1 Reply Latest reply on Mar 20, 2018 12:27 PM by EpicProduction8
    Premiere changing bit rate of wireless headphones.
    EpicProduction8 Level 1
      Premiere changes the default bit rate of my wireless(bluetooth 4.0) headphones. Playing back audio from premiere sounds find, assuming its assimilating the audio files to play correctly, but when I stream/play audio from another application it compresses and reduces the playback quality. Is it something within the computers settings i must force? like changing the default audio settings within premiere to match the rest of the computer.
        • 1. Re: Premiere changing bit rate of wireless headphones.
          Resolved. Issue has to deal with the way premiere and osx deal with AtpX bluetooth codec. It takes a little work around, but over all is simple to fix. Start with force enabling ACC and AtpX codecs. Open terminal and execute these commands.
          1- "sudo defaults write bluetoothaudiod "Enable AptX codec" -bool true"
          2- "sudo defaults write bluetoothaudiod "Enable AAC codec" -bool true"
          Then in premiere: Preferences> audio hardware> input device: Built in option.
          This should fix the masterclock/bitrate dilema.
