2 Replies Latest reply on Mar 19, 2018 8:39 AM by kennetho36747272
    Acrobat user interface dialog box too big
    kennetho36747272 Level 1
      I'm using Acrobat Standard DC (2015 Release) on a Windows 10 Pro 64-bit OS. When I open dialog box at File>Create>PDF From Scanner>Custom Scan, the box is so large that I cannot see the "OK" and "Cancel" buttons across the bottom and there is no way to resize the box. I have found that I can go to Windows Settings>System>Display>Scale and layout and change from default 175% scaling to a smaller (custom) setting, but this makes all text, icons, and everything too small. Searching Adobe support, I found a similar problem with Adobe Muse that described resetting Environment Variable in Windows System properties for Muse, but that did not work for Acrobat.
      Any help?
