmetal_timestamp.dylib (802.3.14) <567B1E2F-A6C4-3350-A72E-AF0E0C4A7788> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3802/Libraries/libmetal_timestamp.dylib
0x7fff653aa000 - 0x7fff653b5ff7 libGPUSupportMercury.dylib (16.4.2) <F5BA5D7A-FD23-3416-B9B3-7EABFD4279D5> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff65752000 - 0x7fff65777ff3 com.apple.GenerationalStorage (2.0 - 285) <07E7BC5F-8EF2-34FC-9EEC-B4E61EAAFA9A> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff6578f000 - 0x7fff660b3fff com.apple.GeoServices (1.0 - 1359.23.11.28.2) <4248D1A7-816A-361B-9B74-76074C599001> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff660f6000 - 0x7fff66105fff com.apple.GraphVisualizer (1.0 - 5) <0A93C5DE-0D28-312E-8764-6B0FB805ED91> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff6617d000 - 0x7fff661f1fff com.apple.Heimdal (4.0 - 2.0) <ACC132E5-97F1-3B36-AD7B-4E6CC077E691> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff661f2000 - 0x7fff6621ffff com.apple.HelpData (2.3 - 158) <4508839C-39FC-31FD-9AB8-A7ADA9284F5C> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff66289000 - 0x7fff6628afff com.apple.ICALogging (1.0 - 1) <3CC543D3-DE7C-3717-8C8D-EA39094DCA0F> /System/Library/PrivateFrameworks/ICALogging.framework/Versions/A/ICALogging
0x7fff6628b000 - 0x7fff6639dff3 com.apple.ids (10.0 - 1000) <F85463DF-6D86-33C6-B740-498B29D7ECC6> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x7fff6639e000 - 0x7fff6647cfff com.apple.idsfoundation (10.0 - 1000) <BE207DF9-8609-3A80-9132-87FEB8E817B6> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x7fff66983000 - 0x7fff669e9ff3 com.apple.imfoundation (10.0 - 1000) <32799DD1-91A2-3093-8D8C-4F4988560FC2> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fff66a99000 - 0x7fff66aa2fff com.apple.IOAccelMemoryInfo (1.0 - 1) <E062BBA9-0857-384E-978B-4C6346825E51> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff66aa3000 - 0x7fff66aaaffb com.apple.IOAccelerator (376.6 - 376.6) <A47129CC-F386-3C31-AD66-C19A70615A50> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff66aae000 - 0x7fff66ac5fff com.apple.IOPresentment (1.0 - 32.1) <B95F06EA-9D5D-311D-9912-978AE42ECFCE> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff66e8f000 - 0x7fff66eb4fff com.apple.IconServices (97.4 - 97.4) <C84A6CA5-8C50-3288-8572-CC3DABF5BBCE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff66fbe000 - 0x7fff66fc1ff3 com.apple.InternationalSupport (1.0 - 1) <5AB382FD-BF81-36A1-9565-61F1FD398ECA> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff6702f000 - 0x7fff6703fffb com.apple.IntlPreferences (2.0 - 227) <0FF7209B-0E4D-3411-B325-03938B7C0938> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff67149000 - 0x7fff6723efff com.apple.LanguageModeling (1.0 - 159.3.1) <9B08E18E-69B4-3413-A03A-EF5AE4BE6277> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff6723f000 - 0x7fff67281ff7 com.apple.Lexicon-framework (1.0 - 33.2) <5CC5E8EE-62A1-3EA5-B300-A39ABD0CF12D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff67285000 - 0x7fff6728cff7 com.apple.LinguisticData (1.0 - 238.3) <228AF7CA-649A-3E24-BBC7-8A24B39B3FC4> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff67373000 - 0x7fff67378fff com.apple.LoginUICore (4.0 - 4.0) <33D9089B-ECDB-361D-973A-1FDDACC5BFDF> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff673c4000 - 0x7fff673e1ff3 com.apple.LookupFramework (1.2 - 239) <ACECB15D-1C21-3D3D-A4C5-F9736090E741> /System/Library/PrivateFrameworks/Lookup.framework/Versions/A/Lookup
