I prefer to open and edit photos in camera raw using Bridge. Once the edits are made, I select the photo(s) from the list view on the left of the window and click the "Open Images" button at the lower right of the window. Nearly every time, no matter how many photos I have selected, one or more will fail to open in Photoshop. Even though I have only one photo open in raw, the image might not open into Photoshop. I receive no warning about camera raw not being activated. My software versions are all up-to-date and I am running OS 10.13.3. One explanation might be that the update to High Sierra is the issue as it is with certain functions of InDesign.
Does anyone have a similar problem?
I am using High Sierra.
Bridge > Open in Camera Raw... presents the chosen jpg images as expected.
Camera Raw... "Select All" and "Open Images" present no problems. Opening a single image works fine, too.
Resetting your Bridge Preferences may solve the problem.
To reset Prefs:
Start Adobe Bridge and immediately press Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) until the Reset Settings dialog box appears. Select all three options--Reset Preferences, Reset Standard Workspaces, and Purge
...Copy link to clipboard
What's the exact process you use?
E.g. I've tested the following from Bridge (also running OS High Sierra 10.13.3):
It opens all camera raw images each time I've tested it.
Are you able to review WHICH camera raw files don't open when you try this? Is there something / some setting significantly different, do they have a different file format maybe?
Thanks for your help.
I should have mentioned that virtually all the image file I am using are .jpg files sent by clients for print projects. I haven't tried opening raw file exclusively, but I will run an experiment to check.
Until I upgraded to High Sierra, I had no problems with Bridge opening single or multiple image files into Photoshop.
To reset Prefs:
Start Adobe Bridge and immediately press Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) until the Reset Settings dialog box appears. Select all three options--Reset Preferences, Reset Standard Workspaces, and Purge Entire Thumbnail Cache--and then click OK.
