The Photoshop 11.0 Open Finder Window keeps collapsing in the 'Name' field. As I use this a lot it really slows me down. How do I re-set the preferences so this doesn't happen? I also use Illustrator, InDesign and Quark, and it hasn't happened in those.
It's your User Library
Try this:
Click on your desktop and in the Go menu click on Go To Folder
Then paste or type ~/Library/Preferences
That should get you Library>Preferences and look for and delete the
com.adobe.Photoshop.plist
Hi Keryn
I'm a Windows user so can't offer much insight into what I suspect is related to your version of OSX. It might be helpful to know what that version is? Can you also describe in a bit more detail what is happening? I am guessing that is the way the name field is truncating the file name so you can't read the whole name. Is that right?
How do those fields look in the other applications you mention? Are the other fields in the same order and the same size as in Photoshop?
Have you expanded the window to show more of the fields?
With Windows, double clicking the interface between fields auto expands them to the required width. Have you tried that?
Thanks for getting back to me Akash. Sorry I’ve taken so long to reply (work getting in the way).
I’m currently using a Mac OS X 10.6.8.
You seem to have grasped the problem. And it only happens in Photoshop (Illustrator, InDesign etc are fine).
If you drag the window across you can see the name in full, and if you double click the interface it expands sufficiently. The problem is it doesn’t stay open. Every time you use it you have to drag or double click it open, which really slows down my work (I publish magazines and work with a lot of photos).
This problem only started about a month ago. The window has stay open since I first installed CS4 many years ago. And it hasn’t affected the other CS4 programmes.
I re-installed Photoshop but that made no difference.
I’ve tried sourcing the internet, but a major hiccup is how do you word your request?
If you call it a window you usually get tips on Widows.
Or your request relates the word windows to actual photos.
I’m guessing it’s something to do with preferences or settings, but when you type these nothing is relevant to this problem.
What version of mac os x are you using?
See if going to
/Users/User Name/Library/Preferences
and trashing the
fixes the issue.
Thanks for the reply Jeff.
I’m using Mac OS X 10.6.8
I tried to find /Users/User Name/Library/Preferences with no luck.
Does it apply to me (I’m using CS4)?
Try this:
Guess what Jeff, I tried it and it worked!
This is saving me so much time not having to stretch out the open window each time I open a file or save over one.
Thanks so much for you help. The step-by-steps you gave made a difference too.
Keryn
I have a similar problem. I am on a desktop Imac MasOS Sierra Version 10.12.6 Everytime I open a finder window in Photoshop the finder window is tiny and needs to be enlarged, every time. This started happening last year and I've just put up with it. I tried what you told the person in this conversation to do and it didn't change anything. I hate having to resize the finder window everytime I try to open something. Can you help me? Going to folder library/preferences and looking for com.adobe.photoshop.plist and deleting it didn't help this problem so I put it back so I wouldn't mess up anything else.
I am uisng an imac mas 0S sierra Version 10.12.6
lanaec,
What version of photoshop are you using?
Can you post a screenshot?
I am using an iMac mas 0S Sierra Version 10.12.6n 10.12.6
Sorry, I left out the version of photoshop. It is CS6 purchased over 4 years ago
