3 Replies Latest reply: Jan 29, 2014 8:43 AM by bradwood.com RSS
    Change Default Connection Properties for SQL Server / ColdFusion 7
    JR "Bob" Dobbs-qSBHQ2 Community Member
      I've started working with indexed views in my Microsoft SQL Server 2005 database. Whenever a SQL statement alters a field ( INSERT, UPDATE, DELETE ) used by the index on an indexed view certain connection settings must be set.
      SET ANSI_NULLS ON
      SET ANSI_PADDING ON
      SET ANSI_WARNINGS ON
      SET CONCAT_NULL_YIELDS_NULL ON
      SET NUMERIC_ROUNDABORT OFF
      SET QUOTED_IDENTIFIER ON
      SET ARITHABORT ON
      When ColdFusion connects to SQL server the ARIHABORT setting is OFF causing SQL statements to fail.
      I currently have two workarounds for this:
      1. Use a stored procedure created with the required settings.
      2. Run a cfquery containing the required settings before the UPDATE, INSERT, or DELETE cfquery statement.
      Questions:
      1. Is it possible to configure ColdFusion's connection to set ARITHABORT ON by default?
      2. Does Microsoft's JDBC driver use this setting by default?
      My environment:
      ColdFusion 7.0.2
      Windows 2003
      Using the SQL Server drivers bundled with CF7
      References:
      Improving Performance with SQL Server 2005 Indexed Views
      http://www.microsoft.com/technet/prodtechnol/sql/2005/impprfiv.mspx
      PRB: Error "INSERT Failed" When You Update Table Referenced in an Indexed View
      http://support.microsoft.com/kb/305333
      Any help is appreciated.