0x7fff67ab0000 - 0x7fff67ab3fff com.apple.Mangrove (1.0 - 1) <13832222-8A6B-3790-8914-BE874B5ED4DD> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff67b3c000 - 0x7fff67b3eff7 com.apple.marco (10.0 - 1000) <86E99D5C-D56D-3874-B465-833A9B40DE88> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fff67bcc000 - 0x7fff67bffff7 com.apple.MediaKit (16 - 871) <47A5B872-4139-315D-A047-581F9C485D15> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff67eee000 - 0x7fff67f57ff7 com.apple.gpusw.MetalTools (1.0 - 1) <F77943BC-0466-3700-BEDF-CDD13125D36A> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff67f5f000 - 0x7fff67f74ff3 com.apple.MobileAssets (1.0 - 437.40.1) <589D6786-0C0F-3CDB-8093-3834402CE083> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff680cc000 - 0x7fff680e4ff3 com.apple.MobileKeyBag (2.0 - 1.0) <4C70F92C-BB58-393E-B613-EAB16790CCED> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff68170000 - 0x7fff68198fff com.apple.MultitouchSupport.framework (1204.13 - 1204.13) <6C5D778D-4AB7-39A4-989B-2E8D2D57B3A0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff681a1000 - 0x7fff682a4ff7 com.apple.NLP (1.0 - 122.3) <53DD8573-32DE-32FD-A25A-249356EF9D95> /System/Library/PrivateFrameworks/NLP.framework/Versions/A/NLP
0x7fff683fd000 - 0x7fff68408fff com.apple.NetAuth (6.2 - 6.2) <5C6F492A-28EF-3A0E-B573-6F3D60CFF0C7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff68415000 - 0x7fff684e2ff7 com.apple.Network (1.0 - 1) <0221BFB3-3174-3D87-B6F2-4557367B770B> /System/Library/PrivateFrameworks/Network.framework/Versions/A/Network
0x7fff69c0a000 - 0x7fff69c4affb com.apple.PerformanceAnalysis (1.183.1 - 183.1) <2BE359F2-DCE6-3E33-BA99-964507A3F540> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff69cc2000 - 0x7fff69cc2ff7 com.apple.PhoneNumbers (1.0 - 1) <F8D10107-164F-39BE-8A3D-638E90678DDD> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff6b6ae000 - 0x7fff6b6d3fff com.apple.pluginkit.framework (1.0 - 1) <D627D78B-BEDA-3E53-B5F8-B3805F1C4D2A> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff6b9d2000 - 0x7fff6ba25fff com.apple.ProtectedCloudStorage (1.0 - 1) <BA92C805-2AAD-3C71-A8EC-C2A4DAFD5E7C> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff6ba26000 - 0x7fff6ba44fff com.apple.ProtocolBuffer (1 - 259) <D047A3FE-C7A8-3CAA-9891-6232BA88C247> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff6bbb1000 - 0x7fff6bbc6ff3 com.apple.QuickLookThumbnailing (1.0 - 1) <0771325B-BBAD-3865-B2A3-BE7089641C52> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff6bc15000 - 0x7fff6bc20fff com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.30.29) <E2AEA0D7-23E6-3198-96EF-2F1F8ACD98B4> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff6bc21000 - 0x7fff6bc44ffb com.apple.RemoteViewServices (2.0 - 125) <AEDBCE8C-88B7-315A-9F81-3E068F0D3EDC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff6bc45000 - 0x7fff6bc56ffb com.apple.xpc.RemoteXPC (1.0 - 1205.30.29) <1FD53EC6-A9E9-3AEC-86A7-C52729D1A135> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff6d542000 - 0x7fff6d54aff7 com.apple.coreservices.SharePointManager (1.0 - 57.1) <AC7FC6A0-5881-36B4-884E-86B93B74969A> /System/Library/PrivateFrameworks/SharePointManagement.framework/Versions/A/SharePointManagement
