Does anyone know of a script that can add metadata in indesign stating any spots used and page count?
I am guessing that this is possible with a script and it is certainly possible with ExifTool (however the result may not be too pretty without some extra work to clean up the raw results)…
However as well as knowing the source metadata (spot colours and page count), what is the destination metadata field/tag? Is it a single field and if so, which one and what is the preferred order of the data? Is it a separate field for both and if so which? What happens if there is any existing data in the destination metadata field/s?
There may be more questions, these are just the first that spring to mind…
EDIT: ExifTool (and Bridge) appears to only report on the first 2 pages of a 2+ page INDD file, so only the spot colours can reliably be reported… So an InDesign script still appears to be the best bet!
The flag can go in any of the metadata field as long as it's visible by search. ie. Colors used: blah blah blah ; Pagecount: blah blah.
Thanks for your reply
How will you search? What software, OS etc? Knowing the search method will help to find the appropriate metadata field to write to.
It appears that I was looking at the page preview feature, which defaults to 2 pages, so if looking to use this feature this has to be taken into account… So there is likely a better way using scripting, based on the actual pages and not the previews which is all that I can leverage outside of scripting using ExifTool.
Hi Stephen,
ah, you read my remarks here:
Incorrect Page Count Value – Adobe InDesign Feedback
Regards,
Uwe
Yes I did and replied over there, thanks again for the tip! This is beyond my meagre scripting skills, however I may still explore ExifTool in order to practice my regex.
You can access document metadata by script:
app.activeDocument.metadataPreferences;
There are certain built-in fields; I've used documentTitle and description. You could also add an array of keywords:
app.activeDocument.metadataPreferences.keywords = ["Colors used: xxx,yyy,zzz", "Pagecount: nnn""].
As Steven_A_Marsh has said, a lot depends on how you intend to search for this information. Certainly another script could slice the keywords.
Bob
