4 Replies Latest reply on Mar 19, 2018 10:15 PM by Trevor.Dennis
    Make several paths visible
    nickatcs6 Level 1
      Several paths are saved, in the Paths panel. Clicking on any one makes it visible. How to make more than one visible?
      Nick
        • 1. Re: Make several paths visible
          Semaphoric Adobe Community Professional
          With a path selected, Shift+Click or Control+Click on another path.
          • 2. Re: Make several paths visible
            pixxxel schubser MVP & Adobe Community Professional
            If you copy several paths into one path and save - you are able to make visible all paths (better: this new path with all included paths) at once.
            Have fun
            • 3. Re: Make several paths visible
              nickatcs6 Level 1
              Thanks for trying, but this doesn't work.
              (Note: on my Mac,  Command is the same as Control on PC.)
              My results:
              1. Shift-click does the same as click:
              This highlights in the panel and displays in the image only the path that is clicked.
              2. Control-click :
              This highlights in the panel and displays in the image only the path that is control-clicked, in dashed lines, which cannot respond to path selection tool. Dashes persist if the same or another path is clicked.
              Peculiarity? These paths were generated and saved by a script ( "plot pixel value" from the Scripts forum). Because I know nothing about Java, I'm guessing that the last line in it does the save:
              actactiveDocument.pathItems.add('Plot'+Math.random().toString().substr(2), pth); .toSource());
              • 4. Re: Make several paths visible
                Trevor.Dennis Adobe Community Professional
                Use the direct select tool (White arrow) and drag a box around the second path to make its points active.  Copy it Cmd c
                Select the first path and paste Cmd v
                Repeat for the other paths
                Or start by making a new path and paste all the paths onto that.
                On the other hand, if you just want all the paths to be visible, simply select them all