0x7fff6d561000 - 0x7fff6d672fff com.apple.Sharing (972.14 - 972.14) <964AEC2D-8A2A-33BE-9334-98A7CBE7CC51> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff6d673000 - 0x7fff6d692ff3 com.apple.shortcut (2.16 - 98) <B8A517F6-B872-3A71-B096-709A0CC6656F> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff6d69c000 - 0x7fff6d69dfff com.apple.performance.SignpostNotification (1.0 - 1) <D4C967BA-92C6-3BAB-AFB5-59F98B35F921> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0x7fff6e39a000 - 0x7fff6e634fff com.apple.SkyLight (1.600.0 - 312.23.4) <455CE6F6-CD58-3E08-8300-CA8BDD3377FC> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff6ede5000 - 0x7fff6edf2ff7 com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <AC026FB9-78F8-31F9-BB80-619D5378DB70> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff6eea5000 - 0x7fff6f0e0fff com.apple.spotlight.index (10.7.0 - 1191.2.6) <236BC19C-F361-344B-91DE-1B40C6E31878> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff6f28b000 - 0x7fff6f2b2ff7 com.apple.StreamingZip (1.0 - 1) <F06F4CDC-138C-3991-A987-7C7332BE4508> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff6f2b3000 - 0x7fff6f324ffb com.apple.Suggestions (6.0 - 213) <36ED2166-7EE5-3114-9EA7-FEA0616DF0DE> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fff6f984000 - 0x7fff6fa08fe7 com.apple.Symbolication (9.0 - 63079.1) <177BC9CA-E6AE-3B40-806F-0080C0CDFF29> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff6fa19000 - 0x7fff6fa20fff com.apple.SymptomDiagnosticReporter (1.0 - 820.30.7) <0188BA8D-0C88-3413-A199-666C7FBE4DF1> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff6fcca000 - 0x7fff6fcf6fff com.apple.framework.SystemAdministration (1.0 - 1.0) <6AE03DE8-E5C1-38E5-B788-0A763CAACDC2> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff6fefa000 - 0x7fff6ff01ff3 com.apple.TCC (1.0 - 1) <C807D3F0-FE20-3FC0-8D61-306477ABEBC4> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff7010e000 - 0x7fff701cbff7 com.apple.TextureIO (3.7 - 3.7) <C98BFACA-7807-3DCA-945D-58EBA2B723C8> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff7021c000 - 0x7fff70237ffb com.apple.ToneKit (1.0 - 1) <A0242052-983B-3726-B5BD-D2E672CEFE2F> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff70238000 - 0x7fff7025ffff com.apple.ToneLibrary (1.0 - 1) <7EEABD7F-D0CB-327E-A772-ACF406B9C8F2> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff7026f000 - 0x7fff70270fff com.apple.TrustEvaluationAgent (2.0 - 31) <39F533B2-211E-3635-AF47-23F27749FF4A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff70276000 - 0x7fff70425ff3 com.apple.UIFoundation (1.0 - 546.1.1) <D2DB451C-56CD-3249-B8EE-AF21DBDCFBF8> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff710ee000 - 0x7fff711bdff7 com.apple.ViewBridge (343.2 - 343.2) <B23D10F2-A5E8-30EF-964A-6E968F4017A1> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff7193a000 - 0x7fff7199afff com.apple.xquery (1.3.1 - 30) <D18B188E-9D92-3644-9612-6ECB2D9C908F> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
0x7fff71b68000 - 0x7fff71b6affb com.apple.loginsupport (1.0 - 1) <5E2C4AA7-066D-3FDB-B0E1-4CDAF287392C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff71b6b000 - 0x7fff71b80fff com.apple.login (3.0 - 3.0) <140118A7-8FB9-35C5-92FA-BD79C9C32309> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff71bab000 - 0x7fff71bd8fff com.apple.contacts.vCard (1.0 - 2330.3) <0417A3AE-7A95-37DB-895B-33EAAC7A1422> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff71cce000 - 0x7fff71d01fff libclosured.dylib (519.2.2) <48051216-5647-3643-B979-B77D0FD20011> /usr/lib/closure/libclosured.dylib
