• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Add page number to first page of chapters (Edited for brevity)
Participant ,
Mar 20, 2018 Mar 20, 2018
Page numbers do not appear on the first page of new chapters. Continuous page numbering is spot-on, but I want to be able to see the page number in the footer of EVERY page, including the first page of a new chapter in the book.
Views
315
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Mar 21, 2018 Mar 21, 2018
Hi cameol8779899​:
The only way for this to happen is if the first page of each chapter is using a custom master page.
New double-sided documents start with a default left and right master page. Anything you add to them (i.e., a page number) will immediately appear on all the body pages. To remove a page number, you have to add a custom master, remove the page number variable and assign it page to 1 either thought Format > Page Layout > Apply Master Pages or a master page mapping table on the refe
Votes
Translate
Translate
LEGEND ,
If the first page of each chapter is different from the standard right/left pages, then add the page number variable to the appropriate Master Page used by your chapter first pages.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Hi cameol8779899​:
New double-sided documents start with a default left and right master page. Anything you add to them (i.e., a page number) will immediately appear on all the body pages. To remove a page number, you have to add a custom master, remove the page number variable and assign it page to 1 either thought Format > Page Layout > Apply Master Pages or a master page mapping table on the reference pages.
In your scenario, you could either add the page number to the custom master behind page 1 as per Arnis, or revaluate page 1. Does it need to look different from all the other right hand pages? If it doesn't, you can assign Right/Left to body page 1 (again Format > Page Layout > Apply Master Pages), then delete the custom master. If it was assigned through the master page mapping table, then remove that reference from the reference pages, as well.
~Barb
Votes
Translate
Translate
Report
Report
