0 Replies Latest reply on Jun 24, 2008 2:15 PM by loydbrahn
    Flex 3 and Flash CS3 Component Kit Problems
    loydbrahn
      Hello,
      I'm having problems trying to create a component using the Flash CS3 Component kit for Flex.
      Basically, I'm trying to access a movie clip that is nested within other another movie clip(s). When I select the parent movie clip and select "Convert symbol to Flex Component", then publish the .swc file, and add it to the libs folder in Flex, I'm able to reference the parent movie clip in Actionscript, but none of its children. I've tried giving the nested movie clips instance names (and not giving them instance names), as well as checking/unchecking export for Actionscript in the linkage settings, but nothing seems to work.
      Is there something I'm missing? Shouldn't I be able to access them through parentmc.nestedmc1, etc.?
      My end objective is to change a (dynamic) text field in the Flex Actionscript, which is part of a movie clip, that is then nested within another movie clip.
      Thanks in advance for any help.
      -James