0x7fff71da1000 - 0x7fff71ddaff7 libCRFSuite.dylib (41) <AB2DA745-F22C-30CF-81D4-35DD716463B8> /usr/lib/libCRFSuite.dylib
0x7fff71ddb000 - 0x7fff71de6fff libChineseTokenizer.dylib (28) <D30A7DB6-058F-3286-9583-60C9EEB77A6E> /usr/lib/libChineseTokenizer.dylib
0x7fff71de7000 - 0x7fff71e74ff7 libCoreStorage.dylib (546) <B495D87B-FE21-3C14-9017-F02D9CA226D5> /usr/lib/libCoreStorage.dylib
0x7fff71e78000 - 0x7fff71e79ff3 libDiagnosticMessagesClient.dylib (104) <9712E980-76EE-3A89-AEA6-DF4BAF5C0574> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff71eb0000 - 0x7fff7207aff3 libFosl_dynamic.dylib (17.7) <B2476843-7FA7-3E62-B79F-2B15FE557E63> /usr/lib/libFosl_dynamic.dylib
0x7fff720b2000 - 0x7fff720b2fff libOpenScriptingUtil.dylib (174) <203D2C39-61BB-3713-A502-2D17B04A42AC> /usr/lib/libOpenScriptingUtil.dylib
0x7fff721db000 - 0x7fff721dfffb libScreenReader.dylib (562.13) <21638ECC-87BF-3CC5-B2D8-6F7883F5FDCA> /usr/lib/libScreenReader.dylib
0x7fff721e0000 - 0x7fff721e1ff3 libSystem.B.dylib (1252) <47329E26-DC23-3EBA-9461-37755368327D> /usr/lib/libSystem.B.dylib
0x7fff72260000 - 0x7fff72261fff libThaiTokenizer.dylib (2.2) <04AC7CD4-BD9A-3B1D-8CEB-9E2030B6B667> /usr/lib/libThaiTokenizer.dylib
0x7fff72274000 - 0x7fff72274fff libapple_crypto.dylib (109.40.1) <32252490-B1E9-363F-AEED-3EC97D919348> /usr/lib/libapple_crypto.dylib
0x7fff72275000 - 0x7fff7228bff7 libapple_nghttp2.dylib (1.24) <01402BC4-4822-3676-9C80-50D83F816424> /usr/lib/libapple_nghttp2.dylib
0x7fff7228c000 - 0x7fff722b6ff3 libarchive.2.dylib (54) <8FC28DD8-E315-3C3E-95FE-D1D2CBE49888> /usr/lib/libarchive.2.dylib
0x7fff722b7000 - 0x7fff72338fdf libate.dylib (1.13.1) <178ACDAD-DE7E-346C-A613-1CBF7929AC07> /usr/lib/libate.dylib
0x7fff7233c000 - 0x7fff7233cff3 libauto.dylib (187) <A05C7900-F8C7-3E75-8D3F-909B40C19717> /usr/lib/libauto.dylib
0x7fff7233d000 - 0x7fff723f4fff libboringssl.dylib (109.40.1) <75F5F125-B919-3318-BD12-29CB5E868475> /usr/lib/libboringssl.dylib
0x7fff723f5000 - 0x7fff72405ff3 libbsm.0.dylib (39) <770B341F-3BB7-3123-B53C-F2D58868A963> /usr/lib/libbsm.0.dylib
0x7fff72406000 - 0x7fff72413ffb libbz2.1.0.dylib (38) <0A5086BB-4724-3C14-979D-5AD4F26B5B45> /usr/lib/libbz2.1.0.dylib
0x7fff72414000 - 0x7fff7246afff libc++.1.dylib (400.9) <FCF5E1F6-2B04-3545-8004-F3AB32FED172> /usr/lib/libc++.1.dylib
0x7fff7246b000 - 0x7fff7248fff7 libc++abi.dylib (400.7) <217656D5-BC40-37FF-B322-91CB2AAD4F34> /usr/lib/libc++abi.dylib
0x7fff72491000 - 0x7fff724a1fff libcmph.dylib (6) <A5509EE8-7E00-3224-8814-015B077A3CF5> /usr/lib/libcmph.dylib
0x7fff724a2000 - 0x7fff724b8fff libcompression.dylib (47) <E64D4416-DFBF-314B-BBB9-BED23C3A251C> /usr/lib/libcompression.dylib
0x7fff72765000 - 0x7fff7277dff7 libcoretls.dylib (155) <DFE2454F-2FE3-3B2B-A22B-422947C34C69> /usr/lib/libcoretls.dylib
0x7fff7277e000 - 0x7fff7277fffb libcoretls_cfhelpers.dylib (155) <D3F4B882-40C1-3CD4-927B-0E0ED6031D0B> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff72835000 - 0x7fff72917ff3 libcrypto.0.9.8.dylib (76.30.1) <D47BDA97-AF5D-39A5-9F54-8244C4B6A993> /usr/lib/libcrypto.0.9.8.dylib
0x7fff72918000 - 0x7fff72aa8fff libcrypto.35.dylib (22) <067CFC21-249D-392D-ADE1-785100BF0F83> /usr/lib/libcrypto.35.dylib
0x7fff72c43000 - 0x7fff72c4eff7 libcsfde.dylib (546) <B6F6340A-F874-38BD-A7BB-FFADEBA54789> /usr/lib/libcsfde.dylib
