I was using illustrator just fine yesterday. Come today and I cannot use any of the menu bar items at the top, nor can I use most of the sidebar options. Cannot select, cannot save unless I close the program, cannot type, can't copy and past from one application (illustrator, photoshop and text from word document. I cannot open a file from the top bar options. To get more than one page up in the tabs, I have to go to the folder they are saved in and I cannot switch between them nnor can I edit them in any way. Please someone help???
What exact version of Illustrator and what operating system are you using? There is "CC" and there was "CS" 1-6 but there is no such thing as "CCS". At any rate the problems you are describing sound like your program is in need of resetting to its default so try trashing your preferences.
To do so:
For Macintosh Users: With Illustrator closed launch a Finder Window in column view and click on your home folder. With the Option Key pressed choose Library from the Finder Go Menu. Within the Library folder find the folder called Preferences and within it find the following two files and delete them: “Adobe Illustrator <Version #> Settings” (earlier versions of Illustrator might just say “Adobe Illustrator”) and “com.adobe.Illustrator.plist”. When Illustrator is next launched it will create new preference files and the program will be restored to its defaults.
For Windows Users: You can try the quick way of resetting on a PC which is to hold down Ctrl + Alt + Shift when launching Illustrator and respond affirmatively when asked if you want to reset. There have been some recent reports that the window asking if you want to reset is not popping up but that the prefs are being reset anyway. If this works great but if it doesn’t you may have to manually delete them.
To do so:
On Windows 7 and above the preference files are hidden. To find them go to the Control Panel and open Folder Options and then click the View tab. Then select “Show hidden files and folders” or “Show hidden files, folders or drive options” in Advanced Settings. Then delete (or rename) the folder at the end of this path: C:\Users\[User Name]\AppData\Roaming\Adobe\Adobe Illustrator [version number]\ Settings\<Language>. Make sure that Illustrator is closed when you do this. When you relaunch the program it will create new preference files and the program will be at its default settings.
The advantage of manually deleting preference files is that after you’ve reset up the program (make sure that no document window is open) to your liking, you can create copies of your personalized “mint” preference files (make sure that you quit the program before copying them—that finalizes your customization) and use them in the future to replace any corrupt versions you may need to delete.
Wha version of illustrator you have? did you just updated it? it might not be compatible to your grphics card.
Suggestions:
Uninstall it - and clear all preferences.
Do a clean install!
That might help1
Let us know if it is working~
Cheers
This has now been sorted out. Thank you
How was it sorted out?
