I've bought a surface pro and the salesman assured me I could run indesign on it however there's nowhere to insert the disk and I'm having trouble installing from the download as well. It's asking for an app to open it so I've downloaded the Creative Cloud app but that won't open it either.
You can download your CS4 installer from
Download Adobe Creative Suite 4 (CS4) products
You must download the correct installer for your serial number. If your serial number is for InDesign CS4 standalone then you must download that installer- not a Suite.
In the case of Windows, you must download two files separately: File 1 (a .7z file) and File 2 (a .exe) file.
I suspect you've only downloaded File 1 and Windows is unable to unpack the .7z file without a separate app - hence the message you saw.
O
...Copy link to clipboard
you can't use the cc app. uninstall it.
what installation file(s) (name, extension and size) did you download?
[moved from Creative Cloud Download & Install to Downloading, Installing, Setting Up]
Once you've downloaded both Files, double click the .exe file and follow the prompts. It will automatically use the .7z file during installation. You'll be asked to enter your serial number to complete the installation so have that handy.
Also, Two ideas that MAY work to install and/or run old programs in Windows 10
-RIGHT click the program icon or EXE and select a compatibility mode in the pop up option window
-or Run as Administrator http://forums.adobe.com/thread/969395 to assign FULL Windows permissions may help... this says Encore, but is sometimes required for ALL Adobe programs (this is NOT the same as using an Administrator account) so follow the instructions for your specific program