0x7fff72c4f000 - 0x7fff72ca5ff3 libcups.2.dylib (462.1) <B78448A0-9C97-3D4A-823E-EBE37B2B7CA6> /usr/lib/libcups.2.dylib
0x7fff72cd0000 - 0x7fff72d24ffb libcurl.4.dylib (105.40.1) <17EC22AC-0CE7-3FA7-AD55-B636806F46F8> /usr/lib/libcurl.4.dylib
0x7fff72d27000 - 0x7fff72d2eff3 libdscsym.dylib (183.1) <2DE012BF-CE9A-3BDF-9A2D-55D66B51AA35> /usr/lib/libdscsym.dylib
0x7fff72de3000 - 0x7fff72de3fff libenergytrace.dylib (16) <A92AB8B8-B986-3CE6-980D-D55090FEF387> /usr/lib/libenergytrace.dylib
0x7fff72e15000 - 0x7fff72e19ff7 libgermantok.dylib (17) <379C5DC6-BEDB-378D-B09C-A63D297EAA6D> /usr/lib/libgermantok.dylib
0x7fff72e1a000 - 0x7fff72e1fff3 libheimdal-asn1.dylib (520.30.1) <14DC1451-6E22-3A48-80CB-5D33DC0F8C3B> /usr/lib/libheimdal-asn1.dylib
0x7fff72e4b000 - 0x7fff72f3cff7 libiconv.2.dylib (51) <0772997F-4109-38A1-91ED-0F3F16AE99E5> /usr/lib/libiconv.2.dylib
0x7fff72f3d000 - 0x7fff73164ffb libicucore.A.dylib (59152.0.1) <E628882C-6F83-3DCD-B62A-2FE6F77EF6F7> /usr/lib/libicucore.A.dylib
0x7fff731b1000 - 0x7fff731b2fff liblangid.dylib (128) <39C39393-0D05-301D-93B2-F224FC4949AA> /usr/lib/liblangid.dylib
0x7fff731b3000 - 0x7fff731ccffb liblzma.5.dylib (10) <3D419A50-961F-37D2-8A01-3DC7AB7B8D18> /usr/lib/liblzma.5.dylib
0x7fff731cd000 - 0x7fff731e3ff7 libmarisa.dylib (9) <D6D2D55D-1D2E-3442-B152-B18803C0ABB4> /usr/lib/libmarisa.dylib
0x7fff731e4000 - 0x7fff73293fff libmecab.1.0.0.dylib (779.7.6) <4FFE8518-473B-378D-997B-9DB55AB66ADA> /usr/lib/libmecab.1.0.0.dylib
0x7fff73294000 - 0x7fff734bcff7 libmecabra.dylib (779.7.6) <7E255F87-BBB4-3AE5-BC82-6DEE70566D05> /usr/lib/libmecabra.dylib
0x7fff73694000 - 0x7fff7376bffb libnetwork.dylib (1229.30.11) <4E7A6EBA-B3DD-3001-9C97-CB423922B78C> /usr/lib/libnetwork.dylib
0x7fff737e1000 - 0x7fff73bcf7e7 libobjc.A.dylib (723) <93A92316-DE1E-378C-8891-99720B50D075> /usr/lib/libobjc.A.dylib
0x7fff73bd0000 - 0x7fff73bd1ff7 libodfde.dylib (24) <1BBC519E-EF89-38F3-B226-70F086670D0F> /usr/lib/libodfde.dylib
0x7fff73be2000 - 0x7fff73be6fff libpam.2.dylib (22) <7B4D2CE2-1438-387A-9802-5CEEFBF26F86> /usr/lib/libpam.2.dylib
0x7fff73be9000 - 0x7fff73c1dfff libpcap.A.dylib (79.20.1) <FA13918B-A247-3181-B256-9B852C7BA316> /usr/lib/libpcap.A.dylib
0x7fff73c1e000 - 0x7fff73c5bfff libpcre.0.dylib (9) <ABAD6F81-41C0-3AD2-B104-0753A925A205> /usr/lib/libpcre.0.dylib
0x7fff73c9c000 - 0x7fff73cb8ffb libresolv.9.dylib (65) <E8F3415B-4472-3202-8901-41FD87981DB2> /usr/lib/libresolv.9.dylib
0x7fff73cf3000 - 0x7fff73d05fff libsasl2.2.dylib (211) <D9E281A2-D7BA-32CD-8B96-54972B1D9E66> /usr/lib/libsasl2.2.dylib
0x7fff73d06000 - 0x7fff73d07ff7 libspindump.dylib (248) <12E8B8BA-072F-39AE-8BC9-7D5840DA80EB> /usr/lib/libspindump.dylib
0x7fff73d08000 - 0x7fff73e9bfe7 libsqlite3.dylib (274.5) <A1DEB5AB-8FE8-332E-A7E5-F493F2223FE3> /usr/lib/libsqlite3.dylib
0x7fff73ef7000 - 0x7fff73f4affb libssl.35.dylib (22) <4D77B502-E065-3794-90E7-39E83F9683F6> /usr/lib/libssl.35.dylib
0x7fff73f9d000 - 0x7fff73febfff libstdc++.6.0.9.dylib (104.1) <92CC5BBD-2FB2-3864-BF6B-B4B1BFF4C1EE> /usr/lib/libstdc++.6.0.9.dylib
0x7fff7401f000 - 0x7fff74054fff libtidy.A.dylib (15.18.1) <3E33A53A-53AB-3FD5-BBAB-DFA6A3A90132> /usr/lib/libtidy.A.dylib
0x7fff7406c000 - 0x7fff740a5fff libusrtcp.dylib (1229.30.11) <537F14D0-84DF-349F-8EA0-52BB7A241E60> /usr/lib/libusrtcp.dylib
0x7fff740a6000 - 0x7fff740a9ffb libutil.dylib (51.20.1) <216D18E5-0BAF-3EAF-A38E-F6AC37CBABD9> /usr/lib/libutil.dylib
