3 Replies Latest reply on Jun 23, 2008 10:28 AM by Captiv8r
    Fail Message
    Jillbr
      Is there a cap on the amount of text you can enter into the fail message review areas?
      When I enter a sentence it will display in the preview, however if enter a paragraph it will not display!
        • 1. Re: Fail Message
          Hi Jill
          Um, which area are you referring to?
          * Failure Caption (appears in conjunction with Click Boxes, Buttons, Text Entry Boxes and Question Slides
          * Review area (appears in Question slides during the review process
          You are talking about a fail message review area, so I'm a bit confused with exactly what you mean.
          Cheers... Rick
          • 2. Re: Fail Message
            Jillbr Level 1
            I'm sorry, I'm referring to the review area which appears in Question slides during the review process
            • 3. Re: Fail Message
              Hi again
              The area does appear to be limited. On my own PC here and testing, it seems that all of it appears on a single line.
              However, this area contains the same text for all slides if a failure has occurred and doesn't allow for differentiating based on the question. So perhaps consider either inserting the text into a Failure caption or a different slide and branching to the different slide when a failure occurs?
              Just thinking out loud... Rick
