5 Replies Latest reply on Apr 5, 2018 7:00 AM by Semmison
    Create vector file and colour
    Semmison
      i have found a pattern in a coloring book that has thick black outlines and blank inside for coloring Purposes. I’d like to create a vector file of this image and colour it in on photoshop or illustrator then save each colored piece as a layer for exporting to Svg for cutting.
      I cannot find a technique that works despite hours of research. Can anyone help with step by step instructions please?
      kind regards Sue
        • 1. Re: Create vector file and colour
          Brad Lawryk Adobe Community Professional & MVP
          You would likely find Illustrator a better tool for this than Photoshop.
          • 2. Re: Create vector file and colour
            Semmison Level 1
            Hi, I have illustrator also. Any assistance appreciated
            • 3. Re: Create vector file and colour
              I know Illustrator has tools to convert a file to vector. Probably get a faster answer in the illustrator forum. Or perhaps it has even been asked a few times on that forum.
              Photoshop isn't a vector based app.
              • 4. Re: Create vector file and colour
                Barbara Ash Adobe Community Professional
                First step would be to paste or File > Place your image into an Illustrator file.
                In the Properties panel, click on Image Trace, Black and White Logo.
                Then click Expand in the Properties panel. You will now have a group of filled vector shapes.
                Select the Live Paint Bucket tool.
                Select a color in Swatches, and click an area to fill it with color.
                If some areas do not fill the way you want, it may be that the area has a gap or opening, and is not enclosed. If that is the case, you can choose Once you are done filling areas with color, choose Image > Live Paint > Gap Options and increase the size of the gaps.
                Once all the areas are filled, choose Object > Live Paint > Expand. That will result in a set of grouped objects.
                The objects need to be ungrouped in order to put them on different layers. (Object > Ungroup)
                In the Layers panel, create a new layer for each object.
                Select an object or set of objects and drag the square dot to the right of the layer to the layer you want to put it on.
                2 people found this helpful
                • 5. Re: Create vector file and colour
                  Semmison Level 1
                  Thank you Barbara, much appreciated.
                  kind regards Sue