0x7fff740aa000 - 0x7fff740b7fff libxar.1.dylib (400) <0316128D-3B47-3052-995D-97B4FE5491DC> /usr/lib/libxar.1.dylib
0x7fff740bb000 - 0x7fff741a2fff libxml2.2.dylib (31.7) <49544596-BCF8-3765-8DC5-DB1A9A90EF92> /usr/lib/libxml2.2.dylib
0x7fff741a3000 - 0x7fff741cbfff libxslt.1.dylib (15.10) <66682AF6-C2D5-374C-901F-25A3E72814DC> /usr/lib/libxslt.1.dylib
0x7fff741cc000 - 0x7fff741deffb libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
0x7fff7427c000 - 0x7fff74280ff7 libcache.dylib (80) <354F3B7D-404E-3398-9EBF-65CA2CE65211> /usr/lib/system/libcache.dylib
0x7fff74281000 - 0x7fff7428bff3 libcommonCrypto.dylib (60118.30.2) <674286D3-7744-36A3-9AAA-49DFCD97A986> /usr/lib/system/libcommonCrypto.dylib
0x7fff7428c000 - 0x7fff74293fff libcompiler_rt.dylib (62) <4487CFBA-A5D7-3282-9E6B-94CAD7BE507E> /usr/lib/system/libcompiler_rt.dylib
0x7fff74294000 - 0x7fff7429cffb libcopyfile.dylib (146.30.2) <2C7C67D7-562B-3FFA-973D-BACF4C10E1EC> /usr/lib/system/libcopyfile.dylib
0x7fff7429d000 - 0x7fff74322fff libcorecrypto.dylib (562.30.10) <8A53EFE1-AFCA-3676-BEE1-FA5ED9F0E222> /usr/lib/system/libcorecrypto.dylib
0x7fff743aa000 - 0x7fff743e3ff7 libdispatch.dylib (913.30.4) <7D0E3183-282B-3FEE-A734-2C0ADC092084> /usr/lib/system/libdispatch.dylib
0x7fff743e4000 - 0x7fff74401ff7 libdyld.dylib (519.2.2) <C50D02BC-A333-3313-B787-02F255A6783F> /usr/lib/system/libdyld.dylib
0x7fff74402000 - 0x7fff74402ffb libkeymgr.dylib (28) <6D84A96F-C65B-38EC-BDB5-21FD2C97E7B2> /usr/lib/system/libkeymgr.dylib
0x7fff74403000 - 0x7fff7440fff3 libkxld.dylib (4570.41.2) <661F47FA-F6FC-3FB1-8023-9DFE108AEEF7> /usr/lib/system/libkxld.dylib
0x7fff74410000 - 0x7fff74410ff7 liblaunch.dylib (1205.30.29) <E66F58ED-C15E-3DFB-BC22-A861E13918C6> /usr/lib/system/liblaunch.dylib
0x7fff74411000 - 0x7fff74415ffb libmacho.dylib (900.0.1) <756F2553-07B6-3B42-ACEA-2F0F1A5E8D0F> /usr/lib/system/libmacho.dylib
0x7fff74416000 - 0x7fff74418ff3 libquarantine.dylib (86) <6AC8773F-3817-3D82-99C2-01BABB9C3CBB> /usr/lib/system/libquarantine.dylib
0x7fff74419000 - 0x7fff7441aff3 libremovefile.dylib (45) <912FA211-DD8C-3C92-8424-21B89F8B10FD> /usr/lib/system/libremovefile.dylib
0x7fff7441b000 - 0x7fff74432fff libsystem_asl.dylib (356.1.1) <94972913-9DF0-3C78-847C-43E58919E3DA> /usr/lib/system/libsystem_asl.dylib
0x7fff74433000 - 0x7fff74433fff libsystem_blocks.dylib (67) <F2493BB5-B1C6-3C4D-9F1F-1B402E0F1DB7> /usr/lib/system/libsystem_blocks.dylib
0x7fff74434000 - 0x7fff744bdff7 libsystem_c.dylib (1244.30.3) <E0136C71-0648-36F0-9F84-82EA2748A8D7> /usr/lib/system/libsystem_c.dylib
0x7fff744be000 - 0x7fff744c1ffb libsystem_configuration.dylib (963.30.1) <0F8D0B76-4F7D-34EC-AB6C-50F9465809DA> /usr/lib/system/libsystem_configuration.dylib
0x7fff744c2000 - 0x7fff744c5ffb libsystem_coreservices.dylib (51) <21A488D0-2D07-344E-8631-CC8B2A246F35> /usr/lib/system/libsystem_coreservices.dylib
0x7fff744c6000 - 0x7fff744c7fff libsystem_darwin.dylib (1244.30.3) <2F750CB1-BC26-3FA3-AE59-553EE30D451B> /usr/lib/system/libsystem_darwin.dylib
0x7fff744c8000 - 0x7fff744ceff7 libsystem_dnssd.dylib (878.30.4) <EB9BB165-45A4-367C-B33A-688D4F383A95> /usr/lib/system/libsystem_dnssd.dylib
0x7fff744cf000 - 0x7fff74518ff7 libsystem_info.dylib (517.30.1) <7D79E167-4B5C-3833-81EE-3AF3FB53616D> /usr/lib/system/libsystem_info.dylib
