Hello everyone!
I have a problem: in 3d mode on extrusion 'Hole' constraint does not work as it must and do the same function as just 'Active'
As posted earlier , it is an issue. Make the hole before extruding and you should be OK
Dave
Can you share some further info :
1. What version of Photoshop are you using
2. What Operating system
3. How exactly did you make the constraint
It is working here on Photoshop CC 19.1.2 Windows 10.
Edit - I made the hole constraint above when making the mesh. Adding a hole constraint later via path or selection does not appear to be working correctly. The only way was to Edit Source and add the constraint that way
Dave
I see exactly the same issue.
I am very new to Photoshop so I may have misunderstood something, but this thread is one of the few things I found about the subject. The process I was using is as follows:
Windows 10
Adobe Photoshop Version: 19.1.5 20180604.r.346 2018/06/04: 1175273 x64
I noticed that 'Hole' is cut, but not through the front and back inflation material. If Ireduce the opacity of these materials you see a tube where the hole was cut.
Am I doing something wrong, or is this an issue?
Thanks.
Dave
