5 Replies Latest reply on Mar 20, 2018 10:18 AM by 360VisitasVirtuales
    Clipping mask from illustrator to Ch Animator Situation
    360VisitasVirtuales Level 1
      So, I have made some clipping masks in illustrator and taken then to Ch without problems(clothing, basically). It gets the clipping group as a single layer, and fine. But I have two arms in wich it is not working. Actually, three, but one got solved just recomposing layers in illustrator. I have tried the same, but it does not work: it gets it as two different layers and therefore the <linked file> in illustrator appears completely, not being the inside of the clipping path. I have tried renaming, reordering...i can´t make it work. Any ideas? Thanks
        • 1. Re: Clipping mask from illustrator to Ch Animator Situation
          alank99101739 Level 4
          Sorry, I don't understand your description, but I thought that Illustrator clipping masks were not understood by Character Animator. It just understands the transparencies in Illustrator files. There is a clipping mask concept inside Character Animator you can turn on, but I suspect you are not using that from your description. Could you share a screen shot perhaps?
          • 2. Re: Clipping mask from illustrator to Ch Animator Situation
            Thanks! Maybe I am just getting lucky with this clipping masks??? As you can see, clipping mask are interpreted as one layer in my frontal character, while some are interpreted as one layer in the profile and others as two layers(being a problem). I hid the right arm in the profile character so you can see the torso is alright, but the arms are not working.
            By the way, do not judge me by my illustrations, please. I am a video editor but someone asked me if I could draw something.
            • 3. Re: Clipping mask from illustrator to Ch Animator Situation
              Ah, gotcha!  Character Animator tries to auto-detect the outline, but sometimes fails. It is usually because there is some discontinuous object in the layer. There is a property that you can set to “Contour” to force using the outline instead of the default “auto”. You could try just setting that.
              Otherwise (or as well!) try going into AI/PS, go into isolation mode for the suit, then try using the laso tool around the suit to see if you can highlight something that snuck into the wrong layer.
              The other thing to try is clicking the little mesh icon at the bottom of the “rig” and “scene” windows. It shows the mesh it allocated to the layer. This is very important to get right otherwise things will distort badly later. Sometimes it highlights the area that is wrong (the mesh looks funny around a point you did not expect).
              Regarding artwork quality, looks good to me! I am a programmers with zero formal art training, so I cannot speak either! ;-).  As long as its fun, who cares what it looks like... which I can say since this is a hobby for me, not work.
              • 4. Re: Clipping mask from illustrator to Ch Animator Situation
                Oh, just realized my answer might have been not answering your question! I don’t know why the second clipping did not work and the first did.  My understanding is not all Illustrator features are supported by Character Animator - you might have hit one.
                • 5. Re: Clipping mask from illustrator to Ch Animator Situation
                  Thanks! What I did to make it work, suspecting I could have just been lucky, is export to PNG, get rid of the white background in PS and then import that again to the puppet in illustrator. It is not a vector, but playing with the size looks good for Full HD, and the puppet is not vectorizing the movement anyways, so looks good.
                  Hey, thanks for the support for my artwork : )