0x7fff74519000 - 0x7fff7453eff7 libsystem_kernel.dylib (4570.41.2) <5155A4C3-825B-3178-AC51-0D2D2F2A6618> /usr/lib/system/libsystem_kernel.dylib
0x7fff7453f000 - 0x7fff7458afcb libsystem_m.dylib (3146) <ABB1B85F-9FFE-31B8-AD4F-E39A30794A93> /usr/lib/system/libsystem_m.dylib
0x7fff7458b000 - 0x7fff745aafff libsystem_malloc.dylib (140.40.1) <36B22C99-D772-3039-9A4C-AA31389965E1> /usr/lib/system/libsystem_malloc.dylib
0x7fff745ab000 - 0x7fff7464fff3 libsystem_network.dylib (1229.30.11) <40BAD301-8744-3AD8-A688-E7925C587B00> /usr/lib/system/libsystem_network.dylib
0x7fff74650000 - 0x7fff7465affb libsystem_networkextension.dylib (767.40.1) <CEDC330D-28F0-3902-BEB0-10B92ACEC69F> /usr/lib/system/libsystem_networkextension.dylib
0x7fff7465b000 - 0x7fff74664ff3 libsystem_notify.dylib (172) <98EA3D62-7C86-30DE-8261-D020D2F1EFF3> /usr/lib/system/libsystem_notify.dylib
0x7fff74665000 - 0x7fff7466cff7 libsystem_platform.dylib (161.20.1) <C049250F-8C35-314D-810F-4E28AEAED983> /usr/lib/system/libsystem_platform.dylib
0x7fff7466d000 - 0x7fff74678fff libsystem_pthread.dylib (301.30.1) <ABA848E1-6978-3B42-A3A7-608B2C36FA93> /usr/lib/system/libsystem_pthread.dylib
0x7fff74679000 - 0x7fff7467cff3 libsystem_sandbox.dylib (765.40.2) <922D3D15-AB4C-3F1A-A94F-39214AF1ADB3> /usr/lib/system/libsystem_sandbox.dylib
0x7fff7467d000 - 0x7fff7467eff3 libsystem_secinit.dylib (30) <F06ADB8F-9E94-34A7-B3C9-2C22FDD14BAD> /usr/lib/system/libsystem_secinit.dylib
0x7fff7467f000 - 0x7fff74686ff7 libsystem_symptoms.dylib (820.30.7) <DC3586C2-AA56-3419-88D3-FC0DBF08E3C0> /usr/lib/system/libsystem_symptoms.dylib
0x7fff74687000 - 0x7fff7469aff7 libsystem_trace.dylib (829.30.14) <69EBF017-D40F-30D7-9B0B-BFC862D761A5> /usr/lib/system/libsystem_trace.dylib
0x7fff7469c000 - 0x7fff746a1ff7 libunwind.dylib (35.3) <6D4FCD49-D2A9-3233-95C7-A7635CE265F2> /usr/lib/system/libunwind.dylib
0x7fff746a2000 - 0x7fff746ceff7 libxpc.dylib (1205.30.29) <F7E5F1BC-614B-39CB-B6CE-92A9C7B7EC0B> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1033
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 276105
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=717.7M resident=0K(0%) swapped_out_or_unallocated=717.7M(100%)
Writable regions: Total=77.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=77.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 640K 6
Activity Tracing 256K 2
CG backing stores 193.1M 12
CG image 740K 43
CoreAnimation 452K 35
CoreGraphics 8K 2
CoreImage 152K 32
CoreUI image data 1416K 11
CoreUI image file 216K 5
Foundation 792K 4
Kernel Alloc Once 8K 2
MALLOC 76.9G 1732
MALLOC guard page 96K 24
Memory Tag 242 12K 2
Memory Tag 250 128K 3
OpenGL GLSL 128K 3
SQLite page cache 64K 2
STACK GUARD 56.2M 53
Stack 34.5M 131
VM_ALLOCATE 721.7M 152
VM_ALLOCATE (reserved) 36K 2 reserved VM address space (unallocated)
__DATA 64.0M 466
__FONT_DATA 4K 2
__GLSLBUILTINS 2588K 2
__LINKEDIT 233.8M 78
__TEXT 483.9M 426
__UNICODE 560K 2
libnetwork 128K 9
mapped file 100.2M 109
shared memory 2752K 18
TOTAL 78.7G 3340
TOTAL, minus reserved VM space 78.7G 3340
Model: iMac15,1, BootROM IM151.0211.B00, 4 processors, Intel Core i5, 3.5 GHz, 8 GB, SMC 2.22f16
Graphics: AMD Radeon R9 M290X, AMD Radeon R9 M290X, PCIe, 2 GB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384B54463531323634485A2D314736453220
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384B54463531323634485A2D314736453220
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x142), Broadcom BCM43xx 1.0 (7.77.37.5.1a3)
Bluetooth: Version 6.0.2f2, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
PCI Card: pci11c1,5901, IEEE 1394 Open HCI, Thunderbolt@195,0,0
Serial ATA Device: APPLE SSD SD0128F, 121.33 GB
Serial ATA Device: APPLE HDD ST1000DM003, 1 TB
USB Device: USB 3.0 Bus
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB2.0 Hub
USB Device: G-DRIVE USB
USB Device: USB 2.0 PRO CF Reader
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Back-UPS BN1250G FW:867.L5 .D USB FW:L5
Thunderbolt Bus: iMac, Apple Inc., 26.1
Thunderbolt Device: Thunderbolt to FireWire Adapter, Apple Inc., 1, 5.6
Sounds like a hardware or system problem. A Kernel bad address is low-level, not something an application would cause.
I'd do a clean install of macOS and run memtest to make sure your RAM is ok.
Ditto.........
In August last year when I lost all my photos, I gutted the iMac unplugged it and took it to the APPLE store Genius Bar. They ran it thru all of their testing . with my 24GB (16GB CRUCIAL.com) of RAM installed. After 2 days of extensive testing I was told that everything tested perfectly except the 16GB of RAM was slower that the Apple memory. I asked them to load the latest OS clean and new so that would be ruled out, when I got the iMac home I removed the 16GB of crucial memory in case that was the problem, and have been using 8GB since september 2017. I spent the next month recovering photos to a NEW HARD DRIVE. Only after writing 2 TB of photos to the new hard drive did I "REINSTALL" the ADOBE PHOTOSHOP CC (2017 18.xxx.xxx).
There IS only 1 Hard drive connected to my iMac and it is 6 months old
Again the reason I am in this forum is because I worked w Apple for months and finally they suggested it was an ADOBE issue because
ADOBE creative suites rewrites the OS KERNAL according to the level 2 support I was working with.
The thing I haven't done is reverting all the way back to Maverick or Snow Leopard (ish?) I think, where this problem seemed to not exist not sure about CC's compatibilities or that Im interested in using an OS that old.
You must have misunderstood. Applications don't "rewrite the OS kernel" or anything like that. I'm a former Mac Genius and this is not an application problem. You either have other software that DOES runs a kernel extension (hard drive software, anti-virus, whatever) or you have bad hardware.
RAM speed doesn't cause crashes. Computers have a RAM spec and there is always a range of RAM with slightly different speeds that is compatible. You wouldn't ever know the difference.
Since this doesn't happen to other people, there is something about your system that is different. Try removing any third-party software that might be causing the problem and see if that makes a difference. If not, its bad hardware.
Hi All,
We have released a new version of Adobe Bridge (CC 2019) on 15th October 2018. The new version build number is 9.0.0.204. This version is available to install via Adobe Creative Cloud application.
This Bridge update contains support for managing media cache files (https://helpx.adobe.com/bridge/using/media-cache.html).
Please check following link to know about all new features in Adobe Bridge CC 2019 - https://helpx.adobe.com/bridge/using/whats-new.html
You may need to update the Creative Cloud application and restart your computer to see the updated installer.
Varun Varshney
